Atmel Studio 7 executes the previous instruction instead of the current one
19 posts / 0 new
Hi guys it's hard to describe my problem so I attach several screenshots
On the first screenshot everything is fine if i press 'step into' button I get into the function. It's ok
if i execute code to the next breakpoints and press ''step into'' button i get to the next breakpoint without getting into the function 'SPIWriteReg'
And if i press 'step into' once again on the "temp = 0xf0;"  i get into the previous function! and temp doesn't change value.
'temp' will change its value when i execute next line here
And in all the following code the previous line will be execute instead current one.
I turned off all optimizations. How to fix this?
upd
mcu Xmega128A1
jtagice mk2
AtmeStudio 7.0.1417
Probably down to optimisation ?
I tried different configurations, now its -O0
Switch to the mixed C+asm view and step it an opcode at a time - that will give a much clearer picture of the path of execution.
That source is not in the right place compared to the code. For example you have a call to SPIWriteReg(0x0B) but you see the LDI R22, 0x0B and RCALL about 10 opcodes later. Similarly there is a SPIWriteReg(0x23) but the LDI R22, 0x23 then RCALL about 10 opcodes later.
When source annotation and code get "out of step" like this it's often something to do with "funny line endings" in the source files.
Or this could simply be a bug in Studio.
Or the source code on your machine does not match what's running in the target; eg, because you forgot to build and/or download it ...
Been there, done that!
That's why I always have a "hello" message that appears at startup with a build timestamp ...
awneil wrote:
...I always have a "hello" message that appears at startup with a build timestamp
+1yes
David (aka frog_jr)
I've tried my project on another PC and it works fine, I hope re-installation will help me
That certainly sounds like the source on the PC out of sync with what's burned in the target, then!
Wonder if the Norway boys are all on vacation? I'd expect to hear from them on this one.
Well, re-installation doesn't help. I make and  debug code in Atmel Studio so I'm sure that the target in mcu is right. I think the problem is in the debugger or drivers, sometimes i've got "Failed to connect: MPLABCOMM_INVALID_HANDLE" and it seems that debugging in my pc is working different than in another with the same mcu and the same debugger.
I have also a lot of Debugging problems with the Studio V7!!!
I have moved from V6.2 to Atmel Studio V7.0.1417 (Naggy 0.4.0 installed) and I'm getting crazy during Debugging with the new Studio (CPU: ATxmega256D3, Debugger Atmel-ICE).
When using STEP OVER or STEP INTO, the Debugger jumps in the source code like there was no debug-information at all.
It jumps back and forth without any sense and without any relation to my source code lines....???
I have tried optimizations O0, O1, Og. None of them is usable.
Currently I went back to V6.2 (with the same source code) and I have absolute NO PROBLEMS at all.
STEP OVER and STEP INTO do what I expect them to do.
Total votes: 2
Do not cross post.
This is happening to me. It has only started happening in the latest version of AS7 1417. The older version (1188) worked fine for me. I am currently in the process of downgrading.
I can't exactly put my finger on what it is that has happened, but I usually understand the optimisations and how that affects debugging quite well. I have always in the past defined a variable as volatile to force a break point such that:
volatile uint8_t x = 5;
x++;    //set break here
Breaking on the x++ in the past has guaranteed a break within my code while debugging. The newer toolchain seems to have done something differently where this is not always the case. Either this or the breakpoint in my 1500 line file starts being...missed. This can be proven by having multiple "else if" statements. Where the functions is defined 1400 lines in. Each "else if" would be defined with two lines of code within them. When I do a "Step Over" it doesn't break on the "else if" at all, it breaks on either the first or second line of code within the statement. "Step over" this line and it jumps to the first or second line of code in the next statement. In my 20 condition "else if" this is very consistent. Thus breaking in the wrong locations in comparison to the older version. I am only talking about comparisons between r1188 and r1417 and how things have appeared to have gotten much worse.
There is another debugging issue that also been identified, where the variables don't get updated after executing lines of code. Sometimes it would take several lines or even entire functions before those variables are updated, while I couldn't comment on how the optimisations affect this, r1188 did do this sometimes, but very rarely. r1417 seems to consistently do with almost every variable I have.
EDIT: Just finished my downgrade to r1188 and all my breakpoints are breaking on the correct locations again and my variables while debugging are showing the correct values once more!
@Atmel: last time this happened it was because the tools were always assuming '\n' line endings in source not the "\r\n" in Windows source files.
Wonder if the 4.x to 5.x compiler switch has regressed this fault?
Duely noted, I've logged a bug so that we can investigate (AVRSV-7889).
:: Morten
meolsen wrote:
Duely noted [...]
I read that as "duly". OTOH since Cliff suggests a possible regression, and a bug that needts to be fixed a second time, it could be "dually". Then of-course, if this is a shoot-out between different EOL conventions it might be "duelly". Sorry, couldn't resist..
JohanEkdahl wrote:
meolsen wrote:
Duely noted [...]
Hang down your head, Tom Dooley
Hang down your head and cry
Poor boy, you're bound to die
-- Kingston Trio, circa 1958  https://www.youtube.com/watch?v=...
