Arduino/AVR: Interrupt only works once
10 posts / 0 new
I've implemented an interrupt in my program, so that when a button is pressed, the program does something. This works and it's all fine. The program gets interrupted from A, does B, and returns to A.
My issue:
Once returned to A, I can't re-interrupt the program. I've tried adding `buttton_init();` after `ledGood();`, but then my program stops working all together!
Here's what I have so far:
    static void button_init(void)
        PORTB |= (1<<PB2); /* enable pull-up */
        PCICR |= (1<<PCIE0); /* enable Pin Change 0 interrupt */
        PCMSK0 |= (1<<PCINT2); /* PORTB2 is also PCINT42*/
    ISR(PCINT0_vect) /* pin change interrupt service routine */
        ledInProgress();
        int count = 0;
        while (count < 100) {
            _delay_ms(200);
            count++;
        /* Let the user know we've finished */
        ledGood();
       /* Init the interrupt button */
       button_init();
        /* Enable interrupts globally - cli() would clear this! */
       sei();
       /* set PORTB for output/input*/
       DDRB = 0b11011111;
        while(true)
            sleep_mode();
If button is on PB2, why make in an output in:
DDRB = 0b11011111;
I believe that should be:
DDRB = 0b11111011;
David
You're right.
It's still not working though..
what's in sleep_mode(), ledGood() & ledInProgress()?
sleep_mode() is an AVR-libc function:
http://avr-libc.nongnu.org/user-...
The LED functions just turn the LEDs on:
ledGood()
void ledGood() {
	PORTB = (1<<PB4);
ledInProgress()
void ledInProgress() {
	PORTB = (1<<PB3);
By using out right assignment you are turning off the pull-up resistor on PB2. Try using |= rather than =.
Edit: To explain further...
	PORTB = (1<<PB4);
will set PORTB to 0b0001000. Thus bit 2 is clear, thus the pull up is disabled. The same applies with
	PORTB = (1<<PB3);
Ah, I knew it would be something like that, I just couldn't figure out what. Do you know of any good resources for bit values, etc? (not limited to the Arduino, more assignment related stuff).
One thing though..
Now, I get an turqoise colour in my RGB LED (ledInProgress = blue, ledGood = green). I know this is because I have both pins toggled at the same time, but I'm not sure why :(
You get a turquoise colour because you have both the blue and green leds on at the same time. When you do
PORTB |= (1<<PB4);
You essentially set bit 4 of PORTB, but the other 7 bits are left unaffected. so for example, if before that line of code is executed PORTB = 0b11001001, then afterwards it would be 0b11011001.
If you google 'bit manipulation in C' or something to that effect you should find plenty on it, but in general:
Set a bit: REG |= (1<<BITn);
Clear a bit: REG &= ~(1<<BITn);
Toggle a bit: REG ^= (1<<BITn);
Checking if a bit is set: REG & (1<<BITn);
For example...
if (PORTB & (1<<PB2)) {   // if bit 2 of port B is high
    PORTB |= (1<<PB4);
} else {
    PORTB &= ~(1<<PB4);
Note: BITn = bit number.
Just for clarification, the (1<<PB4) part means 1, shifted left by 'PB4' times, and you'll find PB4 #define'ed as 4, so:
0000 0001
0000 0010
0000 0100
0001 0000
PORTB |= (1<<PB4); is essentially the same as PORTB |= 0b00010000;
You're amazing. Thank you!
No problem. Also worth knowing, if you're using Atmel Studio 7 you can use IO View to observe various registers and the effects your code has on them.
