Xmodem sends a multiple of 128 bytes?
16 posts / 0 new
I am trying to send a file using TeraTerm using 128B size Xmodem transfer. I receive using ATSAMD21. It seems to be the PC is always sending a multiple of 128B? I would have expected the PC to send all 128B except for the last one where it would send a packet less than 128B when the filesize is not modulo 128? I cant seem to find this info anywhere...
That should be available in Xmodem specs, not TeraTerm, I would think.
OK have done some reading...it seems Xmodem always sends in 128B size including the last packet. Which is a pain...so it means the firmware file must be created in size of modulo 128. Or I could use xtended Xmodem which puts the file size and name in packet 0 at start. But which serial terminal program support this?
Does anyone know the command sequence to get srec_cat to generate filesize modulo 128 padding?
In order words if the file size of the bin is say 12001, it's modulo 128 is 97. Meaning another 31 bytes and it would have been 0 for mod 128.
How can I say fill this 31 bytes with zero and pad. Well that bit is not too hard...but how do I find this modulo number 31 for a given filesize?
Just started using srec_cat so not very versed, yet. BUT, I think you can have it fill up to any specified address. My application fills it to the very last byte (or maybe last byte - 2), then puts a crc16 in the last two bytes.
Normally the xmodem sender will pad if required.
With ctrl-z...
Ctrl Z is fine when its a text file...but when binary...its easy to have a byte that is 26 in value.
I need to consider padding to modulo 128 using srec_cat...someone tell me a way please... still wondering.
This is the downside of Xmodem. There's nothing in the protocol to send the file size. Ymodem is a better choice. Otherwise arrange to send the exact number of bytes before you start.
I probably haven't used that stuff in 30 years.  HyperTerm claims to use Zmodem.
My experience of implementing Xmodem is that Hyperterminal is one of few programs that does not do it right. Just one of many reasons why I would always choose a decent terminal program and not the excrable Hyperterminal!
My memory of Xmodem on 300 baud telephone line modems was that it was terrible.
Xmodem-CRC or Ymodem were a dramatic improvement.
Zmodem has other features.
Nowadays,  telephone modems have Error Correction.   All protocols will benefit from this.
How are you transmitting your files?   Radio, phone, wired link, ... ?
Different transmission mediums will have different types of error.
I am transfering using usb to serial and off to micro...
I would like to use Xmodem if I can. So if i just crop and cut the firmware to 128byte boundary it should all be fine.
There has to be an option for padding to modulo 128 in srec_cat. :(
I never had any problems with it in that respect!
Correct.
And XModem-1K always sends 1KB size blocks.
Loads of them - it is called, "YModem"
EDIT
http://www.rogtronics.net/files/...
http://web.cecs.pdx.edu/~rootd/c...
I don't understand the problem.  It's only the last block that is padded with ctrl-Zs; if you have a binary file, it would have to actually END with ctrl-Z for there to be a problem.  And usually you can just write the ctrl-Zs anyway; it's not like wherever you're putting the data doesn't have its own idea of a block size.  (that's where XMODEM gets it from; 128byte floppy sectors.)
XMODEM was a simple block-oriented file transfer.
YMODEM added file info (length and filename) and used a CRC for error checking.  It permitted wildcard transfers...
ZMODEM added windowing...
