AT CSQ returns CME error 604. Quite strange!
6 posts / 0 new
I'm using an SIMCOM, SIM800. This module was working perfectly fine, but suddenly it stopped posting and while debugging I found out that AT+CSQ was returning "+CME ERROR:604" which according to Telit means can not allocate control socket.
Does anyone know what that means? What does the control socket do? It's strange to see the CSQ command fail.
Clament John | Still in school
What has this got to do with Atmel microprocessors? (the subject of this message board).
Moderator
I'm sorry, this board was tagged as "Evaluation and Development Kits A discussion forum for evaluation and development kits as well as add-on extensions boards."
As the SIM800 module, I'm using is an extension/development board being used with my Atmega. So I assumed this was the right board to raise the question.
No - this is an Atmel board, for discussing Atmel products.
The SIM800 is not an Atmel product; it is a SIMCOM product - so you would need to contact SIMCOM for specific support on their product.
http://simcomm2m.com/En/module/?...
http://simcomm2m.com/En/service/
EDIT
You need to refer to SIMCOM documentation - not Telit - for SIMCOM products!
It means Atmel eval boards:
http://www.atmel.com/products/mi...
Not just "any old board that you might happen to connect to a micro which may or may not be an Atmel".
Surely SimCom have a support forum? In fact while this is more general than just SimCom there seems to be a lot of support for this kind of module (SIM800, SIM900 etc) at:
http://m2msupport.net/m2msupport...
Alright, thank you for your time. I'll make sure my future questions are more based on Atmel products and about general electronics.
Thank you.
