Why is OCR0 is a signed byte
23 posts / 0 new
Hello All,
I'm having trouble trying to use PWM on an AtMega328P using AVR Studio 7. When I set up timer0 in an attempt to use OCR0A and OCR0B in CTC mode the values are saved to those registers as SIGNED values.
Whenever I try to place any value higher than 127 in OCR0A or OCR0B it rolls over into the negative domain.
1. Is there a way I can change these two registers to hold unsigned values?
2. Is this a compiler issue or a on-chip register issue?
#include <avr/interrupt.h>
ISR(TIMER0_COMPB_vect)
 PORTD &= ~((0x01<<PORTD6) | (0x01<< PORTD7));
ISR(TIMER0_COMPA_vect)
 PORTD |= (0x01<<PORTD6) | (0x01<<PORTD7);
void PWM(void)
 //OCR0A = top of period in CTC mode
 uint8_t period = 255;
 OCR0A = period; //watch added to OCR0A, IT'S NEGATIVE ???????????????????????
 OCR0B = 129; //ALSO A SIGNED VALUE ??????????????????????????????????
 //3. Ratio of OCR0B/OCR0A gives duty cycle
 sei();
 //TIMER 0 set up:
 TCCR0A |= (0x01<<WGM01); //set up CTC mode for OCR0A
 TCCR0B |= (0x01<<CS00); //enable timer w/ 1 prescaler. Smallest resolution for PWM
 TIMSK0 |= (0x01<<OCIE0A) | (0x01<<OCIE0B); //Enable interrupts for OCR0A and B
    PWM();
    while (1)
If you run the above code and add watches to OCR0A and OCR0B you will see that they are negative values...All the documentation EVERYWHERE states that the register max is 255.
Please help. This is severely screwing up my PWM.
The only hint you've given is 'watch' - are we to assume you've drawn your conclusion from the value shown in the debugger watch window? You put 129  which represented as a signed value would be displayed as -127. Both values are still 0x81. So where is the problem?
Nothing to do with Studio bugs, moving to mega forum.
Sorry it seems I was wrong, movedback to Studio forum.
This is entirely a presentation problem.
If the signed value presentation is in Atmel Studio while debugging/simulating then you can modify how the value is displayed. The studio help has more om modifying the display in e.g. the watch window.
You keep saying that, but I can't see any forum that is restricted specifically to Studio bugs:
Since the OP is asking specifically about a feature of Atmel Studio, it would seem that it should be in the 'Atmel Studio (AVR-related)' forum - surely?
(in fact, it's probably more of a 'General Programming' issue - as the same thing can arise in anything that displays "raw" values...)
Right click the watch and you have the option to switch to a hex display. In that you will just see 00..FF which are much easier to interpret. (programmers don't really use decimal do they?)
I'm suspecting the implementation is the cause of the upset - prescale of 1 on an 8 bit timer with two interrupts - if those interrupts get too close together in time, then the execution time of the isrs come into play. If we guess at around 50 cycles per isr, the range of pwm is rather limited.
Thanks for the speedy reply. Yes, I was using a watch with the debugger and noticed that the value was negative rather than what I expected it to be. Does this mean that regardless of what the debugger is displaying the register holds the full unsigned value?
Yes.
Again: The interpretation and display as signed or unsigned is in the debugger display. The register is literally eight binary bits - nothing more.
The signed - 1 and the unsigned 255 is the exact same bit pattern in eight bits.
I think you missed the point.
The point is that what the debugger displays does not in any way affect the bit values in the underlying hardware.
You have to adjust the debugger to show the particular interpretation/representation that is most convenient for you at the time.
0xFF, 255, -128 (sic) are all ways to interpret the same underlying bit pattern.
EDIT
Ahem: Of course, I mean: 0xFF, 255, -1 are all ways to interpret the same underlying bit pattern.
blush
> 0xFF, 255, -128 are all ways to interpret the same underlying bit pattern.
Double-check your two's complement just above, awneil... ;-)
First, thanks for the speedy reply.
If I'm running the chip at 16MHz, shouldn't the 50 cycles be inconsequential because they're so small...ahhh, but the Timer0 "sees" cycles so if the two OCR0n values are within 50 of each other then there will be an issue.
If I use the function _delay_ms(), how will that affect the ISR. Can I use it to build a bit of space between OCR0A and B interrupts?
Excellent! I get it.
Thanks for help guys.
Why on earth would you want to call _delay_ms()? Already your ISR() times could be "borderline". You don't want to compromise that further.
blush
post updated
The only reason i could see that you would implement pwm in the manner you have is to have the freedom to choose the port pins. You now know the limitations. The timers have specific pwm modes that do exactly what you want in hardware - no interrupts needed. The downside is that you need to use specific port pins.
https://www.avrfreaks.net/forum/g...
I guess a lawyer could interpret or misinterpret what point 2 says.
2. This is forum is only for questions relating to AVR Studio - problems, clarifications, bugs, etc. If your topic is a general AVR question please post it in the proper forum (ie: not this one).
oops I forgot people don't read stickies. wink
John, the question could well be deemed one about clarification of a Studio functionality.
I think that's pretty clear that it's for any questions relating to AVR (sic) Studio.
It is clear that the question here is not specific to AVR.
Moved back to Studio forum by popular demand. I will no longer do any thread moving unless someone specifically asks for a thread to be moved to a specific forum.
And let's ger rid of the the ARM studio forum, questions can be asked here.
I agree that the division into "communities" is stupid and does not serve the purpose at all.
No worries there ... !
wink
to a specific forum
Another stupid forum feature: A user can only request that a thread be moved; there is no way for a user to specify - or even suggest - where it should be moved to!
Yes there is, I asked before that a post be made in the forum that needs to be moved.
