help with raven usb stick(Target voltage outside range")
4 posts / 0 new
Hi all. I have an RZUSBSTICK which i tried to flash the new killerbee framework with avrdude. after a misspell I did to the firmware image avrdude game me reply that flashed the firmware installed but couldn't install the new one(ofc as i misspelled it, sorry i don't have screenshot) From that point light stopped working but as i saw in another thread that is probably cause there is no USB activity and I hope it's not dead. avrdude is giving me now JTAG fuse errors and I'm really anxious. So i installed ATMEL STUDIO 7 in order to install firmware and  also to try to "sense" the device to see at least if it is alive. But as you can see from the screenshot below I have an error that voltage sensed is outside limits. It is also variating a bit(0.1-0.2Volts). Any ideas??? Is it dead?
Have you done any successful programming using that connector? Did you recently install it?  Check for shorts between pins.
Have you checked the actual supply voltages on the target board?
@dak664 yes the connector has been used many times successfully.
@awneil I checked all supply voltages. First I began with 50 mil connectors pins(as i was afraid for short circuit as well) and respective output pins from mcu. All were variating from 0.8V to 0.9V.
Then I started at the USB supply(as it's a Chinese charger I don't trust either) and it was 4.8V. Then I moved according to schematics to the voltage regulator "LP2985A-33DBV" I suppose that's converting the 5V supply from USB to 3.3V. Well there I measured 1.1V-1.2V on the output. Should I assume there is the problem?
Please tell me I'm missing o a scenario where the regulator is not fried ...sad
