real time data transmission over USB by using LUFA
14 posts / 0 new
Dear Experts,
In a project I have to send near 96 KB of real time data from USB device to host computer.
I use arduino leonardo board which is based on atmega32u4  uC.
I tested different implementation of LUFA project but It seems that only AudioInput sample fits my requirements.
But my problem is that this AudioInput sample is sound card device and windows operating system changes the data based on volume setting and I do not get exactly generated data of my device.
Thus I come to the conclusion that I need a generic device (Like bulkvendor sample) which has isochronous endpoint type.
Now my problem is how to produce such a device.
And how to produce sample driver for windows 7.  (based on libusbk if possible.)
AudioInput sample does not have any distinct driver and generic sound card driver of windows is loaded for it.
Please help me.
Thanks in advance
Mehrdad,
So what does that actually mean?
How long do you have to transmit this 96 KB ?
In other words, how fast ?
If this is just about getting some bytes from one end to the other then surely just about any class of USB device could be used? Bytes are bytes are bytes - doesn't really matter what the bytes represent whether it be audio or whatever.
Hi Again
I forget to write 96 KB in a second.
Suppose that I have a Leonardo which is connected to several hardware sensor via ADC modules and each of those modules produce 8065 bytes per second and I have 12 number of those hardware modules.
Now I think it is a real time data transmission problem.
If you want to simply send data from the micro to the PC, using USB, then I'd have a look at the USB CDC, (Communications Device Class).
This Class essentially replaces the old RS-232 serial port, and is designed for bi-directional serial data transfer.
This Class also has a built in Windows driver, so you don't have to write your own Windows driver, (hard), you just open a serial Com Port, (easy).
IIRC the USB host will poll the CDC device once every one millisecond, at which time the device's buffer will upload its current data.
I don't recall the maximum buffer size for a CDC device, and I don't know how large the CDC transmit buffer is in Dean's LUFA, but if it is > 96 Bytes you are done!
Edit:Typo
Thanks DocJS
But CDC for full speed devices limits the endpoint size to 64.
In LUFA CDC sample, the size of endpoint is set to 64 also.
But I need to get a higher speed and if I can handle it then It will be possible to add more channels.
Thus getting answer from isochronous endpoints is some sort of VITAL for me.
I mixed bulk vendor and audioInput samples from LUFA project to form a device which has following spec:
0. device has only one input endpoint (address == 129)
1. Endpoint size changed to 512
2. Endpoint  type is changed to isochronous
3. Endpoint set to have 2 banks in configuration function.  (    ConfigSuccess &= Endpoint_ConfigureEndpoint(VENDOR_IN_EPADDR,  EP_TYPE_ISOCHRONOUS, VENDOR_IO_EPSIZE, 2);)
4. data is send to host in interrupt routine(exactly like AudioInput sample.)
5. driver for this device is ganerated by using zadiq 2.3 based on libusbk library and it has no problem.
http://zadig.akeo.ie/
6. By using following program I test the module and my device was enumerated and opened but problem is that I can not receive data yet.
http://libusbk.sourceforge.net/U...
As you see I have very hardworking guy.  laugh
Now Proceeding.
If you have any hints please let me know.
You know , USB is very nice invention of human  and trying to get more and more data from it is better especially in open source projects like LUFA.
BR
Mehrdad,
That doesn't matter, surely? - you just send your data in 64-byte "chunks"
FTDI seem to manage over 1 Mbps on CDC ...
USB 1.1 which is the slowest is 1.5Mb/second or 12Mb/second  Thats not fast enough to spit 96K to your host pc?
I cannot remember what speed the AVR can send sorry, but it's at least 1.5Mb/second.
JIm
64byte endpoint * 1000 1m frames per second says 64KB/s to me.
As you say if you could do 128 byte endpoints then presumably the max rate is 128KB/s
Can't help thinking you have chosen the wrong micro for the job. There must be 32 bit micros not far beyond AVR that offer a faster USB link. (and can keep the "pump primed" easier because they can process/stuff the bytes quicker)
But those are just the raw USB signalling rates - not  the achievable payload throughput rates ...
EDIT
and they are bits per second - the OP is talking bytes per second.
The Teensy 2 (mega32U4) is capable of some speed.
PJRC
C code for Teensy: USB Serial
https://www.pjrc.com/teensy/usb_serial.html
USB: Virtual Serial Port
(bottom)
Transmit Bandwidth Benchmark
Windows 7 Beta (build 7100), 32 bit; 823 kbytes/sec
Maximum Theoretical Bandwidth USB 2.0 Specification Section 5.8.4, Table 5-9, Page 54; 1056 kbytes/sec
Teensy 3 is one of many.
High-speed USB is common for those.
chipKIT is one of the Arduino compatible PIC32.
https://www.pjrc.com/teensy/index.html
chipKIT® Development Platform – Inspired by Arduino™
http://chipkit.net/
Thanks Experts,
My problem is that I designed the PCB because I thought USB speed is not an important issue then.
As I mentioned earlier this project is a real time project and I need to send 96KB/sec in current phase.
As Isochronous endpoint is designed to be used for real time application, I would rather try to use this type of endpoints and if I come to the conclusion that I could not get data by using that then I switch to CDC.
But as atmega32u4 is a full speed usb device, endpoint size limit for it is restricted to be 64 bytes max for CDC devices, thus 64KB/sec would be  achievable in CDC mode.
Thus for the sake of GOD give me some hints how to get answer from isochronus endpoint.
If I can get answer from isochronous, then I have a good hope for the future to increase the number of channels of my device from 12 to 16 or more wink
BR
Mehrdad,
Mehrdad, if your first version of the project, its software, its hardware, and the PCB all work then that is great!
For me that is often not the way things work out, even with a lot of careful thought and planning.
Sorry, I don't have any more USB suggestions to fix your current setup.
I would suggest, however, as was mentioned above, that simply adding a FTDI USB Bridge chip to your current system might be an easy, and fast, "fix" to the problem.
Route the micro's USART TxData and RxData lines to the FTDI chip and you can have fast CDC communications.
FTDI USB bridges can be purchased on small breakout boards, pre-assembled, or you can wire up your own.
As with any project, you have to decide how much time and effort to spend optimizing the solution to any problem you encounter, instead of accepting a possible, working, solution and moving forward with the rest of the project.
Thanks DocJS
I think I get answer from isochromous endpoint just by changing following codes:
1. I changed the USB endpoint size from 512 to 256, as atmega32u4 supports double buffering for only 256 byte length endpoints.
2. I removed the 'StreamingAudioInterfaceSelected' flag from the code.
Now I can read 256 bytes isochronous data from hardware.
I have not checked the values yet but as you know hardware projects always proceed step by step and my next step is to check to see if data is correct or not.
Thank you all and best wishes
Mehrdad,
