I'm having a problem with a bit of code that initialises a pointer.
478: uint16_t lRealLength = 0; +000006FB: 821C STD Y+4,R1 Store indirect with displacement +000006FC: 821B STD Y+3,R1 Store indirect with displacement 479: uint16_t lTrackLength = 1; +000006FD: E081 LDI R24,0x01 Load immediate +000006FE: E090 LDI R25,0x00 Load immediate +000006FF: 839E STD Y+6,R25 Store indirect with displacement +00000700: 838D STD Y+5,R24 Store indirect with displacement 480: uint8_t* pData = (uint8_t *)(aPacket + lTrackLength); +00000701: 812D LDD R18,Y+5 Load indirect with displacement +00000702: 813E LDD R19,Y+6 Load indirect with displacement +00000703: E08E LDI R24,0x0E Load immediate +00000704: E091 LDI R25,0x01 Load immediate +00000705: 9F28 MUL R18,R24 Multiply unsigned +00000706: 01A0 MOVW R20,R0 Copy register pair +00000707: 9F29 MUL R18,R25 Multiply unsigned +00000708: 0D50 ADD R21,R0 Add without carry +00000709: 9F38 MUL R19,R24 Multiply unsigned +0000070A: 0D50 ADD R21,R0 Add without carry +0000070B: 2411 CLR R1 Clear Register +0000070C: 019A MOVW R18,R20 Copy register pair +0000070D: 8189 LDD R24,Y+1 Load indirect with displacement +0000070E: 819A LDD R25,Y+2 Load indirect with displacement +0000070F: 0F82 ADD R24,R18 Add without carry +00000710: 1F93 ADC R25,R19 Add with carry +00000711: 8798 STD Y+8,R25 Store indirect with displacement +00000712: 838F STD Y+7,R24 Store indirect with displacement ================================================================================ 478: uint16_t lRealLength = 0; +000006FB: 821C STD Y+4,R1 Store indirect with displacement +000006FC: 821B STD Y+3,R1 Store indirect with displacement 479: uint16_t lTrackLength = 1; +000006FD: E081 LDI R24,0x01 Load immediate +000006FE: E090 LDI R25,0x00 Load immediate +000006FF: 839E STD Y+6,R25 Store indirect with displacement +00000700: 838D STD Y+5,R24 Store indirect with displacement 480: uint8_t* pData = (uint8_t *)aPacket; +00000701: 8189 LDD R24,Y+1 Load indirect with displacement +00000702: 819A LDD R25,Y+2 Load indirect with displacement +00000703: 8798 STD Y+8,R25 Store indirect with displacement +00000704: 838F STD Y+7,R24 Store indirect with displacement 481: pData += lTrackLength; +00000705: 812F LDD R18,Y+7 Load indirect with displacement +00000706: 8538 LDD R19,Y+8 Load indirect with displacement +00000707: 818D LDD R24,Y+5 Load indirect with displacement +00000708: 819E LDD R25,Y+6 Load indirect with displacement +00000709: 0F82 ADD R24,R18 Add without carry +0000070A: 1F93 ADC R25,R19 Add with carry +0000070B: 8798 STD Y+8,R25 Store indirect with displacement +0000070C: 838F STD Y+7,R24 Store indirect with displacement
Now, as far as I'm concerned pData = (uint8_t*)(aPacket + lTrackLength);
should result in the correct pointer value. The actual data is aPacket=0x015F and lTrackLength being on the stack at location 0x10F0 initialised with a value of 1. In my opinion pData should be initalised with the value 0x0160 which is aPacket + lTrackLength.
However, the result of this code, as seen above in assemler results in pData getting a value 0x02CD?
The bits that confuse me are the immediate loading and multiplies? I can't understand what they're there for.
The second section of the disassembly above works fine and does exactly what I expected the first line to do. I'm sure I've done pointer arthmitic like this before and its been fine.
Has anyone got any ideas as to whether my c statement should result okay, or can anyone decipher what the compiler is trying to do in the first case?
I'm using avr-gcc 3.4.6 and optimisation is set to 0 because I'm debugging. Any help greatly appreciated.
