Atmega328pb serial number format?
13 posts / 0 new
I'm using the unique serial numbers in the atmega328pb to identify and track our products, but there are way more bytes (10) than I really need (2-3).
Anyone know how ATMEL assigns these?  Are they just serialized (i.e. can I just use the last 3 bytes), or is there another coding they use?
My coworkers in customer service will be angry if they need customers to read 20 hexadecimal digits... so I'd like to distill this to 3 unique bytes.
(Yes, I could burn a serial number of my choosing in EEPROM, but I'd like to use the built-in one if possible.)
You could run the chip's serial number through a hash function with the appropriate length output value and use that as the ID.
What does the datasheet say?  devil
33.5. Serial Number
Each individual part has a specific serial number. This can be used to identify a specify part while it is in
the field.
The serial number consists of nine bytes which can be accessed from the signature address space.
(but that is a typo, as we see bytes 0-9 in the address chart:)
Now I have to say something useful -- I seem to recall that an early adopter played with a few, and part of the serial number appeared to be equivalent to "model number".  You'd probably need a few units, and/or 'Freaks help with their units, to confirm.
Anecdotal results here, which is probably the thread I was thinking of:
https://www.avrfreaks.net/forum/u...
Now, many of the results posted there were for Mega168PB.  Let's grab a few from that thread for discussion...
Serial Number :  0x59 0x34 0x37 0x31 0x37 0x37 0xFF 0x3 0x1C 0x16
Serial Number :  0x4A 0x39 0x33 0x34 0x33 0x30 0xFF 0x16 0x3 0x9
Serial Number :  0x6E 0x75 0x6E 0x6B 0x77 0x6F 0xFF 0x3 0x21 0x16
There w3as some discussion there about Xmega serial numbers which have die/die position info.
Look at the above:  The first 6 bytes are decodable characters.  The 7th is 0xff, and then perhaps 24 bits of "real" serial number?
Y47177 ... 203798
J93430 ... 1442569
nunkwo ... 205078   (that last one sure looks like "unknown" to me -- maybe the die info in an ES device?)
[edit] byte swap the last into 16-bit chunks and un kn ow  -- "unknow[n]"
Perhaps the last bytes also?  Dunno.
Let us say that the ATmega328PB sells in large quantities.   e.g. 1 billion.
A 4-byte binary Serial number would go up to 4 billion.
A 5-byte BCD Serial number would go up to 9,999,999,999 e.g. 10 billion
So yes,  9 bytes seems like overkill.  But hey-ho,  it is always wise to design for success.  e.g. 1000 billion.  5-byte binary or 6-byte BCD.
This thread https://www.avrfreaks.net/comment... has discussion of Tiny/AVR8/Xmega lot number decoding (as marked on the chip) and correspondence to signature row values.  Might be workth the exercise with '328PB you have in hand?
Is this different to Xmega then? In that the ID is made up of things like the manufacture year, week, wafer number, x and y position on the wafer and so on. I'm pretty sure the Xmega data explains all this. Is there some reason to assume 328pb is different in some way? (bit if an oversight if the data doesn't mimic Xmega though).
From one of the links I dug out above, it mentions Xmega is 11 bytes.  I didn't follow up, but just that would mean non-identical mapping, right?
You can probably form pairs ...maybe add bytes 0,2,4,6,8  bytes 1,3,5,7,9  bytes 0,1,4,5,8,9  bytes 2,3,6,7  bytes 0,2,5,9  now you have 40 bits of likely randomness.  Using 36 symbols (A-Z & 0-9) 40 bits can be represented by 7.74  (8)  digits of password entry.  or exactly 8 digits of a 32 symbol alphabet.
So that might tell someone who has a database of all of the bytes which unit it is (through matching).  You can't go from the 8 chars back to the 80 bits (but you can go from 80 bits in a database to 8 chars).
Or maybe you just want to punch in a code to verify that a caller's unit is "valid" (yes/no) rather than figuring out which unit it is.  That can be slightly different/easier.
Is it important to positively and uniquely identify each device, or is it enough if there is a "quite high" probability that the device is legit?
"quite high" is adequate.
Not knowing anything about the SN format, how would I choose/design a hash function that prevented collisions?
Have a read on Wikipedia on the 'Birthday Attack'; there's a useful table in there that relates hash-size to probability of a collision. Then see this thread on Stackoverflow...
http://stackoverflow.com/questio...
Perhaps a CRC-type operation?
