UART help
5 posts / 0 new
so,
here's my transmit routine..
void USART0Transmit(unsigned char data[text])			//Transmits command and speech data to TTS
	int t=0;
	while ( (t < (text + 1)) & (data[t] != 0x00) )
		while ((UCSR0A & _BV(UDRE0)) == 0);			//Waiting for empty transmit buffer
		UDR0 = data[t];
		t++;
Here is how i'm using it
USART0Transmit("XXXX");
USART0Transmit(ASCIIcode);
ASCIIcode is a chracter array
i define it as
ASCIIcode[3];
// then it gets initiallize at start up to..
ASCIIcode[0] = '1';
ASCIIcode[1] = '2';
ASCIIcode[2] = '3';
So at runtime i replace the string with random numbers (in ASCII format)..
and i run the
routine..
here's the weird thing..
so if i start it up, without changing the string, leaving it how initialize it..
everything shows up okay in hyper terminal.. i get XXX123XXX
not if i change it at run time to something random.. say..
"345"
it tends to display
XXX3455XXX
it sends the last character twice..
what's the deal.. any suggestions?
The really weird thing is...
if i change my ASCIIcode array to..
ASCIIcode[2]
and still use
ASCIIcode[3];
ASCIIcode[0] = '1';
ASCIIcode[1] = '2';
ASCIIcode[2] = '3';
and
it works perfect..
but this just doesn't make sense to me
I haven't though too much about the side effects you mention, but the way you have coded it is a little clumsy. You should read up on the use of pointers as this is what you're trying to achieve but in a round about fashion.
Your transmit routine should be declared as such:
void transmit(char *buf)
while (*buf != 0)
UDR0 = *buf++;
Some things to remember:
for an array, the array name alone is an address.
char hello_str[] = {"Hello there\n"};
transmit(hello_str); //should output the "hello there"
transmit(&hello_str[5]); //should transmit "there"
& = 'address of'
* = what is pointed to
Your double character output problem is almost certainly because you don't zero terminate the ASCIIcode string. Instead of:
ASCIIcode[3];
ASCIIcode[0] = '1';
ASCIIcode[1] = '2';
ASCIIcode[2] = '3';
you should use:
ASCIIcode[4];
ASCIIcode[0] = '1';
ASCIIcode[1] = '2';
ASCIIcode[2] = '3';
ASCIIcode[3] = 0;
The USART0Transmit() routine is looking for a 0 terminator, as it stands your code is dependent on whatever happens to be located after ASCIIcode[] in memory.
By the way, what were you hoping to achieve with the "(t < (text + 1))" part of the while() clause?
Cliff
Cliff
I'm not sure.. this is code i wrote like 2 - 3 years ago.. i was hoping to just reuse it...
I'm going to have to try what you suggested later tonight though
Thanks a million guys.. i took both of your suggestions.. and it's working fine now..
