Detect which interrupt called an ISR on ATmega
7 posts / 0 new
I want to have a single ISR handling the eight INTn external interrupts on a ATmega2560, using ISRALIASOF(INT0_vect) for INT1 to INT7.
Is there a way within the ISR to detect which input caused the interrupt? I've tried reading EIFR, but it's already cleared by the time I'm in the ISR.
Of course I could define eight ISRs all calling the same routine with a parameter 0 to 7, but that seems a bit messy.
Thanks, David
Why can't you read the PIN registers of the ext-int pins and just note which changed since last time? (which is what you do for PCINT to determine which of 8 caused it)
But why ALIASOF in the first place?
Thanks for the quick reply!
Because if it was a brief pulse and I'm detecting the rising edge it might be low again by the time I'm in the ISR.
How else would I do it without having eight ISRs?
I think you've answered your own question - if there is no mechanism to determine who interrupted, then you need 8 isrs that identify what input interrupted.
What exactly is wrong with 8 ISR() s?
If this is about maintaining 8 copies of almost identical code then put the common bits into an "__attribute__((always_inline)) static inline" function and invoke that from each.
OK, thanks. I'll try that out.
David
+1.
As Cliff mentioned, the common core code can be isolated, and invoked with "inline" routine or [gasp] goto.
There are other esoteric ways.  For example, if you keep the ISR code close enough to the vector table to be reached with RJMP then you can LDI a flag value in the other vector word.
