Updating RTC at every 24hours
5 posts / 0 new
Hi all,
I have a project I am using RTC and GSM interfaced. I need to update RTC time by getting GSM time at every 24hour (Say at 12AM). In the sense when date changes I have to update my RTC Time.
What method can I use?
I am using Atmega164A, GSM900A,
Please help me in this.
Thank you In advance.
SNAP!
My Google was "get network time using sim900" and that thread was the top hit for that too :-)
The same search hit a load of useful looking threads. A brief summary is given in this:
https://importgeek.wordpress.com...
So the bottom line of it all:
AT+CCLK?
I would suggest sync'ing your time shortly after 2 am, that way you will also automagicly adjust for standard/daylight savings as well as correcting for any clock drift.
AT+CCLK?
Not sure I trust that.
AT+CCLK is a GSM 07.07 Standard command: it usually relates to the module's local RTC - not the Network time.
The Blog refers to using AT+CENG to turn on "Engineering Mode". The SIM900_AT Command Manual_V1.11.pdf says nothing to indicate that this sets the RTC
http://simcom.ee/documents/?dir=...
But one thing is certain: it has nothing specifically to do with AVR.
