Pointer increament
5 posts / 0 new
I am using a pointer function to save three 32 bit variables value in to 3 memory location of a 32 bit controller..the following are the instruction i used
declared status_0,status_1,status_2 gloably
int*block0=(int*)0x00800000;
*block0=status_s0;
int*block1=(int*)0x00800001;
*block1=status_s1;
int*block2=(int*)0x00800002;
*block2=status_s2;
I want to know the method i used is right or wrong and there is any other way to do this by increment the pointer and how it do...i need your valuable suggestions..thank you very much
int *block = (int*)0x00800000;
*block=status_s0;
block++;
*block=status_s1;
block++;
*block=status_s2;
The memory address is in bytes, so your code will not work as you expect. If your addresses were
8000000
8000004
8000008
Then it would work as expected.
Note:you are using pointers, not pointer functions.
Thank you sir,, thanks for your reply
Why on earth don't you just declare:
Int *block = (int *) 0x80000000;
then:
block[0] = status_s0;
block[1] = status_s1;
etc.
extern int blocks[3];
Assign the symbol blocks with the linker.
