How can I Blinking LED without using delay?
14 posts / 0 new
My previous code I use delay to turn ON and turn OFF my LED to make it blink by using delay.
As we know (for the expert in AVR), the delay will use lot of cycles rather than we use Timer.
I have problem to make the LED blinking with Timer.
Im using ATMEGA256rfr2.
Thank you in advance.
Here my code:
	DDRB |= (1<<PINB4);
	TCCR1A = 0x00;
	TCCR1B |= (1<<CS11) |(1<<CS10);
	TCCR1B = 0x00;
    while (1)
		if (TIFR0 & (1<<TOV1))
			TIFR0 |= (1<<TOV1);
			PORTB ^= (1<<PINB4);
	TCCR1B = 0x00;
This stops the timer.
This LED will toggle from 0 to 1 only?
Or it will continuous blinking?
The ^ operator means 'exclusive or'.  The effect is that if the bit was 1 it will be changed to 0, and if it was 0 it will be changed to 1.  So each time that statement is executed, the bit will toggle.
WHY would you use an AVR with RF communications capabilities to learn programming on?  Did you get the XPRO kit as a gift?
I am going to parrot what others have said in the past to others....Get an Arduino UNO and learn to crawl and walk on that before you try and run.
EDIT: Changed Kit Name
I already run the code but the LED is not blinking at all.
I try this code in actual board ATMEGA256RFR2.
kyrul wrote:
Here my code:
	DDRB |= (1<<PINB4);
	TCCR1A = 0x00;
	TCCR1B = 0x00;
    while (1)
			TIFR0 |= (1<<TOV1);
As joeymorin said, you're stopping the timer. Could you have meant to write TCCR1C = 0x00.
But you have another problem, you are checking if Timer0 has overflowed instead of Timer1. Use TIFR1 instead of TIFR0 and you will find your LED will blink on/off roughly every second if you are using an 8MHz clock.
Cheers
jgmdesign wrote:
WHY would you use an AVR with RF communications capabilities to learn programming on?  Did you get the XPLAIN kit as a gift?
Actually i only have this ATMEGA256rfr2.
Is it Arduino programming same as Atmel Studio?
I really don't see what difference it makes what device you get and to be honest, kyrul is pretty much learning to crawl with the simple blink program he is uploading to the uC. It isn't as if he is developing a sprinkler control system that wirelessly communicates with his home PC to set time schedules on his first run wink
His only problems that I could see was a few typos in the register names. After he sorts that out, his LED should be blinking in no time at all.
Cheers
Cheers
Thank you adam3141.
Cheers
Yeah you are correct adam3141. Please keep teaching me on this AVR stuff.
I just started learned it last Monday.
Thank you so much guys.
Agreed, but my poorly worded comment was asking why go with such a complicated device to begin with.  You are correct in that one can certainly use the RFR2, its more common though for beginners to simply pick up a $3.00 UNO clone on ebay and get going.
Maybe the RFR2 was a gift. Cheaper than a "$3.00 UNO clone on ebay". laugh
I mentioned that in my post.
ALL
Lets not derail this thread over my comment about the development kit, it serves no purpose whatsoever.  The OP answered my post, leave it at that. - JIM
