Solved: ATmega 162 - USART using AVRStudio 4
3 posts / 0 new
Hi all
I tried to use USART (0 or 1) in ATmega 162 but I can't do it right sad
#define USART_BAUDRATE 9600
#define BAUD_PRESCALE (((F_CPU / (USART_BAUDRATE * 16UL))) - 1)
UCSR0A = 0x00;
UCSR0C |= (1<<URSEL0)|(1<<UCSZ00)|(1<<UCSZ01); // 8 N 1
UBRR0L |= (uint8_t)BAUD_PRESCALE;	       // baud rate lo_byte
UBRR0H |= (uint8_t)(BAUD_PRESCALE>>8);         // baud rate hi_byte
UCSR0B |= (1<<TXEN0);       	               // Enable usart TX
 unsigned char data=0;
  while(!(UCSR0A & (1 << UDRE0)));
  UDR0 = data++;
With the code above I can get correct value only if I set the Rx device / Terminal Baudrate to 1200 not 9600 as expected.
I changed the MCU with ATmega16 or ATmega32 with above setting and I had no problem.
Can someone help me ?
What did I miss ?
Thank you
Which tells you that the AVR is running 8 times slower than you think.
Does the 162 have a "CKDIV8" fuse by any chance?
EDIT: well yes it does....
That would be the first culprit I would be looking at!
AVRs that have CKDIV8 fuses have them activated by default so whatever clock you select it will run at 1/8th the speed.
You can either change the fuse or do the double write to CLKPR in your code to change the divisor back to divide by 1.
Hi Clawson
Thanks a lot for your quick answer yes
That's my stupid mistake ! sadno
CKDIV8 and CLKPR solved the problem! yes
Thank you very much sir smiley
