Solved: SSD1306 i2c with ATmega328 (How to display lines of text?)
10 posts / 0 new
As the title shows, I am working on a project that involves me displaying information on a screen, such as Location and temperature data. My goal is to have text data displayed like "LOCATION: ..." and such.
I am using an ATmega and Adafruit's ssd1306 128x64 display (communicating via i2c). I have been successful with initializing the display, but have had some trouble with getting actual text characters to be written to the display.
At the moment I am just using a global buffer which is temporarily storing the hex values that display the Adafruit logo. I want to find out how to properly store the text data in the buffer and how I can actually write actual characters to the screen. At the moment I am able to just alter sets of pixels and clear the display, but I have yet to find out how to properly get characters and lines of text to appear.
I've attached an image of code that I have tried, but have found it to not be quite what I want in terms of trying to display text.
Does anyone have any suggestions. Thanks
*Note: I am writing all of my code in C.
Surely, Adafruit must have examples of how to do this?!
Posting code as an image attachment is a really unfriendly way to do it!
surprise
It's text - just copy & paste it!!
Use the 'Add Codebutton to insert properly-formatted code into your posts:
Instructions here: https://www.avrfreaks.net/wiki/ad...
EDIT
And, for completeness, here are the instructions for putting an image in a post (like the above screenshot):
https://www.avrfreaks.net/wiki/em...
EDIT 2
It seems that the toolbar - and, thus, the 'Add Code' button - is not available on the mobile version of this site!
So, if you need to include source code in your post, you have to do it from a PC or similar.
See: https://www.avrfreaks.net/comment...
#AddCode
#PostImageAndCode
Go on. The Adafruit library is designed for the Arduino. The print methods inherit from the Print C++ class. The graphics from the Adafruit_GFX class.
All that you see in the Adafruit_SSD1306 library is how to set and clear pixels. You can see how to render a single letter from a Font. And then you have the basics.
e.g. print a string is just a sequence of letters.
e.g. print a number is sprintf(buf, "%d", number) followed by printing the resultant string.
Life would be a lot simpler if you used C++ and the existing libraries.
Indeed.
But it's not like the ssd1306 is a new or unusual chip that nobody's ever used before - is it?
There is plenty of prior art:
http://www.lmgtfy.com?q=avr+ssd1306+text
A character such as 'A' or 'w' or whatever is nothing more than a "logo" that just happens to be only 8x8 pixels in size (or whatever your chosen display size is).
The only tricky bits in writing text are (a) defining all the little 8x8 patterns that make up 'A', 'B', 'C', etc and (b) moving the x,y location where you use the equivalent of drawBuffer() to the right spot for the "next" character to be output. If the font really is 8x8 and all the characters are the same width (fixed pitch) then it should be as simple as "x=x+8" and at the end of the lines x=0;y=y+8
So thats what is showing up now on my display. A bunch of nonsense.
I can easily clear the screen and make it all black or white, but still having a hard time with writing strings. I found some C++ code and stripped away the classes to create C code. I assuming that my issue comes down to my DisplayFonts.h library and my functions for writing the strings ( drawInternal() and drawStringInternal() )
This is the font library...
#ifndef OLEDDISPLAYFONTS_h
#define OLEDDISPLAYFONTS_h
const char ArialMT_Plain_10[] = {
  0x0A, // Width: 10
  0x0D, // Height: 13
  0x20, // First Char: 32
  0xE0, // Numbers of Chars: 224
  // Jump Table:
  0xFF, 0xFF, 0x00, 0x03,  // 32:65535
  0x00, 0x00, 0x04, 0x03,  // 33:0
  0x00, 0x04, 0x05, 0x04,  // 34:4
  0x00, 0x09, 0x09, 0x06,  // 35:9
  0x00, 0x12, 0x0A, 0x06,  // 36:18
  0x00, 0x1C, 0x10, 0x09,  // 37:28
  0x00, 0x2C, 0x0E, 0x07,  // 38:44
  0x00, 0x3A, 0x01, 0x02,  // 39:58
  0x00, 0x3B, 0x06, 0x03,  // 40:59
  0x00, 0x41, 0x06, 0x03,  // 41:65
  0x00, 0x47, 0x05, 0x04,  // 42:71
  0x00, 0x4C, 0x09, 0x06,  // 43:76
  0x00, 0x55, 0x04, 0x03,  // 44:85
  0x00, 0x59, 0x03, 0x03,  // 45:89
  0x00, 0x5C, 0x04, 0x03,  // 46:92
  0x00, 0x60, 0x05, 0x03,  // 47:96
  0x00, 0x65, 0x0A, 0x06,  // 48:101
  0x00, 0x6F, 0x08, 0x06,  // 49:111
  0x00, 0x77, 0x0A, 0x06,  // 50:119
  0x00, 0x81, 0x0A, 0x06,  // 51:129
  0x00, 0x8B, 0x0B, 0x06,  // 52:139
  0x00, 0x96, 0x0A, 0x06,  // 53:150
  0x00, 0xA0, 0x0A, 0x06,  // 54:160
  0x00, 0xAA, 0x09, 0x06,  // 55:170
  0x00, 0xB3, 0x0A, 0x06,  // 56:179
  0x00, 0xBD, 0x0A, 0x06,  // 57:189
  0x00, 0xC7, 0x04, 0x03,  // 58:199
  0x00, 0xCB, 0x04, 0x03,  // 59:203
  0x00, 0xCF, 0x0A, 0x06,  // 60:207
  0x00, 0xD9, 0x09, 0x06,  // 61:217
  0x00, 0xE2, 0x09, 0x06,  // 62:226
  0x00, 0xEB, 0x0B, 0x06,  // 63:235
  0x00, 0xF6, 0x14, 0x0A,  // 64:246
  0x01, 0x0A, 0x0E, 0x07,  // 65:266
  0x01, 0x18, 0x0C, 0x07,  // 66:280
  0x01, 0x24, 0x0C, 0x07,  // 67:292
  0x01, 0x30, 0x0B, 0x07,  // 68:304
  0x01, 0x3B, 0x0C, 0x07,  // 69:315
  0x01, 0x47, 0x09, 0x06,  // 70:327
  0x01, 0x50, 0x0D, 0x08,  // 71:336
  0x01, 0x5D, 0x0C, 0x07,  // 72:349
  0x01, 0x69, 0x04, 0x03,  // 73:361
  0x01, 0x6D, 0x08, 0x05,  // 74:365
  0x01, 0x75, 0x0E, 0x07,  // 75:373
  0x01, 0x83, 0x0C, 0x06,  // 76:387
  0x01, 0x8F, 0x10, 0x08,  // 77:399
  0x01, 0x9F, 0x0C, 0x07,  // 78:415
  0x01, 0xAB, 0x0E, 0x08,  // 79:427
  0x01, 0xB9, 0x0B, 0x07,  // 80:441
  0x01, 0xC4, 0x0E, 0x08,  // 81:452
  0x01, 0xD2, 0x0C, 0x07,  // 82:466
  0x01, 0xDE, 0x0C, 0x07,  // 83:478
  0x01, 0xEA, 0x0B, 0x06,  // 84:490
  0x01, 0xF5, 0x0C, 0x07,  // 85:501
  0x02, 0x01, 0x0D, 0x07,  // 86:513
  0x02, 0x0E, 0x11, 0x09,  // 87:526
  0x02, 0x1F, 0x0E, 0x07,  // 88:543
  0x02, 0x2D, 0x0D, 0x07,  // 89:557
  0x02, 0x3A, 0x0C, 0x06,  // 90:570
  0x02, 0x46, 0x06, 0x03,  // 91:582
  0x02, 0x4C, 0x06, 0x03,  // 92:588
  0x02, 0x52, 0x04, 0x03,  // 93:594
  0x02, 0x56, 0x09, 0x05,  // 94:598
  0x02, 0x5F, 0x0C, 0x06,  // 95:607
  0x02, 0x6B, 0x03, 0x03,  // 96:619
  0x02, 0x6E, 0x0A, 0x06,  // 97:622
  0x02, 0x78, 0x0A, 0x06,  // 98:632
  0x02, 0x82, 0x0A, 0x05,  // 99:642
  0x02, 0x8C, 0x0A, 0x06,  // 100:652
  0x02, 0x96, 0x0A, 0x06,  // 101:662
  0x02, 0xA0, 0x05, 0x03,  // 102:672
  0x02, 0xA5, 0x0A, 0x06,  // 103:677
  0x02, 0xAF, 0x0A, 0x06,  // 104:687
  0x02, 0xB9, 0x04, 0x02,  // 105:697
  0x02, 0xBD, 0x04, 0x02,  // 106:701
  0x02, 0xC1, 0x08, 0x05,  // 107:705
  0x02, 0xC9, 0x04, 0x02,  // 108:713
  0x02, 0xCD, 0x10, 0x08,  // 109:717
  0x02, 0xDD, 0x0A, 0x06,  // 110:733
  0x02, 0xE7, 0x0A, 0x06,  // 111:743
  0x02, 0xF1, 0x0A, 0x06,  // 112:753
  0x02, 0xFB, 0x0A, 0x06,  // 113:763
  0x03, 0x05, 0x05, 0x03,  // 114:773
  0x03, 0x0A, 0x08, 0x05,  // 115:778
  0x03, 0x12, 0x06, 0x03,  // 116:786
  0x03, 0x18, 0x0A, 0x06,  // 117:792
  0x03, 0x22, 0x09, 0x05,  // 118:802
  0x03, 0x2B, 0x0E, 0x07,  // 119:811
  0x03, 0x39, 0x0A, 0x05,  // 120:825
  0x03, 0x43, 0x09, 0x05,  // 121:835
  0x03, 0x4C, 0x0A, 0x05,  // 122:844
  0x03, 0x56, 0x06, 0x03,  // 123:854
  0x03, 0x5C, 0x04, 0x03,  // 124:860
  0x03, 0x60, 0x05, 0x03,  // 125:864
  0x03, 0x65, 0x09, 0x06,  // 126:869
  0xFF, 0xFF, 0x00, 0x00,  // 127:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 128:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 129:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 130:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 131:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 132:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 133:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 134:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 135:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 136:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 137:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 138:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 139:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 140:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 141:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 142:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 143:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 144:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 145:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 146:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 147:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 148:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 149:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 150:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 151:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 152:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 153:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 154:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 155:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 156:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 157:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 158:65535
  0xFF, 0xFF, 0x00, 0x0A,  // 159:65535
  0xFF, 0xFF, 0x00, 0x03,  // 160:65535
  0x03, 0x6E, 0x04, 0x03,  // 161:878
  0x03, 0x72, 0x0A, 0x06,  // 162:882
  0x03, 0x7C, 0x0C, 0x06,  // 163:892
  0x03, 0x88, 0x0A, 0x06,  // 164:904
  0x03, 0x92, 0x0A, 0x06,  // 165:914
  0x03, 0x9C, 0x04, 0x03,  // 166:924
  0x03, 0xA0, 0x0A, 0x06,  // 167:928
  0x03, 0xAA, 0x05, 0x03,  // 168:938
  0x03, 0xAF, 0x0D, 0x07,  // 169:943
  0x03, 0xBC, 0x07, 0x04,  // 170:956
  0x03, 0xC3, 0x0A, 0x06,  // 171:963
  0x03, 0xCD, 0x09, 0x06,  // 172:973
  0x03, 0xD6, 0x03, 0x03,  // 173:982
  0x03, 0xD9, 0x0D, 0x07,  // 174:985
  0x03, 0xE6, 0x0B, 0x06,  // 175:998
  0x03, 0xF1, 0x07, 0x04,  // 176:1009
  0x03, 0xF8, 0x0A, 0x05,  // 177:1016
  0x04, 0x02, 0x05, 0x03,  // 178:1026
  0x04, 0x07, 0x05, 0x03,  // 179:1031
  0x04, 0x0C, 0x05, 0x03,  // 180:1036
  0x04, 0x11, 0x0A, 0x06,  // 181:1041
  0x04, 0x1B, 0x09, 0x05,  // 182:1051
  0x04, 0x24, 0x03, 0x03,  // 183:1060
  0x04, 0x27, 0x06, 0x03,  // 184:1063
  0x04, 0x2D, 0x05, 0x03,  // 185:1069
  0x04, 0x32, 0x07, 0x04,  // 186:1074
  0x04, 0x39, 0x0A, 0x06,  // 187:1081
  0x04, 0x43, 0x10, 0x08,  // 188:1091
  0x04, 0x53, 0x10, 0x08,  // 189:1107
  0x04, 0x63, 0x10, 0x08,  // 190:1123
  0x04, 0x73, 0x0A, 0x06,  // 191:1139
  0x04, 0x7D, 0x0E, 0x07,  // 192:1149
  0x04, 0x8B, 0x0E, 0x07,  // 193:1163
  0x04, 0x99, 0x0E, 0x07,  // 194:1177
  0x04, 0xA7, 0x0E, 0x07,  // 195:1191
  0x04, 0xB5, 0x0E, 0x07,  // 196:1205
  0x04, 0xC3, 0x0E, 0x07,  // 197:1219
  0x04, 0xD1, 0x12, 0x0A,  // 198:1233
  0x04, 0xE3, 0x0C, 0x07,  // 199:1251
  0x04, 0xEF, 0x0C, 0x07,  // 200:1263
  0x04, 0xFB, 0x0C, 0x07,  // 201:1275
  0x05, 0x07, 0x0C, 0x07,  // 202:1287
  0x05, 0x13, 0x0C, 0x07,  // 203:1299
  0x05, 0x1F, 0x05, 0x03,  // 204:1311
  0x05, 0x24, 0x04, 0x03,  // 205:1316
  0x05, 0x28, 0x04, 0x03,  // 206:1320
  0x05, 0x2C, 0x05, 0x03,  // 207:1324
  0x05, 0x31, 0x0B, 0x07,  // 208:1329
  0x05, 0x3C, 0x0C, 0x07,  // 209:1340
  0x05, 0x48, 0x0E, 0x08,  // 210:1352
  0x05, 0x56, 0x0E, 0x08,  // 211:1366
  0x05, 0x64, 0x0E, 0x08,  // 212:1380
  0x05, 0x72, 0x0E, 0x08,  // 213:1394
  0x05, 0x80, 0x0E, 0x08,  // 214:1408
  0x05, 0x8E, 0x0A, 0x06,  // 215:1422
  0x05, 0x98, 0x0D, 0x08,  // 216:1432
  0x05, 0xA5, 0x0C, 0x07,  // 217:1445
  0x05, 0xB1, 0x0C, 0x07,  // 218:1457
  0x05, 0xBD, 0x0C, 0x07,  // 219:1469
  0x05, 0xC9, 0x0C, 0x07,  // 220:1481
  0x05, 0xD5, 0x0D, 0x07,  // 221:1493
  0x05, 0xE2, 0x0B, 0x07,  // 222:1506
  0x05, 0xED, 0x0C, 0x06,  // 223:1517
  0x05, 0xF9, 0x0A, 0x06,  // 224:1529
  0x06, 0x03, 0x0A, 0x06,  // 225:1539
  0x06, 0x0D, 0x0A, 0x06,  // 226:1549
  0x06, 0x17, 0x0A, 0x06,  // 227:1559
  0x06, 0x21, 0x0A, 0x06,  // 228:1569
  0x06, 0x2B, 0x0A, 0x06,  // 229:1579
  0x06, 0x35, 0x10, 0x09,  // 230:1589
  0x06, 0x45, 0x0A, 0x05,  // 231:1605
  0x06, 0x4F, 0x0A, 0x06,  // 232:1615
  0x06, 0x59, 0x0A, 0x06,  // 233:1625
  0x06, 0x63, 0x0A, 0x06,  // 234:1635
  0x06, 0x6D, 0x0A, 0x06,  // 235:1645
  0x06, 0x77, 0x05, 0x03,  // 236:1655
  0x06, 0x7C, 0x04, 0x03,  // 237:1660
  0x06, 0x80, 0x05, 0x03,  // 238:1664
  0x06, 0x85, 0x05, 0x03,  // 239:1669
  0x06, 0x8A, 0x0A, 0x06,  // 240:1674
  0x06, 0x94, 0x0A, 0x06,  // 241:1684
  0x06, 0x9E, 0x0A, 0x06,  // 242:1694
  0x06, 0xA8, 0x0A, 0x06,  // 243:1704
  0x06, 0xB2, 0x0A, 0x06,  // 244:1714
  0x06, 0xBC, 0x0A, 0x06,  // 245:1724
  0x06, 0xC6, 0x0A, 0x06,  // 246:1734
  0x06, 0xD0, 0x09, 0x05,  // 247:1744
  0x06, 0xD9, 0x0A, 0x06,  // 248:1753
  0x06, 0xE3, 0x0A, 0x06,  // 249:1763
  0x06, 0xED, 0x0A, 0x06,  // 250:1773
  0x06, 0xF7, 0x0A, 0x06,  // 251:1783
  0x07, 0x01, 0x0A, 0x06,  // 252:1793
  0x07, 0x0B, 0x09, 0x05,  // 253:1803
  0x07, 0x14, 0x0A, 0x06,  // 254:1812
  0x07, 0x1E, 0x09, 0x05,  // 255:1822
  // Font Data:
  0x00,0x00,0xF8,0x02,  // 33
  0x38,0x00,0x00,0x00,0x38, // 34
  0xA0,0x03,0xE0,0x00,0xB8,0x03,0xE0,0x00,0xB8, // 35
  0x30,0x01,0x28,0x02,0xF8,0x07,0x48,0x02,0x90,0x01,  // 36
  0x00,0x00,0x30,0x00,0x48,0x00,0x30,0x03,0xC0,0x00,0xB0,0x01,0x48,0x02,0x80,0x01,  // 37
  0x80,0x01,0x50,0x02,0x68,0x02,0xA8,0x02,0x18,0x01,0x80,0x03,0x80,0x02,  // 38
  0x38, // 39
  0xE0,0x03,0x10,0x04,0x08,0x08,  // 40
  0x08,0x08,0x10,0x04,0xE0,0x03,  // 41
  0x28,0x00,0x18,0x00,0x28, // 42
  0x40,0x00,0x40,0x00,0xF0,0x01,0x40,0x00,0x40, // 43
  0x00,0x00,0x00,0x06,  // 44
  0x80,0x00,0x80, // 45
  0x00,0x00,0x00,0x02,  // 46
  0x00,0x03,0xE0,0x00,0x18, // 47
  0xF0,0x01,0x08,0x02,0x08,0x02,0x08,0x02,0xF0,0x01,  // 48
  0x00,0x00,0x20,0x00,0x10,0x00,0xF8,0x03,  // 49
  0x10,0x02,0x08,0x03,0x88,0x02,0x48,0x02,0x30,0x02,  // 50
  0x10,0x01,0x08,0x02,0x48,0x02,0x48,0x02,0xB0,0x01,  // 51
  0xC0,0x00,0xA0,0x00,0x90,0x00,0x88,0x00,0xF8,0x03,0x80, // 52
  0x60,0x01,0x38,0x02,0x28,0x02,0x28,0x02,0xC8,0x01,  // 53
  0xF0,0x01,0x28,0x02,0x28,0x02,0x28,0x02,0xD0,0x01,  // 54
  0x08,0x00,0x08,0x03,0xC8,0x00,0x38,0x00,0x08, // 55
  0xB0,0x01,0x48,0x02,0x48,0x02,0x48,0x02,0xB0,0x01,  // 56
  0x70,0x01,0x88,0x02,0x88,0x02,0x88,0x02,0xF0,0x01,  // 57
  0x00,0x00,0x20,0x02,  // 58
  0x00,0x00,0x20,0x06,  // 59
  0x00,0x00,0x40,0x00,0xA0,0x00,0xA0,0x00,0x10,0x01,  // 60
  0xA0,0x00,0xA0,0x00,0xA0,0x00,0xA0,0x00,0xA0, // 61
  0x00,0x00,0x10,0x01,0xA0,0x00,0xA0,0x00,0x40, // 62
  0x10,0x00,0x08,0x00,0x08,0x00,0xC8,0x02,0x48,0x00,0x30, // 63
  0x00,0x00,0xC0,0x03,0x30,0x04,0xD0,0x09,0x28,0x0A,0x28,0x0A,0xC8,0x0B,0x68,0x0A,0x10,0x05,0xE0,0x04,  // 64
  0x00,0x02,0xC0,0x01,0xB0,0x00,0x88,0x00,0xB0,0x00,0xC0,0x01,0x00,0x02,  // 65
  0x00,0x00,0xF8,0x03,0x48,0x02,0x48,0x02,0x48,0x02,0xF0,0x01,  // 66
  0x00,0x00,0xF0,0x01,0x08,0x02,0x08,0x02,0x08,0x02,0x10,0x01,  // 67
  0x00,0x00,0xF8,0x03,0x08,0x02,0x08,0x02,0x10,0x01,0xE0, // 68
  0x00,0x00,0xF8,0x03,0x48,0x02,0x48,0x02,0x48,0x02,0x48,0x02,  // 69
  0x00,0x00,0xF8,0x03,0x48,0x00,0x48,0x00,0x08, // 70
  0x00,0x00,0xE0,0x00,0x10,0x01,0x08,0x02,0x48,0x02,0x50,0x01,0xC0, // 71
  0x00,0x00,0xF8,0x03,0x40,0x00,0x40,0x00,0x40,0x00,0xF8,0x03,  // 72
  0x00,0x00,0xF8,0x03,  // 73
  0x00,0x03,0x00,0x02,0x00,0x02,0xF8,0x01,  // 74
  0x00,0x00,0xF8,0x03,0x80,0x00,0x60,0x00,0x90,0x00,0x08,0x01,0x00,0x02,  // 75
  0x00,0x00,0xF8,0x03,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,  // 76
  0x00,0x00,0xF8,0x03,0x30,0x00,0xC0,0x01,0x00,0x02,0xC0,0x01,0x30,0x00,0xF8,0x03,  // 77
  0x00,0x00,0xF8,0x03,0x30,0x00,0x40,0x00,0x80,0x01,0xF8,0x03,  // 78
  0x00,0x00,0xF0,0x01,0x08,0x02,0x08,0x02,0x08,0x02,0x08,0x02,0xF0,0x01,  // 79
  0x00,0x00,0xF8,0x03,0x48,0x00,0x48,0x00,0x48,0x00,0x30, // 80
  0x00,0x00,0xF0,0x01,0x08,0x02,0x08,0x02,0x08,0x03,0x08,0x03,0xF0,0x02,  // 81
  0x00,0x00,0xF8,0x03,0x48,0x00,0x48,0x00,0xC8,0x00,0x30,0x03,  // 82
  0x00,0x00,0x30,0x01,0x48,0x02,0x48,0x02,0x48,0x02,0x90,0x01,  // 83
  0x00,0x00,0x08,0x00,0x08,0x00,0xF8,0x03,0x08,0x00,0x08, // 84
  0x00,0x00,0xF8,0x01,0x00,0x02,0x00,0x02,0x00,0x02,0xF8,0x01,  // 85
  0x08,0x00,0x70,0x00,0x80,0x01,0x00,0x02,0x80,0x01,0x70,0x00,0x08, // 86
  0x18,0x00,0xE0,0x01,0x00,0x02,0xF0,0x01,0x08,0x00,0xF0,0x01,0x00,0x02,0xE0,0x01,0x18, // 87
  0x00,0x02,0x08,0x01,0x90,0x00,0x60,0x00,0x90,0x00,0x08,0x01,0x00,0x02,  // 88
  0x08,0x00,0x10,0x00,0x20,0x00,0xC0,0x03,0x20,0x00,0x10,0x00,0x08, // 89
  0x08,0x03,0x88,0x02,0xC8,0x02,0x68,0x02,0x38,0x02,0x18,0x02,  // 90
  0x00,0x00,0xF8,0x0F,0x08,0x08,  // 91
  0x18,0x00,0xE0,0x00,0x00,0x03,  // 92
  0x08,0x08,0xF8,0x0F,  // 93
  0x40,0x00,0x30,0x00,0x08,0x00,0x30,0x00,0x40, // 94
  0x00,0x08,0x00,0x08,0x00,0x08,0x00,0x08,0x00,0x08,0x00,0x08,  // 95
  0x08,0x00,0x10, // 96
  0x00,0x00,0x00,0x03,0xA0,0x02,0xA0,0x02,0xE0,0x03,  // 97
  0x00,0x00,0xF8,0x03,0x20,0x02,0x20,0x02,0xC0,0x01,  // 98
  0x00,0x00,0xC0,0x01,0x20,0x02,0x20,0x02,0x40,0x01,  // 99
  0x00,0x00,0xC0,0x01,0x20,0x02,0x20,0x02,0xF8,0x03,  // 100
  0x00,0x00,0xC0,0x01,0xA0,0x02,0xA0,0x02,0xC0,0x02,  // 101
  0x20,0x00,0xF0,0x03,0x28, // 102
  0x00,0x00,0xC0,0x05,0x20,0x0A,0x20,0x0A,0xE0,0x07,  // 103
  0x00,0x00,0xF8,0x03,0x20,0x00,0x20,0x00,0xC0,0x03,  // 104
  0x00,0x00,0xE8,0x03,  // 105
  0x00,0x08,0xE8,0x07,  // 106
  0xF8,0x03,0x80,0x00,0xC0,0x01,0x20,0x02,  // 107
  0x00,0x00,0xF8,0x03,  // 108
  0x00,0x00,0xE0,0x03,0x20,0x00,0x20,0x00,0xE0,0x03,0x20,0x00,0x20,0x00,0xC0,0x03,  // 109
  0x00,0x00,0xE0,0x03,0x20,0x00,0x20,0x00,0xC0,0x03,  // 110
  0x00,0x00,0xC0,0x01,0x20,0x02,0x20,0x02,0xC0,0x01,  // 111
  0x00,0x00,0xE0,0x0F,0x20,0x02,0x20,0x02,0xC0,0x01,  // 112
  0x00,0x00,0xC0,0x01,0x20,0x02,0x20,0x02,0xE0,0x0F,  // 113
  0x00,0x00,0xE0,0x03,0x20, // 114
  0x40,0x02,0xA0,0x02,0xA0,0x02,0x20,0x01,  // 115
  0x20,0x00,0xF8,0x03,0x20,0x02,  // 116
  0x00,0x00,0xE0,0x01,0x00,0x02,0x00,0x02,0xE0,0x03,  // 117
  0x20,0x00,0xC0,0x01,0x00,0x02,0xC0,0x01,0x20, // 118
  0xE0,0x01,0x00,0x02,0xC0,0x01,0x20,0x00,0xC0,0x01,0x00,0x02,0xE0,0x01,  // 119
  0x20,0x02,0x40,0x01,0x80,0x00,0x40,0x01,0x20,0x02,  // 120
  0x20,0x00,0xC0,0x09,0x00,0x06,0xC0,0x01,0x20, // 121
  0x20,0x02,0x20,0x03,0xA0,0x02,0x60,0x02,0x20,0x02,  // 122
  0x80,0x00,0x78,0x0F,0x08,0x08,  // 123
  0x00,0x00,0xF8,0x0F,  // 124
  0x08,0x08,0x78,0x0F,0x80, // 125
  0xC0,0x00,0x40,0x00,0xC0,0x00,0x80,0x00,0xC0, // 126
  0x00,0x00,0xA0,0x0F,  // 161
  0x00,0x00,0xC0,0x01,0xA0,0x0F,0x78,0x02,0x40,0x01,  // 162
  0x40,0x02,0x70,0x03,0xC8,0x02,0x48,0x02,0x08,0x02,0x10,0x02,  // 163
  0x00,0x00,0xE0,0x01,0x20,0x01,0x20,0x01,0xE0,0x01,  // 164
  0x48,0x01,0x70,0x01,0xC0,0x03,0x70,0x01,0x48,0x01,  // 165
  0x00,0x00,0x38,0x0F,  // 166
  0xD0,0x04,0x28,0x09,0x48,0x09,0x48,0x0A,0x90,0x05,  // 167
  0x08,0x00,0x00,0x00,0x08, // 168
  0xE0,0x00,0x10,0x01,0x48,0x02,0xA8,0x02,0xA8,0x02,0x10,0x01,0xE0, // 169
  0x68,0x00,0x68,0x00,0x68,0x00,0x78, // 170
  0x00,0x00,0x80,0x01,0x40,0x02,0x80,0x01,0x40,0x02,  // 171
  0x20,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0xE0, // 172
  0x80,0x00,0x80, // 173
  0xE0,0x00,0x10,0x01,0xE8,0x02,0x68,0x02,0xC8,0x02,0x10,0x01,0xE0, // 174
  0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02, // 175
  0x00,0x00,0x38,0x00,0x28,0x00,0x38, // 176
  0x40,0x02,0x40,0x02,0xF0,0x03,0x40,0x02,0x40,0x02,  // 177
  0x48,0x00,0x68,0x00,0x58, // 178
  0x48,0x00,0x58,0x00,0x68, // 179
  0x00,0x00,0x10,0x00,0x08, // 180
  0x00,0x00,0xE0,0x0F,0x00,0x02,0x00,0x02,0xE0,0x03,  // 181
  0x70,0x00,0xF8,0x0F,0x08,0x00,0xF8,0x0F,0x08, // 182
  0x00,0x00,0x40, // 183
  0x00,0x00,0x00,0x14,0x00,0x18,  // 184
  0x00,0x00,0x10,0x00,0x78, // 185
  0x30,0x00,0x48,0x00,0x48,0x00,0x30, // 186
  0x00,0x00,0x40,0x02,0x80,0x01,0x40,0x02,0x80,0x01,  // 187
  0x00,0x00,0x10,0x02,0x78,0x01,0xC0,0x00,0x20,0x01,0x90,0x01,0xC8,0x03,0x00,0x01,  // 188
  0x00,0x00,0x10,0x02,0x78,0x01,0x80,0x00,0x60,0x00,0x50,0x02,0x48,0x03,0xC0,0x02,  // 189
  0x48,0x00,0x58,0x00,0x68,0x03,0x80,0x00,0x60,0x01,0x90,0x01,0xC8,0x03,0x00,0x01,  // 190
  0x00,0x00,0x00,0x06,0x00,0x09,0xA0,0x09,0x00,0x04,  // 191
  0x00,0x02,0xC0,0x01,0xB0,0x00,0x89,0x00,0xB2,0x00,0xC0,0x01,0x00,0x02,  // 192
  0x00,0x02,0xC0,0x01,0xB0,0x00,0x8A,0x00,0xB1,0x00,0xC0,0x01,0x00,0x02,  // 193
  0x00,0x02,0xC0,0x01,0xB2,0x00,0x89,0x00,0xB2,0x00,0xC0,0x01,0x00,0x02,  // 194
  0x00,0x02,0xC2,0x01,0xB1,0x00,0x8A,0x00,0xB1,0x00,0xC0,0x01,0x00,0x02,  // 195
  0x00,0x02,0xC0,0x01,0xB2,0x00,0x88,0x00,0xB2,0x00,0xC0,0x01,0x00,0x02,  // 196
  0x00,0x02,0xC0,0x01,0xBE,0x00,0x8A,0x00,0xBE,0x00,0xC0,0x01,0x00,0x02,  // 197
  0x00,0x03,0xC0,0x00,0xE0,0x00,0x98,0x00,0x88,0x00,0xF8,0x03,0x48,0x02,0x48,0x02,0x48,0x02,  // 198
  0x00,0x00,0xF0,0x01,0x08,0x02,0x08,0x16,0x08,0x1A,0x10,0x01,  // 199
  0x00,0x00,0xF8,0x03,0x49,0x02,0x4A,0x02,0x48,0x02,0x48,0x02,  // 200
  0x00,0x00,0xF8,0x03,0x48,0x02,0x4A,0x02,0x49,0x02,0x48,0x02,  // 201
  0x00,0x00,0xFA,0x03,0x49,0x02,0x4A,0x02,0x48,0x02,0x48,0x02,  // 202
  0x00,0x00,0xF8,0x03,0x4A,0x02,0x48,0x02,0x4A,0x02,0x48,0x02,  // 203
  0x00,0x00,0xF9,0x03,0x02, // 204
  0x02,0x00,0xF9,0x03,  // 205
  0x01,0x00,0xFA,0x03,  // 206
  0x02,0x00,0xF8,0x03,0x02, // 207
  0x40,0x00,0xF8,0x03,0x48,0x02,0x48,0x02,0x10,0x01,0xE0, // 208
  0x00,0x00,0xFA,0x03,0x31,0x00,0x42,0x00,0x81,0x01,0xF8,0x03,  // 209
  0x00,0x00,0xF0,0x01,0x08,0x02,0x09,0x02,0x0A,0x02,0x08,0x02,0xF0,0x01,  // 210
  0x00,0x00,0xF0,0x01,0x08,0x02,0x0A,0x02,0x09,0x02,0x08,0x02,0xF0,0x01,  // 211
  0x00,0x00,0xF0,0x01,0x08,0x02,0x0A,0x02,0x09,0x02,0x0A,0x02,0xF0,0x01,  // 212
  0x00,0x00,0xF0,0x01,0x0A,0x02,0x09,0x02,0x0A,0x02,0x09,0x02,0xF0,0x01,  // 213
  0x00,0x00,0xF0,0x01,0x0A,0x02,0x08,0x02,0x0A,0x02,0x08,0x02,0xF0,0x01,  // 214
  0x10,0x01,0xA0,0x00,0xE0,0x00,0xA0,0x00,0x10,0x01,  // 215
  0x00,0x00,0xF0,0x02,0x08,0x03,0xC8,0x02,0x28,0x02,0x18,0x03,0xE8, // 216
  0x00,0x00,0xF8,0x01,0x01,0x02,0x02,0x02,0x00,0x02,0xF8,0x01,  // 217
  0x00,0x00,0xF8,0x01,0x02,0x02,0x01,0x02,0x00,0x02,0xF8,0x01,  // 218
  0x00,0x00,0xF8,0x01,0x02,0x02,0x01,0x02,0x02,0x02,0xF8,0x01,  // 219
  0x00,0x00,0xF8,0x01,0x02,0x02,0x00,0x02,0x02,0x02,0xF8,0x01,  // 220
  0x08,0x00,0x10,0x00,0x20,0x00,0xC2,0x03,0x21,0x00,0x10,0x00,0x08, // 221
  0x00,0x00,0xF8,0x03,0x10,0x01,0x10,0x01,0x10,0x01,0xE0, // 222
  0x00,0x00,0xF0,0x03,0x08,0x01,0x48,0x02,0xB0,0x02,0x80,0x01,  // 223
  0x00,0x00,0x00,0x03,0xA4,0x02,0xA8,0x02,0xE0,0x03,  // 224
  0x00,0x00,0x00,0x03,0xA8,0x02,0xA4,0x02,0xE0,0x03,  // 225
  0x00,0x00,0x00,0x03,0xA8,0x02,0xA4,0x02,0xE8,0x03,  // 226
  0x00,0x00,0x08,0x03,0xA4,0x02,0xA8,0x02,0xE4,0x03,  // 227
  0x00,0x00,0x00,0x03,0xA8,0x02,0xA0,0x02,0xE8,0x03,  // 228
  0x00,0x00,0x00,0x03,0xAE,0x02,0xAA,0x02,0xEE,0x03,  // 229
  0x00,0x00,0x40,0x03,0xA0,0x02,0xA0,0x02,0xC0,0x01,0xA0,0x02,0xA0,0x02,0xC0,0x02,  // 230
  0x00,0x00,0xC0,0x01,0x20,0x16,0x20,0x1A,0x40,0x01,  // 231
  0x00,0x00,0xC0,0x01,0xA4,0x02,0xA8,0x02,0xC0,0x02,  // 232
  0x00,0x00,0xC0,0x01,0xA8,0x02,0xA4,0x02,0xC0,0x02,  // 233
  0x00,0x00,0xC0,0x01,0xA8,0x02,0xA4,0x02,0xC8,0x02,  // 234
  0x00,0x00,0xC0,0x01,0xA8,0x02,0xA0,0x02,0xC8,0x02,  // 235
  0x00,0x00,0xE4,0x03,0x08, // 236
  0x08,0x00,0xE4,0x03,  // 237
  0x08,0x00,0xE4,0x03,0x08, // 238
  0x08,0x00,0xE0,0x03,0x08, // 239
  0x00,0x00,0xC0,0x01,0x28,0x02,0x38,0x02,0xE0,0x01,  // 240
  0x00,0x00,0xE8,0x03,0x24,0x00,0x28,0x00,0xC4,0x03,  // 241
  0x00,0x00,0xC0,0x01,0x24,0x02,0x28,0x02,0xC0,0x01,  // 242
  0x00,0x00,0xC0,0x01,0x28,0x02,0x24,0x02,0xC0,0x01,  // 243
  0x00,0x00,0xC0,0x01,0x28,0x02,0x24,0x02,0xC8,0x01,  // 244
  0x00,0x00,0xC8,0x01,0x24,0x02,0x28,0x02,0xC4,0x01,  // 245
  0x00,0x00,0xC0,0x01,0x28,0x02,0x20,0x02,0xC8,0x01,  // 246
  0x40,0x00,0x40,0x00,0x50,0x01,0x40,0x00,0x40, // 247
  0x00,0x00,0xC0,0x02,0xA0,0x03,0x60,0x02,0xA0,0x01,  // 248
  0x00,0x00,0xE0,0x01,0x04,0x02,0x08,0x02,0xE0,0x03,  // 249
  0x00,0x00,0xE0,0x01,0x08,0x02,0x04,0x02,0xE0,0x03,  // 250
  0x00,0x00,0xE8,0x01,0x04,0x02,0x08,0x02,0xE0,0x03,  // 251
  0x00,0x00,0xE0,0x01,0x08,0x02,0x00,0x02,0xE8,0x03,  // 252
  0x20,0x00,0xC0,0x09,0x08,0x06,0xC4,0x01,0x20, // 253
  0x00,0x00,0xF8,0x0F,0x20,0x02,0x20,0x02,0xC0,0x01,  // 254
  0x20,0x00,0xC8,0x09,0x00,0x06,0xC8,0x01,0x20  // 255
#endif
ssd1306.h
#include "i2c.h"
#include <avr/pgmspace.h>
#define SSD1306_DEFAULT_ADDRESS 0x78
#define SSD1306_SETCONTRAST 0x81
#define SSD1306_DISPLAYALLON_RESUME 0xA4
#define SSD1306_DISPLAYALLON 0xA5
#define SSD1306_NORMALDISPLAY 0xA6
#define SSD1306_INVERTDISPLAY 0xA7
#define SSD1306_DISPLAYOFF 0xAE
#define SSD1306_DISPLAYON 0xAF
#define SSD1306_SETDISPLAYOFFSET 0xD3
#define SSD1306_SETCOMPINS 0xDA
#define SSD1306_SETVCOMDETECT 0xDB
#define SSD1306_SETDISPLAYCLOCKDIV 0xD5
#define SSD1306_SETPRECHARGE 0xD9
#define SSD1306_SETMULTIPLEX 0xA8
#define SSD1306_SETLOWCOLUMN 0x00
#define SSD1306_SETHIGHCOLUMN 0x10
#define SSD1306_SETSTARTLINE 0x40
#define SSD1306_MEMORYMODE 0x20
#define SSD1306_COLUMNADDR 0x21
#define SSD1306_PAGEADDR   0x22
#define SSD1306_COMSCANINC 0xC0
#define SSD1306_COMSCANDEC 0xC8
#define SSD1306_SEGREMAP 0xA0
#define SSD1306_CHARGEPUMP 0x8D
#define SSD1306_SWITCHCAPVCC 0x2
#define SSD1306_NOP 0xE3
#define SSD1306_DEACTIVATE_SCROLL 0x2E
#define SSD1306_LCDWIDTH      128
#define SSD1306_LCDHEIGHT      64
#define DISPLAY_BUFFER_SIZE 1024
// Header Values
#define JUMPTABLE_BYTES 4
#define JUMPTABLE_LSB   1
#define JUMPTABLE_SIZE  2
#define JUMPTABLE_WIDTH 3
#define JUMPTABLE_START 4
#define WIDTH_POS 0
#define HEIGHT_POS 1
#define FIRST_CHAR_POS 2
#define CHAR_NUM_POS 3
enum OLEDDISPLAY_COLOR {
  BLACK = 0,
  WHITE = 1,
  INVERSE = 2
enum OLEDDISPLAY_TEXT_ALIGNMENT {
  TEXT_ALIGN_LEFT = 0,
  TEXT_ALIGN_RIGHT = 1,
  TEXT_ALIGN_CENTER = 2,
  TEXT_ALIGN_CENTER_BOTH = 3
extern uint8_t display_buffer[SSD1306_LCDHEIGHT * SSD1306_LCDWIDTH / 8];
void ssd1306_command(uint8_t command);
void ssd1306_init(void);
void setColAddress();
void setPageAddress();
void TransferBuffer();
void display(void);
void clear_display(void);
void drawPixel(uint8_t pos_x, uint8_t pos_y, uint8_t pixel_status);
//void setPixel(int16_t x, int16_t y);
void drawInternal(int16_t xMove, int16_t yMove, int16_t width, int16_t height, const char *data, uint16_t offset, uint16_t bytesInData);
//void drawString(int16_t x, int16_t y, String text);
void drawStringInternal(int16_t xMove, int16_t yMove, char* text, uint16_t textLength, uint16_t textWidth, uint16_t textAlignment);
ssd1306.c
#include <stdint.h>
#include "ssd1306.h"
#include <util/delay.h>
#include <stdio.h>
#include <string.h>
#include "DisplayFonts.h"
const char  *fontData   = ArialMT_Plain_10;
void ssd1306_command(uint8_t command) {
    i2c_start(SSD1306_DEFAULT_ADDRESS);
    i2c_write(0x00);
    i2c_write(command);
    i2c_stop();
void ssd1306_init(void) {
    PORTD |= (1 << PD4);    // set RES high shortly
    DDRD |= (1 << PD4);
    _delay_ms(40);
    PORTD ^= (1 << PD4);   // set RES low (active low)
    _delay_ms(40);
    PORTD ^= (1 << PD4);    // set RES high
    _delay_ms(40);
    // Init sequence for 128x64 OLED module
    ssd1306_command(SSD1306_DISPLAYOFF);                    // 0xAE
    ssd1306_command(SSD1306_SETDISPLAYCLOCKDIV);            // 0xD5
    ssd1306_command(0x80);                 // the suggested ratio 0x80
    ssd1306_command(SSD1306_SETMULTIPLEX);                  // 0xA8
    ssd1306_command(0x3F);
    ssd1306_command(SSD1306_SETDISPLAYOFFSET);              // 0xD3
    ssd1306_command(0x0);                                   // no offset
    ssd1306_command(SSD1306_SETSTARTLINE);// | 0x0);        // line #0
    ssd1306_command(SSD1306_CHARGEPUMP);                    // 0x8D
    ssd1306_command(0x14);  // using internal VCC
    ssd1306_command(SSD1306_MEMORYMODE);                    // 0x20
    ssd1306_command(0x00);          // 0x00 horizontal addressing
    ssd1306_command(SSD1306_SEGREMAP | 0x1); // rotate screen 180
    ssd1306_command(SSD1306_COMSCANDEC); // rotate screen 180
    ssd1306_command(SSD1306_SETCOMPINS);                    // 0xDA
    ssd1306_command(0x12);
    ssd1306_command(SSD1306_SETCONTRAST);                   // 0x81
    ssd1306_command(0xCF);
    ssd1306_command(SSD1306_SETPRECHARGE);                  // 0xd9
    ssd1306_command(0xF1);
    ssd1306_command(SSD1306_SETVCOMDETECT);                 // 0xDB
    ssd1306_command(0x40);
    ssd1306_command(SSD1306_DISPLAYALLON_RESUME);           // 0xA4
    ssd1306_command(SSD1306_NORMALDISPLAY);                 // 0xA6
    ssd1306_command(SSD1306_DEACTIVATE_SCROLL);
    ssd1306_command(SSD1306_DISPLAYON);                     //switch on OLED
// Used when doing Horizontal or Vertical Addressing
  ssd1306_command(SSD1306_COLUMNADDR); // 0x21 COMMAND
  ssd1306_command(0); // Column start address
  ssd1306_command(SSD1306_LCDWIDTH-1); // Column end address
  ssd1306_command(SSD1306_PAGEADDR); // 0x22 COMMAND
  ssd1306_command(0); // Start Page address
  ssd1306_command((SSD1306_LCDHEIGHT/8)-1);// End Page address
// Transfers the local buffer to the CGRAM in the SSD1306
  uint16_t j=0;
      // set the Column and Page addresses to 0,0
      setColAddress();
      setPageAddress();
      i2c_write(0X40); // data not command
      for(j=0;j<1024;j++)
        i2c_write(display_buffer[j]);
      i2c_stop();
void display(void)
  setColAddress();
  setPageAddress();
    // I2C
  uint16_t i;
  uint8_t x;
  for (i = 0; i < (SSD1306_LCDWIDTH*SSD1306_LCDHEIGHT/8); i++) {
    // send a bunch of data in one transmission
    i2c_write(0x40);
    for (x = 0; x < 16; x++) {
      i2c_write(display_buffer[i]);
      i++;
    i--;
    i2c_stop();
  memset(display_buffer, 0x00, (SSD1306_LCDWIDTH*SSD1306_LCDHEIGHT/8));
  display();
  if (pos_x >= SSD1306_LCDWIDTH || pos_y >= SSD1306_LCDHEIGHT) {
      return;
  if (pixel_status) {
      display_buffer[pos_x+(pos_y/8)*SSD1306_LCDWIDTH] |= (1 << (pos_y&7));
  else {
       display_buffer[pos_x+(pos_y/8)*SSD1306_LCDWIDTH] &= ~(1 << (pos_y&7));
void drawBuffer(const uint8_t *progmem_buffer) {
    uint8_t current_byte;
    uint8_t y_pos;
    uint8_t x_pos;
    for (y_pos = 0; y_pos < 64; y_pos++) {
        for (x_pos = 0; x_pos < 128; x_pos++) {
            current_byte = pgm_read_byte(progmem_buffer + y_pos*16 + x_pos/8);
            if (current_byte & (128 >> (x_pos&7))) {
                drawPixel(x_pos,y_pos,1);
            } else {
                drawPixel(x_pos,y_pos,0);
    display();
void drawStringInternal(int16_t xMove, int16_t yMove, char* text, uint16_t textLength, uint16_t textWidth, uint16_t textAlignment) {
  uint8_t textHeight       = pgm_read_byte(fontData + HEIGHT_POS);
  uint8_t firstChar        = pgm_read_byte(fontData + FIRST_CHAR_POS);
  uint16_t sizeOfJumpTable = pgm_read_byte(fontData + CHAR_NUM_POS)  * JUMPTABLE_BYTES;
  uint8_t cursorX         = 0;
  uint8_t cursorY         = 0;
  switch (textAlignment) {
    case TEXT_ALIGN_CENTER_BOTH:
      yMove -= textHeight >> 1;
    // Fallthrough
    case TEXT_ALIGN_CENTER:
      xMove -= textWidth >> 1; // divide by 2
      break;
    case TEXT_ALIGN_RIGHT:
      xMove -= textWidth;
      break;
  // Don't draw anything if it is not on the screen.
  if (xMove + textWidth  < 0 || xMove > SSD1306_LCDWIDTH ) {return;}
  if (yMove + textHeight < 0 || yMove > SSD1306_LCDHEIGHT) {return;}
  uint16_t j;
  for (j = 0; j < textLength; j++) {
    int16_t xPos = xMove + cursorX;
    int16_t yPos = yMove + cursorY;
    uint8_t code = text[j];
    if (code >= firstChar) {
      uint8_t charCode = code - firstChar;
      // 4 Bytes per char code
      uint8_t msbJumpToChar    = pgm_read_byte( fontData + JUMPTABLE_START + charCode * JUMPTABLE_BYTES );                  // MSB  \ JumpAddress
      uint8_t lsbJumpToChar    = pgm_read_byte( fontData + JUMPTABLE_START + charCode * JUMPTABLE_BYTES + JUMPTABLE_LSB);   // LSB /
      uint8_t charByteSize     = pgm_read_byte( fontData + JUMPTABLE_START + charCode * JUMPTABLE_BYTES + JUMPTABLE_SIZE);  // Size
      uint8_t currentCharWidth = pgm_read_byte( fontData + JUMPTABLE_START + charCode * JUMPTABLE_BYTES + JUMPTABLE_WIDTH); // Width
      // Test if the char is drawable
      if (!(msbJumpToChar == 255 && lsbJumpToChar == 255)) {
        // Get the position of the char data
        uint16_t charDataPosition = JUMPTABLE_START + sizeOfJumpTable + ((msbJumpToChar << 8) + lsbJumpToChar);
        drawInternal(xPos, yPos, currentCharWidth, textHeight, fontData, charDataPosition, charByteSize);
      cursorX += currentCharWidth;
void drawInternal(int16_t xMove, int16_t yMove, int16_t width, int16_t height, const char *data, uint16_t offset, uint16_t bytesInData) {
  if (width < 0 || height < 0) return;
  if (yMove + height < 0 || yMove > SSD1306_LCDHEIGHT)  return;
  if (xMove + width  < 0 || xMove > SSD1306_LCDWIDTH)   return;
  uint8_t  rasterHeight = 1 + ((height - 1) >> 3); // fast ceil(height / 8.0)
  int8_t   yOffset      = yMove & 7;
  bytesInData = bytesInData == 0 ? width * rasterHeight : bytesInData;
  int16_t initYMove   = yMove;
  int8_t  initYOffset = yOffset;
  uint16_t i;
  for (i = 0; i < bytesInData; i++) {
    // Reset if next horizontal drawing phase is started.
    if ( i % rasterHeight == 0) {
      yMove   = initYMove;
      yOffset = initYOffset;
    uint8_t currentByte = pgm_read_byte(data + offset + i);
    int16_t xPos = xMove + (i / rasterHeight);
    int16_t yPos = ((yMove >> 3) + (i % rasterHeight)) * SSD1306_LCDWIDTH;
    int16_t yScreenPos = yMove + yOffset;
    int16_t dataPos    = xPos  + yPos;
    if (dataPos >=  0  && dataPos < DISPLAY_BUFFER_SIZE &&
        xPos    >=  0  && xPos    < SSD1306_LCDWIDTH ) {
      if (yOffset >= 0) {
        display_buffer[dataPos] |= currentByte << yOffset;
        if (dataPos < (DISPLAY_BUFFER_SIZE - SSD1306_LCDWIDTH)) {
          display_buffer[dataPos + SSD1306_LCDWIDTH] |= currentByte >> (8 - yOffset);
      } else {
        // Make new offset position
        yOffset = -yOffset;
        display_buffer[dataPos] |= currentByte >> yOffset;
        // Prepare for next iteration by moving one block up
        yMove -= 8;
        // and setting the new yOffset
        yOffset = 8 - yOffset;
      //yield();
main test program
- the display buffer has the initial data for the Adafruit logo, which no longer even appears without me editing the buffer. There definitely seems to be an issue with where and how I am defining the buffer.
#include "i2c.h"
#include <stdio.h>
#include <string.h>
uint8_t display_buffer[SSD1306_LCDHEIGHT * SSD1306_LCDWIDTH / 8] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80,
0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x80, 0x80, 0xC0, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xE0, 0xF0, 0xF8, 0xFC, 0xF8, 0xE0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80,
0x80, 0x80, 0x00, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0x80, 0x80, 0x00, 0xFF,
0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0x80, 0x00, 0x00, 0x80, 0x80, 0x00, 0x00,
0x80, 0xFF, 0xFF, 0x80, 0x80, 0x00, 0x80, 0x80, 0x00, 0x80, 0x80, 0x80, 0x80, 0x00, 0x80, 0x80,
0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x00, 0x00, 0x8C, 0x8E, 0x84, 0x00, 0x00, 0x80, 0xF8,
0xF8, 0xF8, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xE0, 0xE0, 0xC0, 0x80,
0x00, 0xE0, 0xFC, 0xFE, 0xFF, 0xFF, 0xFF, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0xFF, 0xC7, 0x01, 0x01,
0x01, 0x01, 0x83, 0xFF, 0xFF, 0x00, 0x00, 0x7C, 0xFE, 0xC7, 0x01, 0x01, 0x01, 0x01, 0x83, 0xFF,
0xFF, 0xFF, 0x00, 0x38, 0xFE, 0xC7, 0x83, 0x01, 0x01, 0x01, 0x83, 0xC7, 0xFF, 0xFF, 0x00, 0x00,
0x01, 0xFF, 0xFF, 0x01, 0x01, 0x00, 0xFF, 0xFF, 0x07, 0x01, 0x01, 0x01, 0x00, 0x00, 0x7F, 0xFF,
0x80, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0x7F, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x01, 0xFF,
0xFF, 0xFF, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x03, 0x0F, 0x3F, 0x7F, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xE7, 0xC7, 0xC7, 0x8F,
0x8F, 0x9F, 0xBF, 0xFF, 0xFF, 0xC3, 0xC0, 0xF0, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0xFC, 0xFC,
0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xF8, 0xF8, 0xF0, 0xF0, 0xE0, 0xC0, 0x00, 0x01, 0x03, 0x03, 0x03,
0x03, 0x03, 0x01, 0x03, 0x03, 0x00, 0x00, 0x00, 0x00, 0x01, 0x03, 0x03, 0x03, 0x03, 0x01, 0x01,
0x03, 0x01, 0x00, 0x00, 0x00, 0x01, 0x03, 0x03, 0x03, 0x03, 0x01, 0x01, 0x03, 0x03, 0x00, 0x00,
0x00, 0x03, 0x03, 0x00, 0x00, 0x00, 0x03, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x03, 0x03, 0x03, 0x03, 0x03, 0x01, 0x00, 0x00, 0x00, 0x01, 0x03, 0x01, 0x00, 0x00, 0x00, 0x03,
0x03, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x80, 0xC0, 0xE0, 0xF0, 0xF9, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x3F, 0x1F, 0x0F,
0x87, 0xC7, 0xF7, 0xFF, 0xFF, 0x1F, 0x1F, 0x3D, 0xFC, 0xF8, 0xF8, 0xF8, 0xF8, 0x7C, 0x7D, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x3F, 0x0F, 0x07, 0x00, 0x30, 0x30, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xFE, 0xFE, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0xC0, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
0x00, 0xC0, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x7F, 0x3F, 0x1F,
0x0F, 0x07, 0x1F, 0x7F, 0xFF, 0xFF, 0xF8, 0xF8, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xF8, 0xE0,
0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0xFE, 0x00, 0x00,
0x00, 0xFC, 0xFE, 0xFC, 0x0C, 0x06, 0x06, 0x0E, 0xFC, 0xF8, 0x00, 0x00, 0xF0, 0xF8, 0x1C, 0x0E,
0x06, 0x06, 0x06, 0x0C, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0xFE, 0xFE, 0x00, 0x00, 0x00, 0x00, 0xFC,
0xFE, 0xFC, 0x00, 0x18, 0x3C, 0x7E, 0x66, 0xE6, 0xCE, 0x84, 0x00, 0x00, 0x06, 0xFF, 0xFF, 0x06,
0x06, 0xFC, 0xFE, 0xFC, 0x0C, 0x06, 0x06, 0x06, 0x00, 0x00, 0xFE, 0xFE, 0x00, 0x00, 0xC0, 0xF8,
0xFC, 0x4E, 0x46, 0x46, 0x46, 0x4E, 0x7C, 0x78, 0x40, 0x18, 0x3C, 0x76, 0xE6, 0xCE, 0xCC, 0x80,
0x00, 0x00, 0x00, 0x00, 0x01, 0x07, 0x0F, 0x1F, 0x1F, 0x3F, 0x3F, 0x3F, 0x3F, 0x1F, 0x0F, 0x03,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x0F, 0x00, 0x00,
0x00, 0x0F, 0x0F, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x0F, 0x00, 0x00, 0x03, 0x07, 0x0E, 0x0C,
0x18, 0x18, 0x0C, 0x06, 0x0F, 0x0F, 0x0F, 0x00, 0x00, 0x01, 0x0F, 0x0E, 0x0C, 0x18, 0x0C, 0x0F,
0x07, 0x01, 0x00, 0x04, 0x0E, 0x0C, 0x18, 0x0C, 0x0F, 0x07, 0x00, 0x00, 0x00, 0x0F, 0x0F, 0x00,
0x00, 0x0F, 0x0F, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x0F, 0x00, 0x00, 0x00, 0x07,
0x07, 0x0C, 0x0C, 0x18, 0x1C, 0x0C, 0x06, 0x06, 0x00, 0x04, 0x0E, 0x0C, 0x18, 0x0C, 0x0F, 0x07,
int main(void){
    i2c_init();
    _delay_ms(3000);
     ssd1306_init();
   clear_display();
   char buff[] = "Testing this.";
   drawStringInternal(0, 0, buff,13,10,0);
   display();
   _delay_ms(3000);
    while (1){
	return 0;
Also not sure what I need to be putting in for the textlength and textwidth parameters in the draw string internal function.
Here's the link to where I found the code:https://github.com/squix78/esp82...
Yes, you seem to have got the hang of converting C++ methods to C functions.
I suggest that you ZIP up your AS7 project and attach it. Then someone might build and debug it for you.
I doubt if anyone is going to copy-paste all your individual files. Or even read through the code.
Is there any reason why you chose C? AS7 can compile the C++ from Arduino. It is easy to write some stubs to remove dependence on any other Arduino code.
Or just Google for an existing C library. Rendering monospaced fonts is fairly complicated. Proportional fonts more so. But since it has all been done before, you might just as well adapt existing code.
Here is the ZIP file for the project attached.
Just the requirement for the project, it's for a senior design course.
I'm yet to really find any C code for the dislay that would work with avr compiler.
I think I am getting closer to it functioning. Something just seems to be off with how I am updating the buffer and using the font library.
I have it all working now. I'll try to post my code for it later.
Thanks everyone for the help!
