convert hex file back to code
7 posts / 0 new
Hi
Is it possible to convert a .hex file back to the code?
I had written a program in basic and loaded it up on the micro.
But my HDD crashed, and i lost the program. The program is still loaded on the micro, so i read back the flash memory and it was stored as a .hex file. Now i need to figure out if theres a way i can turn this back to the code?
thanks
Hi
Try ReAVR
https://www.avrfreaks.net/index.php?module=FreaksTools&func=viewItem&item_id=272
Surely you must some printout of the code that you wrote or some other backup.
Ken
It's an amazing how common an occurance this is!
'Ain't gonna happen. When code written in a high-level language is compiled down to a HEX, all the human-readable aspect are stripped. The best you can possibly get is the pure assembler representation of the compiled code, not the actual code itself.
- Dean :twisted:
amol,
Personally I like DISAVR for this - a thread search here will turn it up.
In future, if I were you I'd use the DVD drive, a USB memory stick a USB/Firewire external HDD or a netowrk to regularly back up any data that is "precious" - a small amount of work will save a LOT of heartache in the future!
Cliff
Hi
I adopt the same policies what Cliff mentioned above.
There is another way which might be unorthodox is to email your own code to yourself or to your own service provider.
I do this all the time.
I email home stuff to work address.
At work email to my own private one like ****@yahoo.com.
That way there are copies floating around when you get into trouble?
Hint! You set a tag so it does not remove itself from the server area.
This has never left me out in the cold & it works well.
Also makes many printouts as hard copies at a regulator interval.
Write the date, time & filename on the printouts.
This I recommended to our members of the family who are doing IT & University degrees.
They also send me email containing their works of essays & thesis’s.
I never delete theirs at all but all will end up on a couple of backup CDs.
Just a precaution if you get caught out.
Just a few cents worth of paper will give you a peace of mind?
So, I don’t mind if anybody else would like to adopt this technique.
Ken
Very NICE ! I've love it.
You should also check out the resent thread regarding a similiar experience.
In particular, please check out my last post in this thread. Oh, thank the computer gods that I practiced what I preached!
In the end, you can use all of the new fangled do-hickey type programs you want but, nothing substitutes for a deciplined back-up regime.
