voice transfer not playing correctly 256A3BU ESP8266
2 posts / 0 new
Hello everyone,
I am working with esp8266 and xmega256a3bu to transfer voice from mic on one xmega to another over wifi using esp8266. When I transfer it from adc to dac via dma directly, it works quite well. When I use a buffer instead, (ADC ->DMA-> BUFFER & BUFFER -> DMA-> DAC) It works better if the samples are less but works still. However, when I transfer samples from this very buffer over wifi and send the received data (also stored in a buffer) to DAC, it simply can't recreate the signal. I suspect it's because it is too slow which effectively decreases the sample rate since number of samples are the same but time to process and transfer them is longer. slower sample rate means lower nyquist frequency which means I would get an alias instead of the original signal. Of course this is just a theory.
Either way, could someone tell me if there is a way around this problem? or is the problem something entirely different?
Thanks!!!
Soul
WiFi, itself, is certainly capable of digital voice transmission. Its done all the time - using Skype for example. It MAY be that your WiFi modules don't have sufficient speed or the speed of the MCU-WiFi transfer is not fast enough. You probably need to do a bit more to identify where the bottleneck really is.
