Good point, unfortunately not. During my problem analysis I disabled/closed all unnecessary windows processes. The Task-Manager doesn't give me helpful hints.
Posted by straighter: Tue. Mar 21, 2017 - 02:07 PM
1
2
3
4
5
Does it mean that it is removed from the Extensions as well? Can I revert the installation to a previous version to have it? Or will it disappear forever from the Extensions section? Is there a way to install it separately? Or will there be a similar feature installed?
We have removed it from the studio installation due to the license. However, if Percepio wants to make it available in the gallery is up to them. I don't know if they want to do that (I haven't had the chance to talk to them about this yet).
I'm sure that if you ask them you'll at least get an answer
:: Morten
Are you aware that the Atmel Studio Webpage still shows 1188 as the latest. Just downloaded the 1188 full installer and the first question was: "There is a newer version ..." ... sigh. Also the release notes are for 1188. The ones you posted here are newer.
I am not privy to the contractual agreements between Atmel and Percepio. My understanding based on your statements is that Percepio Trace was removed from the Gallery by Atmel because of the agreement's expiry, but Percepio might not know about it yet?
I'm running the 1417 under Windows 7. Installation worked, it compiles, but my GUI stucks about every 5 seconds for about 1-2 seconds. This is very annoying, a continuous workflow is nearly impossible (the complete Atmel Studio is affected). Did anyone else encountered this problem so far? The last Atmel Studio (1188 for me) worked fine.
Regards
After a complete reinstallation of Atmel Studio .1417 (by as-installer-7.0.1417-web.exe) everything works fine, last time I updated from .1188. I know that Atmel Studio is based on VS 2015, but my web search showed me, that some VS 2017 users have exactly the same problem. (link1link2)
Is the new version still unofficial? I cannot find it on http://www.atmel.com/tools/atmel..., there is 7.0.1188. I can't find release notes for 7.0.1417 as well.
That's right. However, when I tried to install 7.0.0.188 it says there is a later version and asks if you would like to install the newest version. I clicked yes and I got 7.0.1417.
7.0.1417 is official, it's just that updating the web site is a task that (obviously) takes some time. Not everything is running smooth after the merger.
@acab, try to delete the content in Atmel\Studio\7.0\atbackend\codeCache\ and start Studio again. If not even the simulator is showing in the tools list there is nothing wrong with your tools, it's the backend that is having issues.
Thanks for your response. Unfortunately I got impatient and I decided to go back and install the old version I had which was working mostly. But It would crash with an error of "AVR8 Device Support". Therefore, I tried to re-install 7.0.1417 but I got the same error.
When I checked the Atmel site I noticed that the latest version recommended is 7.0.1188. So I donwloaded it and tried to install with the same result plus more errors listed. It also shows some links on how to troubleshoot. However when I click them I get sent to a web page that is not working.
I submitted a support case to Microchip but no answer yet.
I noticed Atmel studio still shows up as an installed. I tried to uninstall but that only restarts the installation and I get the same error again:
So to summarize my problem is that I don't have Atmel Studio anymore and any attempt to install it fail.
It seems my problem was a corrupted registry. Tried to Fix it with Microsoft Fix-It but didn't work. Finally I used Revo Uninstaller and that worked. Great program!.
I have installed version 7.0.1188. I still have to properly fix everything but I'm hopeful.
I'm using win10 creators update (attached file), Atmel studio 7 build 1417, Atmega324P MCU and JTAGICE3/Atmel ICE. I can use JTAGICE3 or Atmel ICE to flash the code to board successfully. But can not debugging due to "Debugger command Prog Mode Leave failed" error, then the FUSES were reset (JTAGEN changed from checked to unchecked).
Do you have any idea to resolve this issue? Thank you.
I tried to update to 7.0.1417 on Win 7 but it doesn't work. AS installer says that I have to update Windows KB2999226 (essential) and KB2670838 and KB2978092 (optional), but all are installed!
I tried to deinstall the 3 updates and reinstall using Windows Update - no success. AS installer doesn't finish the installation because of the missing updates.
The error message talks about an earlier version of "Microsoft Redistributable 2010" being present and that it is a "blocker" for installing Atmel Studio.
Are you sure about that youre trying to install "the latest version"? You're talking about "AVR Studio" but it's been caölled "Atmel Studio" for many years now. Also, I can (faintly) read in your screen shot that it tries to install "Microsoft C++ 2010 x86 Redistributable Setup". I do not think (but am not 100% sure) that it is a part of the latest Atmel Studio install.
As far as sI know Atmel Studio 7 is based on newer components than that from Microsoft.
Can you tell us what version of Studio you're trying to install? I.e. give us the version number. Also tell us where/how you got it.
BTW, your screenshot is ridiculously small and very hard to read. Whenever possible, it is much better to copy error messages as text and paste them in a post here. Or possibly do a decent screenshot and copy messages as text and post both.
As of January 15, 2018, Site fix-up work has begun! Now do your part and report any bugs or deficiencies here.
No guarantees, but if we don't report problems they won't get much of a chance to be fixed! Details/discussions at link given just above.
Package Name = Microsoft Visual C++ 2010 x86 Redistributable Setup
Package Version = 10.0.30319
User Experience Data Collection Policy: UserControlled
Logging all the global blocks
Installation Blockers:
Une version plus récente de Microsoft Visual C++ 2010 Redistributable a été détectée sur cet ordinateur.
Final Result: Installation failed with error code: (0x000013EC), "A StopBlock was hit or a System Requirement was not met." (Elapsed time: 0 00:00:00).
In fact: i have on my computer the version Microsoft Visual C++ 2015
Posted by JohanEkdahl: Sun. Jul 2, 2017 - 05:42 PM
1
2
3
4
5
OK. My French is a bit rusty, haven't spoken or written in it for 40+ years, so had to look up "récente" , and of course it's the same as the English "recent".
So, it looks like the Visual C++ 2015 has installed a newer version of the "redistributable" than the one coming with Atmel Studio.
I'm sorry, but I don't know what to do about this. One interesting StackExchange thread found while searching: https://stackoverflow.com/questi... . PErhaps there's something in that to help you?
Hopefully this will resolve the ongoing issues with Windows 10 that are piling up.
Is it possible for Atmel Studio to eventually be in Microsoft Store?
Reason : Windows 10 S
Am uncertain this is possible because Microsoft Visual Studio is not in Microsoft Store though Atmel Studio having Visual Studio Isolated Shell may make this a possibility.
Windows 10 S is likely to be popular in the US for primary, secondary, and post-secondary education and for libraries.
Locally, I doubt Arduino is in secondary schools; any primary and secondary educational use of Arduino is at one library with one professor from the engineering college.
With a reasonable drive, or a few/several mass transit rides, one can be at one library that has a makerspace.
The upgrade to Windows 10 Pro from S has a price of 49USD for a low price notebook PC (zero for more expensive PC with the zero price upgrade ending 2018-Mar-31)
Computerworld
How Windows 10 S is different from the Windows 10 you know
Windows 10 S isn't just for education; Microsoft hopes the new Windows edition will find its way into homes and enterprises, too. But beneath the familiar user interface are some significant differences.
This is a full version of Windows with some limitations, one that’s designed to start up quickly, have long battery life, and keep working properly month after month after month, without resets or support calls.
Another is that schools are usually short on IT resources, so they’re looking for simpler management options that rely on the cloud.
A pristine PC
More significantly, this is a Windows that restricts which applications you can run (they have to come from the Windows Store) and ...
That [Azure Active Directory] removes Group Policy, a feature that gives IT admins control but also slows systems down and makes Windows fragile.
Instead of Group Policy, it’s managed the way smartphones and tablets are, using MDM tools and cloud identities.
... and to install apps – either online or via a USB stick that teachers or admins plug into Windows 10 S devices.
Because Windows 10 S only runs software from the Windows Store, all the apps use a virtualized registry, so one app can’t affect the settings another app uses.
Windows Store restrictions
You can install desktop applications on Windows 10 S, but only if they’ve been sandboxed by Microsoft’s Desktop Bridge tool and come through the Windows Store.
Other software publishers using the Desktop Bridge tool to deliver software include ...
How to get Windows 10 S
... Windows 10 S ISO is available on the Microsoft Developer Network so schools can put it on their existing hardware and IT departments can test it.
(other than MSDN, it's on specific new OEM PCs)
How to get off of Windows 10 S
Schools can switch to Windows 10 Pro Edu at any time and at no cost.
"It's about having the best of Windows 10 S and the best of Windows 10 Enterprise in just one subscription package." - Augusto Valdez, a director of product marketing in the Windows group
... only apps from the just-renamed Microsoft Store can be installed under the OS and will run on it.
... simpler management for IT.
Only on 10 S devices
During Ignite [Microsoft technology conference, Orlando, 2017-Oct], several OEMs, including HP and Lenovo, trotted out new notebooks, some starting as low as $275, that came with Windows 10 S.
Enter Microsoft 365 F1
M365 F1 consists of three parts: Office 365, Windows 10 and Enterprise Mobility + Security (EMS), a collection of device- and user-management services and tools.
What's next?
[desktop PC]
In that scenario, only the latter [notebook PC with Windows 10 Enterprise in S Mode] would leave the multi-layered defenses of the company's network.
Why does the "Update pack, The project is referring to a pack that is not installed" happen? Are these things that did not get downloaded installed with the main program install?
It is cool that the int24 has been added. I sure would love to see double floating point too!
@Morten can (and will) probably correct me if I'm wrong, but packs installed when installing Atmel Studio will be updated/replaced with newer versions when you install a new Atmel Studio version. Packs you have manually installed will be left untouched. Your project was created before you updated Studio, and the Studio update upgraded the part pack.
All part packs are available at packs.download.atmel.com, so you can get any version you want.
Posted by Frankinator: Fri. Mar 2, 2018 - 12:51 AM
1
2
3
4
5
Perhaps using my AVRISP MkII on Atmel Studio 7.0.1645 running under Windows 10 did not cause the degree of trouble for others that it did for me, but in case it did, here is how I fixed it. Firstly, the PROBLEM. Simply, after installation of Studio 7.0 my AVRISP MkII would no longer connect to the TARGET. The AVRISP MkII would not even show up in 'Selected debugger/programmer' window (entered by clicking on the hammer tool on the toolbar at the top). The only choices were "Simulator" or "Custom".
I was aware that Atmel Studio 7.0 changed from using the Jungo driver (used for previous versions) to the winUSB driver so I set about troubleshooting that particular aspect.
I uninstalled Atmel Studio 7.0 and reinstalled using the Web Connected method (there are two methods available for downloading: One is called on-line and the other is called off-line). Results were still the same.
I then viewed a video from the Indian Youtube page "KnowledgeShelf" for which I am eternally grateful. It was a walkthrough of the 'off-line' method and it was during this that I saw that the Jungo driver had to be replaced.
I then set about changing the USB driver and that was no easy feat. Anything automatic always came back to installing the Jungo driver with exactly the same symptoms as mentioned above no matter whether the Jungo driver was uninstalled first or whatever. The results were always the same. I tried manually searching for the correct winUSB driver but kept coming up with something that was rejected by the Installer software. I even attempted to get the driver from Microchip but was offered instead a discount voucher for an ATTiny for the inconvenience of arriving at a 404 Web message. "Great, I thought, I could have a room full of them and nothing to program them with" ... but I digress,
Once more I set about uninstalling Atmel 7.0 with the intention of installing it using the method of KnowledgeShelf, and I had just committed to the uninstall action when I noticed some folders in the uninstall window which looked suspiciously like they contained driver packages. Tracking these back to their source I found that they were under Windows > Program Files (x86) > Atmel > Studio. Yes. That's right, unlike Atmel Studio 6.0 or Atmel Studio 6.2 which are both marked with the full name, for what ever reason, this automatic installation has named the folder simply 'Studio'.
Under Studio, there is a folder marked 7.0 and another marked Drivers. If you look in Drivers > inf you will find winUSB and under winUSB you will find another folder with the elusive 'atmel_winusb'.
When I returned to Device Manager to manually configure the driver, I just gave the path-name to that Drivers folder. (Excitement and expectation was now building to a feverish pitch).
Anyhow, the upshot is that once that was in place, everything worked. I plugged the AVRISP into the computer USB port and good old Plug and Play found the Device, made a new look entry (see below) in the Device Manager table which I quickly examined in detail. Going through right click on AVRISPmkII and looking through the detail tabs of the information presented, I could see that I was now referencing winusb.sys of the system32 drivers.
And there you have it. Hope this helps somebody else.
Regards
TopSorry to be a pain, but where has Percepio Trace gone?
TopWe've had to remove it since our redistribution license expired.
:: Morten
TopDoes it mean that it is removed from the Extensions as well? Can I revert the installation to a previous version to have it? Or will it disappear forever from the Extensions section? Is there a way to install it separately? Or will there be a similar feature installed?
TopWe have removed it from the studio installation due to the license. However, if Percepio wants to make it available in the gallery is up to them. I don't know if they want to do that (I haven't had the chance to talk to them about this yet).
:: Morten
TopAre you aware that the Atmel Studio Webpage still shows 1188 as the latest. Just downloaded the 1188 full installer and the first question was: "There is a newer version ..." ... sigh. Also the release notes are for 1188. The ones you posted here are newer.
@meolsen: You're doing a great job, thanks :-)
TopYes, we know...
Note that when you download 1188, you don't have to check the "download newest" (if that was the question).
:: Morten
TopI am not privy to the contractual agreements between Atmel and Percepio. My understanding based on your statements is that Percepio Trace was removed from the Gallery by Atmel because of the agreement's expiry, but Percepio might not know about it yet?
Topthe trace plugin was never on the gallery....
:: Morten
TopOh, so it was part of the install? so the previous versions of Atmel would still have it?
TopJupp :)
(there's also ways of moving it between versions, but I think I'm passing my usual grey-zone of operation if I divulge too much
:: Morten
TopAfter a complete reinstallation of Atmel Studio .1417 (by as-installer-7.0.1417-web.exe) everything works fine, last time I updated from .1188. I know that Atmel Studio is based on VS 2015, but my web search showed me, that some VS 2017 users have exactly the same problem. (link1 link2)
Regards
TopWhere there's a will there's a way. I had the will, so I found the way.
Nonetheless, the release notes for the latest version should specify the disappearance of Percepio Trace.
TopI just upgraded to the new version of Studio 7 7.0.1417. I'm using Windows 10. Now I can not see any of my programming tools.
The Device Programming screen shows: "There are no Available tools"
I also get an error saying "The back end process exited with code -1073740791"
What is going on?. Should I try to go back to my previous version. I'm using Windows 10.
Arturo
TopIs the new version still unofficial? I cannot find it on http://www.atmel.com/tools/atmel..., there is 7.0.1188. I can't find release notes for 7.0.1417 as well.
TopThat's right. However, when I tried to install 7.0.0.188 it says there is a later version and asks if you would like to install the newest version. I clicked yes and I got 7.0.1417.
Arturo
Top7.0.1417 is official, it's just that updating the web site is a task that (obviously) takes some time. Not everything is running smooth after the merger.
TopThanks for your response. Unfortunately I got impatient and I decided to go back and install the old version I had which was working mostly. But It would crash with an error of "AVR8 Device Support". Therefore, I tried to re-install 7.0.1417 but I got the same error.
How can I get Atmel Studio installed again?
Arturo
TopFYI!
Thanks everybody for listening to my sorrow.
Arturo
Tophttp://www.microchip.com/development-tools/atmel-studio-7
TopYep... website says 1417.
TopWhat's the "MPLAB" component installed when this version is installed?
Should I be worried we will eventually be forced to use that inferior IDE?
TopSeriously? More than a month later and its still not updated!!! How hard is it to update a link?
Simon http://makin-things.com/
TopMy "soon" and yours are probably different. Why shouldn't theirs also be different.
TopWhat are you talking about... It's on the site...
:: Morten
TopMorten he is talking about the Atmel site link where people would normally go for Atmel stuff, it is still 1188
TopBut, Atmel didn't make 7.0.1417... :-)
(I'll ask the web guys to link over to the Microchip site...)
:: Morten
TopOh dear, things are starting to get "very interesting but stupid"...you may be to young to remember Laugh In.
TopHello,
TopHello,
What's going wrong and how can I install 1417?
Hans
Top"Dare to be naïve." - Buckminster Fuller
TopIt’s always looking for IronPython v2.7.0.4
I had the latest IronPython installed 2.7.5, that didn’t work.
I reinstalled v2.7.4 and that didn’t work.
I can find a specific version 2.7.0.4
Joe
If I try to create an Arduino project I get
If I click New Example Project I immediately get this
Joe
TopHi,
i installed AS 7.0.1417 on a Windows 10 64bit OS.
I have a AVR ISP MK2 Programmer.
In AS the Tools list stay empty, no Programmer, no Simulator.
Target is a ATtiny2313A.
The USB Device seems ok, and the programmer work with AVRDUDE.
Any Ideas?
TopSee if it works if you connect the MK2 and then run AS7.
TopApparently, an uninstall, reboot, reinstall, reboot fixed the problem.
Now to learn how to use it.
Joe
TopI have an error when i want to install the last version of AVR studio on windows 10
I need help, please
lolo
TopThe error message talks about an earlier version of "Microsoft Redistributable 2010" being present and that it is a "blocker" for installing Atmel Studio.
TopHi,
The version that i try to install is: 7.0.1417
my screenshot in text mode
OS Version = 6.2.9200, Platform 2
OS Description = Future OS - x64
CommandLine = d:\ac8c7fbe6640ed3b23c420963d\Setup.exe /q /norestart /log "C:\Users\cdt\AppData\Local\Temp\AtmelStudio_7.0.1417\\AS_20170702162238_0_VCRedistD10x86.log"
TimeZone = Paris, Madrid (heure d’été)
Initial LCID = 1036
Using Simultaneous Download and Install mechanism
Operation: Installing
Thank in advance
Laurent
lolo
TopIIRC, Microsoft has ceased maintenance of Windows 8.
If it's Windows Server 2012 then that is maintained.
via https://superuser.com/questions/680825/am-i-running-windows-8-or-8-1#680874
TopOK. My French is a bit rusty, haven't spoken or written in it for 40+ years, so had to look up "récente" , and of course it's the same as the English "recent".
TopCould anyone share the note "How to downgrade to use older Jungo drivers." referenced in the release notes for 1417?
The Server behind the embedded link http://atmel.force.com/support/articles/en_US/FAQ/Downgrading-tools-to-use-older-Jungo-driver seem to be down and Atmel sales support is not answering my mail...
Holger
TopMicrochip support helped me. The support articles have been migrated to the microchip site:
https://microchip.secure.force.com/microchipknowledge/articles/en_US/FAQ/Downgrading-tools-to-use-older-Jungo-driver
Maybe they should put this info into the old database offline-message instead of the useless standard message i've got....
TopReason : Windows 10 S
via https://www.askwoody.com/2017/curious-about-windows-10-s-mary-branscombe-has-an-in-depth-report/
Edit : third URL
Topscratch
Klaus
TopCan the next major version of Atmel Studio run on Windows 10 S?
Reason: Windows 10 Enterprise in S Mode
via https://askwoody.com/2017/where-windows-for-businesses-is-headed-details-about-win10-enterprise-in-s-mode/
Edit: typo
TopWhy does the "Update pack, The project is referring to a pack that is not installed" happen? Are these things that did not get downloaded installed with the main program install?
Top@Morten can (and will) probably correct me if I'm wrong, but packs installed when installing Atmel Studio will be updated/replaced with newer versions when you install a new Atmel Studio version. Packs you have manually installed will be left untouched. Your project was created before you updated Studio, and the Studio update upgraded the part pack.
TopGoogle Drive seems to blocks the files if it is syncing your files.
You may have the same thing happening with it or Dropbox.
0xA
TopPerhaps using my AVRISP MkII on Atmel Studio 7.0.1645 running under Windows 10 did not cause the degree of trouble for others that it did for me, but in case it did, here is how I fixed it. Firstly, the PROBLEM. Simply, after installation of Studio 7.0 my AVRISP MkII would no longer connect to the TARGET. The AVRISP MkII would not even show up in 'Selected debugger/programmer' window (entered by clicking on the hammer tool on the toolbar at the top). The only choices were "Simulator" or "Custom".
Anyhow, the upshot is that once that was in place, everything worked. I plugged the AVRISP into the computer USB port and good old Plug and Play found the Device, made a new look entry (see below) in the Device Manager table which I quickly examined in detail. Going through right click on AVRISP mkII and looking through the detail tabs of the information presented, I could see that I was now referencing winusb.sys of the system32 drivers.
TopI have tried to update studio 7 and succeeded in messing things up. I believe it is all related to CefShar.Core.dll or one of it's dependencies.
At least the following will no longer work:
I have uninstalled/reinstsalled multiple times
I have searched for all CefShap.Core.dll (they do exist in the atmel extentions)
I have cleaned all registry items i could find
I have deleted all residual folders I could find
Installing on a clean machine seems to work without issues so its something releated to my computer
I believe (but speak from a great amount of ignorance) that the issues is related to the search order of the ddls, but not sure how to configure that.
Does anyone any other ideas on how to solve this issue?
TopPages
