Reading Data from LCD
16 posts / 0 new
Hi Everyone.
I've spent the better part of the day trying to add a read data function to my LCD unit.  Everything connection wise is fine with data displaying correctly but due to factors in the environment i sometimes get interference that causes the screen to go ape and display garbage and you need to reset to get the display back.  I was hoping i could use the controller to read the data back and if a problem is found it could re initialize the display.  I haven't found much on the topic since most tutorials just recommend connecting RW to ground and keep it in write mode.  The test function i tried was to read the character back and compare with what should be there and if different to display the read character straight after it.  My basic approach was to just duplicate my send character function with it reading but since its in 4 bit mode i'm assuming i would need to read the 4 high bits and then the 4 low bits.  The result i get from every read is 0? I anyone has successfully done this could you perhaps spot the error in the code.  Ive gone through it over and over but still im missing something.angryIve confirmed the RW pin is in fact pulled high by using an LED.
int LCD_PROOFREAD(uint8_t ch){
uint8_t backread=0;
LCDsendCommand(0b00010000);   //move cursor to the left
LCDR|=(1<<LCD_E) | (1<<LCD_RW) | (1<<LCD_RS);   //Set the DDR as outputs for control bits
LDDR&=~(1<<LCD_D7);
LDDR&=~(1<<LCD_D6);
 LDDR&=~(1<<LCD_D5);
LDDR&=~(1<<LCD_D4);          //Set the DDR for the data bits to 0 to act as inputs
LCP|=(1<<LCD_RS);     //Pull the RS pin high for reading Data not command
LCP|=(1<<LCD_RW);  //Pull the RW pin high to read data instead of writing
 LCP|=(1<<LCD_E);   //Pull the enable pin high
delay_ms(1);    //Wait 1ms for data to settle
backread|=(LDP&0b11110000);  //Read the port with bit masking  bits 4,5,6 and 7 because they are the 4 high bits.
delay_ms(1);
LCP&=~(1<<LCD_E);   //Pull the enable bit low again
delay_ms(1);
LCP|=(1<<LCD_RS);  //Pull the RS pin high because we are working with data
LCP|=(1<<LCD_RW); //Pull the RW pin high because we are reading not writing
_delay_ms(1);  //Wait for the data to settle
backread|=((LDP&0b11110000)>>4);  //We read the Port with a bitmask just to read pin 4-7.  We bit shift  the bits 4 to the right to get the 4 low bits.
_delay_ms(1);
LCP&=~(1<<LCD_E);  //We now pull the enable pin low
                     if (ch!=backread) {  //Check if the character is the same
                    LCDsendChar(backread,0);  //If no match then display the character read next to the one it read
return(0);
Why not refresh (re-write) the display at regular intervals ?
From backread|=(LDP&0b11110000); I am guessing that the LCD datalines are connected to bits 7,6,5 and 4 of the LDP port.
Is that correct ?
The data sheet HERE might help.
It does refresh at regular intervals. The problem is that once interference discombobylates it, there is no recovering as far as i can see. For example calling clear screen has no effect from time of scrambling.
Sorry for wasting everyone's time. The LDP is defined as PORTB which i use to write to the screen. As per a previous problem with calling bit is clear on portB,1. Its not PORTB that i should read from. Its PINB that i should be reading from. The unit now works.
If your lcd is being upset by outside disturbances then i suggest you address that problem as software can't fix that.
We had it happen regularly in the past and weve made a lot of changes that has reduced occurences significantly but there is still that once a week/once every secomd week problem. The idea behind the reading is to shut the screen down and then restart and reinitialize the display.
If you need to reinitialise the display when it becomes corrupted, then why not brute-force re-initialise the display at regular intervals, (once per day, or even once per hour, depending on often people look at it).
You mean the idea is to identify when the display has become corrupted from the data that you read back?
Rather than just leave the display on - with the possibility of corruption - is it an option to just have the display active "on demand" ... ?
(although that is still just masking the symptom rather than curing the fault).
Lol. That was my original idea but then i get asked questions like "why do i have to push a button to be ablento read the screen?". Im not sure i can solve the real cause much better than i have unless i put a emi shield over the entire controller or move it to another location which again comes with a string of questions. Given its just a means to a greater end im going to have to settle for the time being.
Have you actually identified what/where the problem actually is or are you just throwing a solution to a problem without a known cause?
If it's a means to an end, then I would agree most with #8, re-initialize the display at a regular interval and see if that gets ya. However, that most likely wouldn't fix your root problem if it's a software problem like stack corruption, overflow, null pointer, or whatever other thousands of problems could occur. And throwing a software fix to a potential hardware problem would be even worse.
However, I stick to my original point. Try to find exactly where and what the problem is. It will be worth the effort put into it.
[Edit] Added "potential" after "software fix to a potential "
My digital portfolio: www.jamisonjerving.com
My game company: www.polygonbyte.com
discombobylates it
 And what does that mean in the English language?
The correct spelling is "discombobulates"
http://www.thefreedictionary.com...
No wonder I was discombobulated!
At least you were not disassembled...
Quotes for
Number 5 (Character)
from Short Circuit (1986)
Stephanie Speck: [they're heading for the cliff] Oh, no - Jeez! Number Five, we're gonna be killed!
Number 5: Disassemble?
Stephanie Speck: Yes, disassemble ALL OVER THE PLACE!
Number 5: No disassemble Number Five!
I've used character LCD read-back in a few apps over the years. [has OP really specified what "LCD" means?]
Background:  I started with the CodeVision character LCD library as my driver.  That driver is of the "busy flag" type.  So failing operations will hang.  I modified it to be "soft" and to time out and note/log/report the failure.  (I put essentially a dummy counter in the wait loop and abort the operation if too many passes.)
With that in hand, some apps will do the init and put out the welcome message.  I then read back one or two bytes out of the display's memory and compare to what I put out.  Actions on failure vary according to the app.
I use CodeVision's lcd_read_byte() routine.  I could post for examination if really needed.
I agree that discombobulation shouldn't happen in normal operation or bench testing, and the root cause should be determined.  However, I also cannot disagree with a mechanism to indicate a "live" display, whether part of POST (Power-On Self-Test) or periodically during operation.
NB:  IME the number one cause of character LCD problems is a ratty signal on the E line.  Especially e.g. in a lashup with fly wires.  (the small 'scope probe capacitance often clears it up, when probing E on the display.  so simply ship a 'scope with each unit)
