Transformer 25VA
7 posts / 0 new
Guys I have a transformer named as 25VA.It has two 12V tappings on secondary. See the attachment how I have configured.
I want to know how much current I can get from this transformer? Is it 25/24 = 1.04Amps?
If I need 2V,5V,12V (by adding regulators) do I still can get 1.04 Amps?
That is 1 amp, AT THE TRANSFORMER. If they are linear regulators, then the sum of all load currents must be less than 1A. If it is a switcher, then you can get more current out, because they are (approximately) constant power devices: input power = output power (independently, for each switcher).
The peak voltage after the rectifier will be near:
octave:1> (12*2)*sqrt(2) - 2*0.6
ans =  32.741
Edit: Rephrase for [AwNeil]
When drawing 1A from the rectified 32.7V you clearly have more than 25VA and the transformer will be overloaded.
You also ave to take the peak current into account when the transformer re-charges the filter cap.
For a regulator with 12V DC output it would be a lot better to use only one of the 12V windings.
You'll have about 16V n the Elco then, which is enough margin for the ripple voltage over the Elco.
More voltage means more heat in the regulator, higher load for the transformer and more money to your electricity distributor.
Paul van der Hoeven.
http://www.hoevendesign.com
Joseph1 wrote:
Guys I have a transformer named as 25VA. It has two 12V tappings on secondary.
Actaully, if your drawing is correct, is has two 12V secondary windings.
It makes like much easier if you embed the image in the post where we can see it:
See the instructions here: https://www.avrfreaks.net/wiki/em...
Yes: VA = Volts x Amps - so 25VA / 24V = 1.04A
The rating applies to the Transformer - it is irrelevant how you distribute it.
But, as noted, getting 2V, 5V, 12V from the above arrangement using linear regulators will be grossly inefficient!
Paulvdh wrote:
You can not draw 1A of current out of the transformer in this way.
Eh???
If the two 12V windings are independent, I would parallel the two 12V windings.
David (aka frog_jr)
Taking care to connect them the correct way around!
surprise
http://www.electronics-tutorials...
