Problems with compilation/linking
5 posts / 0 new
Hi Freaks!
I've decided I've got better to do than play with
AVR peripheral registers directly, so I just downloaded a copy of AVRLIB so that I can use the peripheral handling functions.
I installed AVRLIB into this directory tree:
--AVRLIB
Atmel----WinAVR
--KamAVR
--Projects----MyProject
I have tried to start with the I2C libraries. I copied global.h and i2cconf.h to the MyProject directory where I have my C source code.
If I try to compile with the following includes
//LIBC stuff
#include
#include
#include
#include
//AVRLIB stuff [Project Specific stuff]
#include "global.h"
#include "i2cconf.h"
#include "../../AVRlib/i2c.h"
I get the messages "global.h: no such file or directory" and "i2cconf.h: no such file or directory" as errors occurring in i2c.h.
On the other hand, if I copy i2c.h into my project directory and change to includes to
//LIBC stuff
#include
#include
#include
#include
#include "global.h"
#include "i2c.h"
I get the messages "undefined reference to XXXX" where XXXX is the name of any library function I use in my code.
How can I solve this? Did I do womething wrong while installing AVRLIB? Am I doing the includes in the wrong way?
Thanks for any help!
nxp
[suffering from includophobia]
Maybe consider using -I on the CFLAGS to instruct the compiler to look in other directories for the .h files?
Cliff
nxp wrote:
I've decided I've got better to do than play with AVR peripheral registers directly,
So, instead, you're playing around to get this Library working!
Perhaps the registers weren't so bad, after all... :wink:
Sounds like you have included just the haeder files, but not linked the actual Libraries themselves?
Remember, a header file contains no code - it just contains promises to the compiler that certain functions will be provided "elsewhere".
The compiler takes your word for this, and generates code that needs these functions to be provided.
You fulfil the promises by providing both the compiler output and the Library files to the Linker.
If the Library files are missing, the Linker will complain saying, "undefined reference to XXXX"
In other words, it is saying, "You've used XXXX - you said you'd provide a definition for it, but you haven't!"
Ok, it seems I was doing a newbie's mistake. I had been under the impression that including the h-file was enough to tell the compiler which functions I needed to use. I beleived that the installation for AVRLIB would have provided some form of library table to GCC and then the header just tell it which files to choose. Seems I was wrong.
Does such a system like the one I assumed exist anywhere? Does GCC provide any way to code something like that?
Including both the .h and the .c files in my project allows it to compile.
Just one last thing - I2C.c needs the rprintf functions, and as far as I can see they are only message and error outputs describing what's going on at a low level. If I dont think I need them, can I comment them out and not include the printf and uart functions?
nxp
[to include or not to include?]
Yes, including the h files does tell the compiler - but that's all it does. There also needs to be something that actually provides the "bodies" of those functions.
See previous reply.
Usually a "Library" does mean a compiled binary object that you just have to link to your project.
However, it seems that this particular library is a source library - ie, just a collection of source files that you have to compile for yourself.
