warning: missing braces around initializer
5 posts / 0 new
When I compile the following fragment I get the warnings shown below. It compiles ok with VC, so I believe it is an issue with AVR-GCC, but i could be wrong.
#define MAX_OUT 3
#define NUM_AUD_LVLS 2
static const unsigned char phys_audio_out[MAX_OUT][NUM_AUD_LVLS]=
// Source Left Right
{ 0x1F, 0x20, // 1
0x21, 0x12, // 2
0x13, 0x24 }; // 3
audio.c 6:warning: missing braces around initializer
audio.c 6:warning: (near initialization for 'phys_audio_out[0]')
admin's test signature
VC is wrong. GCC is correctly pointing out a syntax error.
phys_audio_out is defined as a 2-dimensional array, or said another way, an array of arrays. When initializing this variable, the data must take on the same type structure of the variable. The data that you have is a 1-dimensional array, which is not the same type as the variable. Change the declaration to below:
#define MAX_OUT 3
{0x1F, 0x20},
{0x21, 0x12},
{0x13, 0x24}
So now you have phys_audio_out declared as a 3-element array with each element being a 2-element array of constant unsigned character. The data initializer now matches the type.
Eric
Had the same issue, solved using your solution @eric. Thanks a lot :)
Opening up a 15 year old grave is just plain stupid.
Locked.
It may be unusual to open up such an old thread, but it certainly is not "stupid" as the post is only thanking someone for providing a solution to their problem.
Its also commendable that the peraon took the time to search for an answer rather than simply start a thread.
Unusual yes, stupid....certainly not.
Just my two pence
Why is there a "Highway to Hell" and only a "Stairway to Heaven"? A prediction of the expected traffic load?  - Lee "theusch"
Topic locked
