stk 500
5 posts / 0 new
I want to connect a LCD display to my stk 500. Do some have schematics for this connection?
What socket shall i use? I suppose it is possible to use the expand sockets.
Display i want to use is: 2*24. (14 pins socket).
admin's test signature
why dont you just use the i/o port's on the bottom of the board. like porta,b,c,d
Hi Per
You can have a look at the Codevision website (see Tools on this website), download the evaluation version of the compiler, install it and have a look at the LCD example. It includes the connection diagram. It's by far the easiest way to get an LCD going. Get yourself a ribbon cable with a 10 pin header socket on the end, solder the other end into your LCD and you'll only need 1 port to drive an LCD from your STK500. It works a treat!
Hi Per,
i use an LCD with the STK 500, and it works (with AT90S2313 only) If you need more
information like connecting-sheets, write a mail to Grilec@t-online.de
