Problem insufficient voltage
26 posts / 0 new
I connected 1st 7segment display to port d,
2nd to port c ,3rd to portb ,4th to porta
Problem is ..1,2&3 are getting enough voltage
But 4 is not getting enough voltage
Salman
Pic
Salman
And your schematic is?
It makes life a lot easier if you embed the image in your post - where we can see it - instead of attaching it
Instruction here: https://www.avrfreaks.net/wiki/em...
That's quite a mess of wiring. So the first thing to do is to draw a proper schematic, then re-wire neatly according to the schematic.
Post your schematic.
If tidying your wiring doesn't work, then take voltage measurements, and mark them on the schematic.
Remember that LEDs work on current rather than voltage as such - so check that your resistors are actually the correct value ...
Basically making clock
Salman
Sounds like the classic: AVCC not or improperly connected. It has to be connected to VCC. If you intend to use the ADC, put a low pass filter in between. Consult the datasheet for specifics.
"Some people die at 25 and aren't buried until 75." -Benjamin Franklin
What is life's greatest illusion?"  "Innocence, my brother." -Skyrim
Post your schematic - also known as "circuit diagram"
Here is it...I'm sorry if its not clear
Salman
So you have no resistors to limit the current?
No ...I didnt use resistors
Salman
Wow.
And apparently didn't look in the datasheet about AVcc.  And haven't told us what microcontroller is being used.
If you have the pins, then indeed one could connect each segment to a port pin.  In practice, we'd set up a multiplexing scheme to drive one 7-seg at a time.  So total pins would be 7 or 8 for the segments (often there is a dot.  and a colon for time display can use the dots from two adjacent digits with one mounted upside down), plus one for each digit.
Do u know the multiplexing scheme for operating 7sg
Salman
Seriously - on the entire World Wide Web, you can't find anything about multiplexing 7-Segment displays?!
Or the need for current-limiting resistors with LEDs?
I'm sorry what is ADC..I looked up data sheet cant find it
Salman
Thanks I'll do it..
Salman
Do you have access to Google?
Have you searched this site?  How many discussions did you find in the forums?  How many did you find in the Projects section?
How many did you find in AVR app notes?
ADC = Analog-to-Digital Converter
You still haven't said what chip you're using for this.
In other posts, you have referred to ATmega16
Unfortunately, in the "rebranding", Microchip seem to have lost the Full datasheet - and only list the summary on the Product Page:
http://www.microchip.com/wwwprod...
angry
If that's all you have, you will need to do some googling to find the Full datasheet (the one that doesn't say "Summary").
Indeed.  We don't even know whether it is an AVR.  How could the PDF reader fail on a search for "ADC"?!?
Omg...dont get frustrated... Cool cool..I'm a beginner..and your way of answering ...is pro..I appreciate it
Salman
Everyone would be cool if you simply answered the questions.
Moderator
Back to the original question, you need to put resistors in series with each output to limit the current to each segment, this will also help to distribute the current evenly. In fact, I bet your power supply can't handle more than 500 mA or so of current, or else you would have burned the LEDs and the CPU.
Also, if the CPU you are using has more than one VCC and one GND, remember that all power pins must be connected.
With your connection scheme, you will need 4x8 resistors (I'd say 470 ohm or 1k ohm should do). Where do these values come from? Each red LED has about 2V voltage drop, so if you are using a 5V supply, the resistor has to drop 3V and let pass a maximum of 10mA current for a typical LED, so R = V/I, 3/0,01 gives 300 ohms as minimum resistor value.
That's why we normally use multiplexing, this way you would need much less pins, wires and resistors.
More likely, it is the resistance of the MCU's output drivers that is limiting the current to each segment.
Here's a good site on basic electronics: https://electronicsclub.info
And, specifically, how to calculate LED resistors: https://electronicsclub.info/led...
LED resistor circuit
It will -- but will that limit violate Absolute Maximum Ratings?
Let's do a little noodling.  From the picture shown, that is a red 7-seg?  Let's say Vf of 2V to 2.5V.
A typical 20mm/0.8" 7-seg has an Absolute Maximum Rating of 30mA per segment.
Assuming OP is using Mega16 at 5V. that model has pretty good pin-driver strength compared to newer smaller-feature-size generations.  Chart below.  To get to an output V equal to the voltage drop, that would be 70mA or more.   So that is twice the AMR for that size 7-seg.
Besides the limitations on the sum of current draw, the Mega16 has AMR of 40mA per pin.
So AMR are violated for both the AVR and the 7-seg.
Thus, OP could
, right?
[edit] Forgot the chart
You're right - if the OP hasn't burned the LEDs and/or the IO pins (s)he should be feeling quite lucky ...
Solved... Thanks everyone
Salman
To help anyone else who has the same problem in the future it is considered polite to explain how you solved the problem.
