"High" is half a volt?
22 posts / 0 new
I've been using some TSOP2438 infrared receivers to detect trains and the like blocking flashing IR LEDs for quite a while now, but I've been stuck for several days on a project with 3 of them. They're stuck in my breadboard with an arduino and a bunch of wires.
They detect the IR LED just fine. I have the LED flash at 38KHz for 1mS then turn it off for 3mS. The problem is, these 3 only give me a high of about half a volt, way too low for the arduino to detect as a high. I can see the expected waveform. First thought was I had the arduino pin misconfigured, but if I disconnect the output pin from the arduino, the signal stays the same. Power? Nice steady 4.38v, well within the range for the part. The datasheet for the TSOP2438 shows an NPN output transistor and a 33k pullup inside the pack. I've tried it with an external pullup but still get the same low waveform.
Ok. Maybe the high is .6v, but I'm still mystified. The blue trace is the VCC supply. The yellow trace is the unloaded output. You can see a little noise on the VCC as the IR LED is flashing.
Ideas?
(Sorry, toes don't show in either photo, but they are indeed bare.)
Are you talking about the 3 legged device? I see a Green, a Yellow and a Brown wire connected to that but I don't know which wire is which.
Do you have a datasheet for it? (ie is it connectd correctly?)
Does it require a pull-up resistor? What happens if you add one, just as an experiment?
He did try a pull up, my concern was that it is wrongly connected (don't ask why I suspect this....)
They seem to have a standardised pinout with GND on the centre pin (2) and output on pin 1, I guess the Brown wire, which seems to be connected to the LED also and therefore suspicious.
In my experience, when debugging seemingly simple stuff like this the first thing to do is to clean up your own mess.
In your case this probably means:
Use the "bus bars" on the breadboard for power supply.
Always connect Vcc / GND of components directly to the "bus bars". (So it's easy to optically verify which are the power lines).
Put in some decoupling caps directly on the bus bars and/or directly over the IC's.
Remove unneeded wires or rebuild a part on a separate (part of) the breadboard.
For example. Sensor seems to be in "32", "33", "34", but there is a single wire going to "35". What's that for? Is that supposed to be Vcc? (Again, use the "bus bars").
Is the GND of the scope the same as the GND of your breadboard?
And it's often in the silly compartment. Broken wires, bad contacts on BB, bad batch of sensors, sensor swapped 180 degree but that all seens to obvious.
Connect the scope to Vcc of the sensor. It could be that the source impedance is to high z(bad contact) and your NPN transistor (with 33k) shorts Vcc to gnd.
Can you post a schematic of whats on the BB?
Who else thinks the 0.6V looks suspiciously like a diode drop ?
Total votes: 2
or perhaps a 10x probe :)
Hmm. Rebuilding the circuit.
Oddly, these have the + in the middle and - on one side:
Was surprised to get ALMOST the expected output. The puzzle, of course, is these are familiar parts I've used before, in fact, right on this same breadboard with a similar circuit just a few days ago.
Maybe you have one with the "standard" pinout like the TSOP44 (top line)?? They seem to be Vishay brand.
I have ground and output swapped. I wired it as if it's facing me, but it points the other direction.
Put a boot on the right foot and step one the toes of the left foot now......
For Torby, just putting the boot on would be punishment enough!
Ah Ha! That explains the diode drop then.
What I find surprising is the miswired device was nearly working.
Total votes: 2
Bet SOME of you thought I didn't even HAVE boots:D
It's amazing what one can do with Photoshop these days ;-)
  ROFLOL
+1yes
David (aka frog_jr)
hehe
It's not even photoshopped, that's just someone else's boot.  Maybe a dual boot?
No its definitely only a single boot
Ok, I believe it is time to reboot this thread...
David (aka frog_jr)
