Using print_dbg() function
4 posts / 0 new
Hi Freaks,
I am experimenting with AVR32UC3C and AVR ecosystem in general. Going step by step, I am facing something weird with a simple (I think it is) problem case. But I'm stuck. Here is my code :
#include <stdio.h>
#include <asf.h>
int main (void)
	/* Insert system clock initialization code here (sysclk_init()). */
	board_init();
	sysclk_init();
	init_dbg_rs232(sysclk_get_pba_hz());
	/* Insert application code here, after the board has been initialized. */
	char str[20];
	sprintf(str, "Hello World !\n");
	print_dbg(str);
	return 0;
I have added the "system clock controle" and "USART debug strings" services to the project with ASF Wizard.
When I debug it, when reaching the print_cbg(str) instruction, it feel like something is frozen. I have the Bray's terminal waiting anything but vain.
If someone has  any clue, I would appreciate.
Thank you in advance.
Gnull
In embedded programming, main() should never return!  You need a forever loop!
With most toolchains, when the main() exits, it turns off interrupts and goes into a forever loop of its own, if your usart needs interrupts to perform its output, you are out of luck.
https://www.avrfreaks.net/comment...
Hello @ki0bk and @awneil !
First, thank you your answers. Second, sorry for my delayed response.
@ki0bk
You're right. I won't write this king of main anymore for embedded applications. ;)
@awneil
The reason why I tried UC3 was the 4+ USART channels in 5V... That allow me to restrict the number of parts on my board.
