Converting ADC digital value into degrees Celsius
23 posts / 0 new
Hello !
I'm making a thermometer and I need to find an efficient way of converting the ADC digital value to degrees Celsius.
That's what I've done for now.
switch (ADC){
case 496: temp = 21; break;
case 497: temp = 21; break;
case 498: temp = 21; break;
case 499: temp = 21; break;
case 500: temp = 22; break;
case 501: temp = 22; break;
case 502: temp = 22; break;
case 503: temp = 22; break;
case 504: temp = 23; break;
case 505: temp = 23; break;
case 506: temp = 23; break;
case 507: temp = 23; break;
The actual code goes from 20 degrees to 30 and the list is already quite lengthy. What if I decide to make a temperature range from -40 to 40 degrees ? Is there a formula or something to make the conversation simpler and quicker ?
Plot your readings versus temperature on a graph. If it's a straight line you should be able to get the slope and crossing point for a y=mx + c function. If it's none linear you probably want to break out Excel and do some curve fitting to get the coefficients for some none linear function.
What are you using for a temperature sensor? There might be a library you can use and make your life easy.
I'm using KTY81 110. And I made a graph.
Is there a formula for this graph which will tell the temperature for the given ADC value ?
Subtract 494 and divide the remainder by 4; then add 20.
Neil
Oh my god, how did you come up with this ? I've been twisting my head like all day and did not make anything that would work. Thank you !
And to make it cleaner start at 0
subtract 414 and div with 4.
The 414 id 494-20/(1/4)  ;slope  = 1/4
How did you come up with that ? Is there some rule for this kind of slopes ?
Did you really go all the way through school with no one ever teaching you that a straight line was y=mx+c?
To be honest, I don't remember that from school, maybe I skipped that day when they were teaching that.
Well the modern student may well use some Regression and curve fitting software like Matlab or perhaps a spreadsheet rather than getting out the maths textbooks. Now your graph was almost certainly produced in Excel or similar so you were very nearly there. All you had to do was right click on the plot line and choose "Insert Trend Line". Here's Libreoffice doing that:
You were lucky that KTY81 is highly linear and Neil Barnes could calculate a good fit in his head. A more non-linear sensor would provide more of a mental challenge which is where software like this is a massive boon.
PS: You should be able to identify how Neil's (divide 4) maps to the linear regression equation.
PPS: That plot line wasn't created by experimentation was it ? Did you actually use an equation to generate it ?
Yeah I've got the calculations to their place. I made the graph on some random website and draw it buy putting the coordinates of the points. With KTY81 110 things are quite linear from 20 to 30 but get a little bet more curvy from there on.
I thought there may be a short-cut but I just pulled up the datasheet. They don't give an equation; only a temperature / resistance table at (mostly) 10°C steps. So drawing a graph and regression analysis is the way to go.
I think the easiest way would be drawing polynomial regression in Excel or a similar program.
This thread intrigued me - I wondered how you could get LibreOffice to do such a curve fit so I went googling and found this Youtube video...
It was worth the price of entry just to see how this guy moans about what a real engineer would really want (and not want)! :-)
An engineer would never use so many superlatives...
His teachings are strong.
"No scientist or engineer would ever consider drawing this graph"
- A guy from that video.
LightningWalrus
clawson
LightningWalrus
less than a day later........
LightningWalrus
Someone is a very fast learner.
David
N Winterbottom, you live around the corner from me!
My approach was a little more ad-hoc, based on simple examination of the signal rather than actually plotting a line - though of course the process is mathematically the same.
  1. assumption: this is coming from some sort of digital sensor; these are generally quite linear in the area of interest
  2. assumption: the output is actually not drawn correctly (the software has joined the dots); inspection shows that there are four values for each degree <--- here's the divide by four
  3. the first value mapped to 20C was 494 - so subtract that and you'll get a value of 0 for 20C, 4 for 21C, 8 for 22C etc.
  4. do the divide by four so you get a value above 20C
  5. and as the last stage add 20 to get an actual temperature value.
Neil
Ummm--Algebra 101?  Or is it Trig or Geometry?  Anyway, I'd assume if one was going to do work such as this, there would be familiarity with y=mx+b.
It certainly looks "regular", but the slanty slopes are confusing, as well as the same exact degree result all the time, spanning several ADC counts.
He got that from the table you posted... When the reading increases by 4, the temperature increases by one, so slope (Δx/Δy) = 1/4. The slope is m in y=mx+b. You can then calculate b.
switch (ADC){
case 496: temp = 21; break;		//21.0
case 497: temp = 21; break;		//21.25
case 498: temp = 21; break;		//21.5
case 499: temp = 21; break;             //21.75
case 500: temp = 22; break;		//22.0
case 501: temp = 22; break;	        //and so on...
Well the guy in the video did say:
Perhaps he was right after all. smiley
Neil
Wow thank you! easy peasy
mikkesskoteruthyrning
