Change of Eagle Ownership and Licences
67 posts / 0 new
Pages
@microcarl
Diptrace supports Linux(WINE).
THere is a Freeware version if you want to take it for a spin.
microcarl wrote:
ka7ehk wrote:
I've not been able to figure out from the Eagle web site - If you purchased (big money, like MicroCarl - mea culpa)  a previous version and do not "upgrade", is there anything preventing you from continuing to use that now "old" version?
I can still use my copy of Eagle 5 - on a Windows machine.  The Eagle 5 license is perpetual, as long as you have the original CD and license key.  But...  I only have one Windows machine left - every other machine has been moved over to Linux and I really want this last machine running Linux, but not until I have decent design & development tools running on Linux.  I had been considering shelling out that second $995.00 for the Linux version of Eagle.  But that won't happen now!
So the question is, do the new Eagle owners still offer a free evaluation version that allowed 100mm X 40mm board size?  In a lot of instances, PCB's are 100mm X 40mm, or less.  So the evaluation could still be a viable option for smaller projects.  Many times, I'll place several smaller (but different) board patterns on a single 4" X 6" PCB blank so as not to waste PCB board material.
Does it run under WINE?
Yes for versions 5 and 6; last test was about a year ago.
https://appdb.winehq.org/objectManager.php?sClass=application&iId=698
Here is a pricing matrix courtesy of http://hackaday.com/2017/01/19/a...
It doesn't say, but I assume the "Free" one also has non-commercial restriction.
Bob. Engineer and trainee Rocket Scientist.
jporter wrote:
Most serious board designers vet their own footprints, so this is a minor annoyance.
That's what ones at Olimex did to some of their footprints in KiCad to match their automated PCBA process.
jporter wrote:
The nice thing is that KiCad stores the files in a human readable format.
Olimex's KiCad component libraries don't have any AVR but do have a PIC10 and a PIC16.
Olimex's KiCad footprints have a 0.65mm pitch BGA (for a 64-bit ARM Cortex-A53)
P.S.
Ones at Olimex started small with KiCad for new designs but worked their way up to a complex multi-layer PCB design; took them about one year.
https://olimex.wordpress.com/2016/08/26/olimex-kicad-components-libraries-are-uploaded-on-github/
... again we did these as the KiCAD default libraries are made up to vendor datasheets and may not work well in our own production process.
To give you example: TQFP 0.5 mm step ICs per datasheet must have 0.3 mm width pads with 0.2 mm spaces between the pads, but using our process this yields in lot of shorts, so we made them with 0.25 mm pads width and 0.25 mm space, the 120 um thick stencils we use give best yield with 0.23 mm pad opening for solder paste – this may be not optimal for other manufacturer process who use other thickness stencils etc. BUT it works best for our technology and process based on our experience and tests.
https://github.com/OLIMEX/KiCAD/blob/master/KiCAD_Components/OLIMEX_IC.lib
https://github.com/OLIMEX/KiCAD/tree/master/KiCAD_Footprints/OLIMEX_IC-FP.pretty
https://olimex.wordpress.com/2016/02/17/a64-olinuxino-64-bit-arm-oshw-designed-completely-with-kicad-is-live/
https://olimex.wordpress.com/tag/kicad/
https://github.com/OLIMEX?language=kicad
microcarl wrote:
Free version of Eagle is now 80mm x 80mm.  It used to be 100 x 100.
I know KiCad is free, but I thought I would post the prices for the software I use.
Both wrong. It used to be 100 x 80 mm (half euroboard), now it is 80 cm².
Stefan Ernst
I missed the cm², so that's about 89mm for a square board, but it allows you to make longer skinnier board if needed.
80 square cm? That is not so terrible, but not great. That is a square board 8.9cm on a side (3.5" on a side, more or less).
Jim,
That is the same as it has always been... 100mm x 80mm. Except it is unclear if the marketing people could not fit those two fixed maximum dimensions in their advertising summary so they "did the math" and came up with 80cm2. As far as I know you cannot exceed either the 100mm or the 80mm limits. So same as before.
Ross (long time user, but probably jumping ship soonish)
valusoft wrote:
Jim,
Previously the free version of Eagle had restriction of 100mm wide by 80mm  high.
Also, I have seen screen shots from an Eagle version ('Maker' if I remember correctly)  where you set the desired X  and Y dimensions of your PCB and so long as it was below the area threshold you were good to go.
I suspect this is how it is with the v8 freeware.  Personally I keep away from new releases until around  the x.4 version as there are many bugs prior to then. It is turning out to be the case with v8. There are plenty of silly errors being highlighted.
(@all) The freeware version can open a previous design of any size and you can produce the gerbers for that design.  Should you have commenced a subscription, you need to connect to Autodesk at least every 14 days to maintain your functionality at the level you subscribed to. If you do not, the software drops back to Freeware mode. In that mode you don't have to connect to Autodesk every 14 days. There is one remaining gotcha. Should your PC die and you need to rebuild it, then you will need to connect to Autodesk to download the free version again. You revisit and download using  the Autodesk account you created when you first downloaded v8. The concern is that you may not be able to reach Autodesk on that day. You may have saved and backed up the original freeware you down loaded but that software once re-installed will still require you to go on line once to permit its use. So there remains the situation where you will not be able to access your Eagle designs. This does not happen with versions earlier that v8 so keep that software safe for this scenario.
Moa
valusoft wrote:
They could simply stop supporting that version... following on from M$'s lead.
Well, I do own a licensed copy of Eagle, version 5.  CADSoft stopped supporting v5 when v6 came out !  But they would've been quite pleased to relieve me of another $1,000.00 for the upgrade to v6 or v7...
I went to the Cadsoft site (which directs you to AutoDesk) and hunted around for the 7.x downloads.  I figured I might as well get all my machines up to the last legal version I can run, which would be 7.7.  Well you won't find it on the website anywhere.  I search in the support forum where many users where asking the same thing, and Jorge has posted the ftp site for all the downloads - ftp.cadsoft.de/eagle/program
But that's very common; supporting old versions of software is nigh-on impossible for companies.
Thanks much for the link.  I went and grabbed 7.7.  I don't suppose you have the changelog from 7.6 to 7.7, do you?  Ah well...
What really terrifies me (and this may give those from AutoDesk who read these things a horrible idea) is that they'll just quietly tweak all the user-uploaded libraries and ULPs so that they refuse to work with previous versions.  I had for many years a complete (unlimited, autorouter, everything) copy of 4.12, but I eventually got totally sick of downloading what looked like a cute new part library only to be told "Doesn't work with this version".
Note that in no place was it mentioned exactly what revision of Eagle the library was compatible with before downloading it.  You could only pray and try.
And by then the fully-paid-up version  was old enough that it wasn't worth any credit at all on the upgrade.  Oh well...
S.
PS - I've never sent out an autorouted board to production.  Despite having it, and occasionally using it mostly for grins, I've always ripped up everything it did and re-layed all the traces by hand.  I.
Pages
