SAM D20, programming using Open OCD
8 posts / 0 new
I have just ordered the Atmel-ICE from Mouser and it will take a week to be delivered. So in the mean time, I had a spare Raspberry Pi 3 lying around which I decided to convert into an Open OCD SWD debugger using Adafruit's tutorial. So my question is, do I need to flash the SAM-BA bootloader before I flash the bin/hex/elf file of an application built on Atmel Studio 7 using ASF ? Or can I directly flash the hex/bin file ?
Newbie to the world of Atmel SAM D microcontrollers.
you don't need sam-ba for swd loading or debugging. yes, you can directly flash the bin/hex file.
Thanks Kartman for the quick reply. Am I better of flashing the hex file or the bin file ? This is using the Open OCD flash command right ?
** Wrong post - admin please delete **
Hey Russell,
I flashed the hex file onto the SAMD20G using OpenOCD. After which, I configure the OpenOCD to only init and targets.  If I run "sudo openocd", the state is shown as "running". But if I power cycle and run "sudo openocd", the state is shown as "reset". Does this mean a bootloader is necessary if there is going to be a powercycle after flashing the SAMD20 ? Or is it because the WatchDog hasn't been disabled ?
you shouldn't need a bootloader - openocd loads the code. I did a quick Google for samd21 openocd
https://community.atmel.com/forum...
samd20/21 are similar
Cheers Russell, you have been very helpful mate.
I have a feeling the power cycle was leading to Reset which is active low, remaining in that state. Hardware guys haven't put a capacitor or pull resistor(100K) for that pin. I'll ask them to look into it and double check tomorrow.
Indeed; and, as far as debugging/programming, they are identical.
