Asus jumping on the Raspberry Pi "Me Too" bandwagon
2 posts / 0 new
TechRepublic wrote:
The Raspberry Pi has a new rival, the more powerful but slightly pricier Asus Tinker Board.
The Asus Tinker Board has a faster processor and more memory than the Raspberry Pi 3, but sells for £55 ($68), considerably more than the £33 or $35 Pi 3.
http://www.techrepublic.com/arti...
The colour-coded header pins are a really neat idea!
As the article says, currently on back-order: http://cpc.farnell.com/asus/90mb...
But that is £55!?! Hardly in Pi territory. I remember when I was working on something using Intel motherboards to run as a Linux SBC and we were paying something like £40..50 at the time. So £55 isn't going to exactly set the world on fire.
