Can someone suggest a good freeware terminal program that they have had success with working with AVR USART. I have been trying Realterm, but I have had problems with it. Windows XP.
Can someone suggest a good(free) terminal program?
Tera Term pro? http://sourceforge.jp/projects/ttssh2/releases/
Can you use Hyperterminal? (comes with windows, I guess you know) Even though it is not the best, unless you need some fancy stuff then it should work.
I've had a heck of a time getting it to talk to the USART, but now I think that I have clock problems that I have to work through.
Another vote here for Teraterm but also note that there was am long thread in "Off Topic" in which folks recommended the various terminals they use so fo a balanced picture I'd search out that thread.
Do a search for Bray's terminal--its great.
hterm is also a funny tool - for Windowz and TUX
I installed Bray and it works like a champ. Definitly the best of the bunch. I never did figure out real terminal. Thanks for the suggestion.
Do any of these above terminals support ANSI term command set on a UDP connection?
HyperTerminal almost gets there with TCP but not UDP.
Neil.
maybe teraterm
generally, I much prefer Bray's Terminal
Hi Steve,
Neither Bray's or TeraTerm support UDP :(
Neil.
How about uCon? :wink:
I am happy with the result, John, but I also appreciate the fact that you took the time and energy to reply to my post. Thank You. I do not post often, but I do visit this site daily. I thank all of the regulars for their willingness to share their knowledge. I have learned a geat deal from this site, and I wish all of you long life and Happy Holidays. BTY I searched extensively before I posted, and I did not turn up that thread.
Hi John,
Seasons greetings to you.
I have not seen ucon before but at $795 it's a bit beyond my xmas present price.
We will have to catch up for coffee someday :)
Neil.
try putty, its main focus is to communicate via lan (ethernet) but serial is also supported
You can get it here http://microcross.com/html/micro... half way down the page. I just downloaded the latest version V6.7. Of course I keep the older versions too, I have the unofficial V6.8, so perhaps the one on the website is the official release with the changes I asked for and bug removals.
try with this: http://www.hw-group.com/download...
or this: http://braypp.googlepages.com/te...
Hi Steve,Neither Bray's or TeraTerm support UDP :(
Neil.
BLIPS (projects section here) does UDP with terminal emulation, but just bare bones terminal, not ANSI or vt100
John,
I did a search for ucon +udp and found this site.
http://www.kepware.com/Products/products_UCON.html
It's what I thought you were refering to.
Neil.
John,I did a search for ucon +udp and found this site.
It's what I thought you were refering to.Neil.
$800 purchase price is a bit at odds with the OP's freeware goal.
Putty. Works on Windows, works on Linux. It's all I use these days. Spend the time to properly learn to use it.
I tried putty with a serial port. When I click OPEN, there's a beep but nothing else happens. Tried two known-good serial ports. Nothing in the docs.
win xp admin user
Try docklight it has everything.
ASCII/HEX/Binary view/sending, predefined string (full strings or partially defined), TCP/UDP terminal, of course RS232 terminal, scripting to set automatic answer/action to some strings..
And free version gives you all you need.
Their homepage is http://docklight.de/
Only 9 years later... wow! Glad he isn't in a hurry...
