at32uc3a3 Dev-Kit and LIN bus
5 posts / 0 new
Hi
as the documentation is very sparse on this I'm wondering if someone can help me out on this topic.
We bought a AT32UC3A3-XPLD to evaluate the communication between the AT32UC3A3256 and a LIN-BUS device.
The microcontroller will most likely be the base of a custom board if everything works as expected.
Do I need something more - e.g. a level shifter or a MCP2004 IC - to connect the Dev-Kit to the LIN-Bus or will it work out of the box?
The getting started guide gives examples for LIN-BUS slave and master, but gives no more information whether the DEV-Kit or the microcontroller can be connected directly to the LIN-Bus...
This is really puzzling me at this point.
Martin
Given your assessment of the documentation, and the fact that the future of AVR32 looks doubtful, is this worth pursuing ... ?
See, for example: https://www.avrfreaks.net/comment...
Hi
is there any official blog post or something, so I can present this to my project manager?
Not sure, but Cliff has just restated it here: https://www.avrfreaks.net/comment...
You should probably contact your FAE / Sales Rep / Distributor.
But, "legacy" status aside, why would you pick a proprietary, single-source, niche architecture these days ... ?
