Error after removing all lines of the project C file
23 posts / 0 new
I just started working with Atmel Studio 7.0.
First, I got the errors related to <util/delay.h> then, after I solved it I got the new error even if I remove all lines from the project, the errors are not solved.
Even if I compile with this default Atmel Studio C file sketch, the error is not going and I have to open a new project!
This is my work picture:
1. show the compiler output
2. rebuild all
Keith Vasilakes
Firmware engineer
Minnesota
Also, those errors are for project 1, while you showed project 2...
:: Morten
wolfrose wrote:
..after I solved it I got the new error even if I remove all lines from the project, the errors are not solved.
The errors show 'no such file or directory'.
Do any of the directory folders or the user-name folder have any unusual characters in the name?
1. OK in the following screen copy.
2. There are 3 options, build, rebuild and clean. I didn't see build all. But I think clean is similar to build all but I'm not sure.
Even if I closed Atmel Studio and open it again for specific project, it would still the same error.
... and copy the contents of the output window and paste it here (output in the bottom left in your screenshot)
:: Morten
How? I can't because of these errors, I can't get the output results which shows the details of the build. Unless I open a new project and build it.
Open the output tab (visible in the bottom left, or by going to View-Output) to show the full error message.
:: Morten
------ Rebuild All started: Project: GccApplication1, Configuration: Debug AVR ------
Build started.
Project "GccApplication1.cproj" (Clean target(s)):
Target "Clean" in file "E:\Program Files Directory\Atmel\Studio\7.0\Vs\Compiler.targets" from project "C:\Users\wolfrose\Documents\Atmel Studio\7.0\GccApplication1\GccApplication1\GccApplication1.cproj" (entry point):
Task "RunCompilerTask"
Shell Utils Path E:\Program Files Directory\Atmel\Studio\7.0\shellUtils
E:\Program Files Directory\Atmel\Studio\7.0\shellUtils\make.exe clean
rm -rf main.o
rm -rf main.d
rm -rf "GccApplication1.elf" "GccApplication1.a" "GccApplication1.hex" "GccApplication1.lss" "GccApplication1.eep" "GccApplication1.map" "GccApplication1.srec" "GccApplication1.usersignatures"
Done executing task "RunCompilerTask".
Done building target "Clean" in project "GccApplication1.cproj".
Done building project "GccApplication1.cproj".
Build succeeded.
Build started.
Project "GccApplication1.cproj" (default targets):
Target "PreBuildEvent" skipped, due to false condition; ('$(PreBuildEvent)'!='') was evaluated as (''!='').
Target "CoreBuild" in file "E:\Program Files Directory\Atmel\Studio\7.0\Vs\Compiler.targets" from project "C:\Users\wolfrose\Documents\Atmel Studio\7.0\GccApplication1\GccApplication1\GccApplication1.cproj" (target "Build" depends on it):
E:\Program Files Directory\Atmel\Studio\7.0\shellUtils\make.exe all --jobs 4 --output-sync
Building file: .././main.c
Invoking: AVR/GNU C Compiler : 4.9.2
avr-gcc.exe(0,0): error: =: No such file or directory
avr-gcc.exe(0,0): error: 10000000: No such file or directory
make: *** [main.o] Error 1
"E:\Program Files Directory\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe" -x c -funsigned-char -funsigned-bitfields -DDEBUG -DF_CPU = 10000000 -I"E:\Program Files Directory\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.0.106\include" -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega32u4 -B "E:\Program Files Directory\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.0.106\gcc\dev\atmega32u4" -c -std=gnu99 -MD -MP -MF "main.d" -MT"main.d" -MT"main.o" -o "main.o" ".././main.c"
C:\Users\wolfrose\Documents\Atmel Studio\7.0\GccApplication1\GccApplication1\Debug\Makefile(79,1): error: recipe for target 'main.o' failed
The command exited with code 2.
Done executing task "RunCompilerTask" -- FAILED.
Done building target "CoreBuild" in project "GccApplication1.cproj" -- FAILED.
Done building project "GccApplication1.cproj" -- FAILED.
Build FAILED.
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
I also got this error when I removed F_CPU value from project's --> properties/symbols. And added it again before includes of the code.
------ Build started: Project: GccApplication1, Configuration: Debug AVR ------
Build started.
In file included from .././main.c:11:0:
e:\program files directory\atmel\studio\7.0\toolchain\avr8\avr8-gnu-toolchain\avr\include\util\delay.h: In function 'forward':
e:\program files directory\atmel\studio\7.0\toolchain\avr8\avr8-gnu-toolchain\avr\include\util\delay.h(187,2): error: __builtin_avr_delay_cycles expects a compile time integer constant
__builtin_avr_delay_cycles(__ticks_dc);
"E:\Program Files Directory\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe" -x c -funsigned-char -funsigned-bitfields -DDEBUG -I"E:\Program Files Directory\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.0.106\include" -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega32u4 -B "E:\Program Files Directory\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.0.106\gcc\dev\atmega32u4" -c -std=gnu99 -MD -MP -MF "main.d" -MT"main.d" -MT"main.o" -o "main.o" ".././main.c"
e:\program files directory\atmel\studio\7.0\toolchain\avr8\avr8-gnu-toolchain\avr\include\util\delay.h: In function 'reverse':
Build FAILED.
========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========
error: 10 000 000:
At least a large number of errors are allowed for, one would not want to run out of error numbers. devil
This is just a guess, your AS7 install is on DRIVE e: and your user name is on DRIVE c: maybe it's looking for something on DRIVE c: ??
Your Windows install is on c: right ??
Maybe something to look into.
I've looked in the project's properties, but I don't think there's a problem in the path because the AS7 should look for the adjusted settings.
Because when you first develop the project it compiles OK but when I start to add includes and definitions then I start to errors and I can't compile it again, even if I remove everything!
I tried this morning and it builds OK!!? I don't know why AS7 changed its behavior.
But now I get this error with this command.
_delay_ms(_speed);
I think I shouldn't put this variable inside delay functions, because they won't get it. Maybe it's expecting double values.
OK I removed the variables as though I wish to substitute with variables for more versatility in my functions prototypes.
Now it compiles OK angel
_delay_ms doesn't take variables.
Is there a way to modify it? Because I want to provide the time value as a function argument, so you just modify the function argument and that changes all the delays in forward or reverse functions.
For example:
 * GccApplication1.c
 * Created: 12/25/2016 8:31:54 PM
 * Author : wolfrose
#define F_CPU 10000000UL
#include <util/delay.h>
#define pin1_ON (PORTD = 0x80)
#define pin2_ON (PORTE = 0x40)
#define pin3_ON (PORTB = 0x10)
#define pin4_ON (PORTB = 0x20)
#define pin1_OFF (PORTD = 0x00)
#define pin2_OFF (PORTE = 0x00)
#define pin3_OFF (PORTB = 0x00)
#define pin4_OFF (PORTB = 0x00)
void forward(uint8_t _steps, uint8_t _speed);
void reverse(uint8_t _steps,uint8_t _speed);
DDRD = 0x80;
DDRE = 0x40;
DDRB = 0x30;
    while (1)
  forward(20,10);
  _delay_ms(1000);
  reverse(20,10);
  _delay_ms(1000);
void forward (uint8_t _steps, uint8_t _speed)
 uint8_t n;
 for (n=0;n<_steps;n++){
  pin1_ON;pin4_OFF;
  _delay_ms(_speed);
  pin1_ON;pin2_ON;
  _delay_ms(_speed);
  pin1_OFF;pin2_ON;
  _delay_ms(_speed);
  pin2_ON;pin3_ON;
  _delay_ms(_speed);
  pin2_OFF;pin3_ON;
  _delay_ms(_speed);
  pin3_ON;pin4_ON;
  _delay_ms(_speed);
  pin3_OFF;pin4_ON;
  _delay_ms(_speed);
  pin4_ON;pin1_ON;
 _delay_ms(_speed);}
void reverse (uint8_t _steps,uint8_t _speed)
 uint8_t n;
  pin4_ON;pin1_OFF;
  _delay_ms(_speed);
  pin4_ON;pin3_ON;
  _delay_ms(_speed);
  pin4_OFF;pin3_ON;
  _delay_ms(_speed);
  pin3_ON;pin2_ON;
  _delay_ms(_speed);
  pin3_OFF;pin2_ON;
  _delay_ms(_speed);
  pin2_ON;pin1_ON;
  _delay_ms(_speed);
  pin2_OFF;pin1_ON;
  _delay_ms(_speed);
  pin1_ON;pin4_ON;
 _delay_ms(_speed);}
-DF_CPU = 10000000
You've got spaces in your definition of "F_CPU", do not do that!
The compiler thinks "=" and "10000000" are files to compile, which causes the error messages.
Bob. Engineer and trainee Rocket Scientist.
Where do I have "="?
I think my definition is OK here:
Anyway now it compiles OK :)
In your compiler settings, where you defined "F_CPU". Correct spacing is very important on the command line, but generally speaking not in C source code.
OK so you mean I have to add spaces? Yes you're right it's very important.
Now I have another issue.
_delay_ms (uint32_t);
Should only have constant values, I want to substitute it with Variable names for simplicity in my functions.
Where I can't do that, so what's the solution? Can I modify <util/delay.h>? Or develop a new delay library in the same WinAVR folder?
The idea of the _delay functions is that if you want to invoke with a variable amount you wrap a call to a fixed delay such as _delay_ms(1) or _delay_ms(0.1) or whatever in a for() loop then vary the iteration count of that loop.
Of course no serious MCU application is going to waste time just delaying.  Once your app has a timer enabled use it to coordinate things temporally.
