UPDI Programming using ATTINY817-XMINI
7 posts / 0 new
I am very new to AVR, so please be gentle. I will try very hard not to waste your time.
I am designing a project around the new ATtiny817 (I know it is new and not in production yet).
I have purchased a couple of the 817 XPlained boards from Digikey and development is going slowly but well.
I was about to buy an Atmel ICE programmer to UPDI (single wire) program the new chips but it occurred to me.
Could I make a programmer by taking a $9 817 XPlained  board, desolder the 817 chip, hook the PA0 pin (UPDI/Reset), power and ground to a connector?
To me this would seem to be cheap and easy way to make a UPDI programmer that would have the connector style I want.
This would also give me a test 817 chip to solder to my PCB.
Any thoughts?
It should work. If it doesn't, then at least we will find out that there is some secret serial number inside the chips.
Awesome, I will give it a try and report back.
Thanks for the help.
Probably - see the other threads on this. There is also a 0-0hm jumper on the UPDI line, so you could try removing that, and soldering to one PAD, but full removal does make it obvious  what the board is for... :)
I've not seen actual ISP speed comparisons yet, of the 817 choices - if you have a lot to program, maybe the -Pro is a better platform to kludge ?
We'll have to wait for a programmer. I have AVRICE and I bought few of the $8 ATtiny817-xplained. You will not be able to program a new chip, as it comes with UPDI chip un programmed SYSCFG0 bits 3-2. So you'll need a programmer that can do the 12v pulse on the reset pin to enable the UPDI
Hmm, seems they may have fixed that oops... I think UPDI is now enabled, not sure if that involves a Device Date-code, or was a data sheet typo
41. Datasheet Revision History
41.1 Rev.C - 12/2016
Section Changes
  FUSES - Configuration and User Fuses • Reset value of SYSCFG0 is 0xC4.
All new tiny817 is delivered with UPDI enabled. You only need 12V if you have configured the UPDI pin to something else, and want to connect to it with a programmer/debugger.
