Defining a single port from different port pins
21 posts / 0 new
I want to interface a 128x64 GLCD to atmega328P.I want to connect the LCD data pins to partial pins of PortB & PortC of AVR and act them as a single port.How is that possible.Suppose i want  PB0-PB5 and PC0,PC1 to act like a single port.How to send 8 bits data to them without affecting other pins??
You do it in software... wink
Your low-level software driver takes the 8 bit data value and splits the data to output it to the required pins.
The data strobe signal for the LCD then latches in the data, once you have set it up.
Obviously it takes a few more clock cycles to set up the data across two ports, and depending upon your language, etc., to perhaps even parse the data and set up each pin individually.
But your micro is running at 20 ( ? ) MHz, and 128x64 GLCD's aren't generally very "fast" devices anyways.
If you really want to optimize the data transfer rate, then you need to select the "correct" micro for the job, i.e. one where you can use a dedicated 8-bit data port.
Thanks a lot for your reply.But can you please give me an example about how to do it in software.By d way,i don't need to be very fast as the GLCD must be updated 2/3 times a sec to give a readout of voltage and current.Else will be taken care of by the analog part.My micro is running at 16Mhz.
Well, more info on which GLCD, and what language you are using would be helpful.
This example is for a GLCD driver, in Basic, where every pin is map-able / definable, and where the GLCD data bus was multi-tasking.
The I/O pins are set up for output, and then returned to input mode, for each write!
Know that that is very slow, but was needed for this particular project, and is probably NOT something you will need to do.
This takes a data byte and straight codes writing the data bus.
It clears the data bus to all 0's, then writes the individual bits to 1 if needed.
Glcdwdb:
   'GLCD Write Data Byte
   'On Entry have already set up the address to write to.
   'On Entry have GDB the Byte of data to write to the GLCD
   'On Entry have Chip = 1 or 2, the controller chip for Left or Right halves
   'of the display.  1 = L, 2 = R.  Active High.
   'On Entry have GM = 1 for a data byte, 0 for an Instruction, being sent.
   'First set the Data Port to Output
   'Map the data to the port pins
   'Write the data
   'Return data bus to Input mode
   'Could do the mode swap outside this routine for faster operations
   'when passing lots of data without reading in between writes.
   Set Gen                                                  'Enable starts high
   Set Grw                                                  'Rd/Wr starts high
   If Gm = 1 Then
      'Sending Data
      Set Gdi                                               'Data/Instr is high for data
   Else
      'Sending an Instruction
      Reset Gdi
   End If
   Reset Gcs1                                               'Chip Select 1 disabled
   Reset Gcs2                                               'Chip Select 2 disabled
   'Now make uC Data Bus Output:
   Config D0 = Output
   Config D1 = Output
   Config D2 = Output
   Config D3 = Output
   Config D4 = Output
   Config D5 = Output
   Config D6 = Output
   Config D7 = Output
   'Now set up the data on the uC data bus:
   'Clear all bits, then set the ones high that need to be high, (slow...)
   Reset Gd0
   Reset Gd1
   Reset Gd2
   Reset Gd3
   Reset Gd4
   Reset Gd5
   Reset Gd6
   Reset Gd7
   If Gdb.0 = 1 Then
      Set Gd0
   End If
   If Gdb.1 = 1 Then
      Set Gd1
   End If
   If Gdb.2 = 1 Then
      Set Gd2
   End If
   If Gdb.3 = 1 Then
      Set Gd3
   End If
   If Gdb.4 = 1 Then
      Set Gd4
   End If
   If Gdb.5 = 1 Then
      Set Gd5
   End If
   If Gdb.6 = 1 Then
      Set Gd6
   End If
   If Gdb.7 = 1 Then
      Set Gd7
   End If
   'Now execute a Write:
   Reset Gen                                                'Enable goes low
   Reset Grw                                                'Rd/Wr goes low for Write
   If Chip = 1 Then
      'Left half of display
      Set Gcs1                                              'Chip Select goes high
   Elseif Chip = 2 Then
      'Right half of display
      Set Gcs2
   End If
   Set Gen                                                  'Enable goes high
   Waitus 1
   Waitus 1
   Set Grw                                                  'Rd/Wr goes high
   Reset Gcs1                                               'CS goes low  (covers both)
   Reset Gcs2                                               'CS goes low  (covers both)
   'Write is now done.
   'Now return the uC Data Bus to Input Mode:
   Config D0 = Input
   Config D1 = Input
   Config D2 = Input
   Config D3 = Input
   Config D4 = Input
   Config D5 = Input
   Config D6 = Input
   Config D7 = Input
   Return
I am using ks0108 and using fabian's library for it.I am programming in C & using atmel studio.Can some macro's be useful to accomplish the job?For say,fabian defined some port(say PORTB) as LCD_PORT.So if a macro can replace that PORTB.
How are the the other pins on PORTB (PB6, PB7)and PORTC (PC2 -PC7) configured/used? And how are they connected to the LCD data pins?
Depending on the answers to those questions, I might do something like (Presumes PB0-PB5 are LCD_data0-LCD_data5 and PC0-PC1 are LCD_data6-LCD_7):
PORTB = (PORTB & 0xC0) | (LCD_data & 0x3F);  // Mask current contents of PORTB and merge low bits of LCD_data
PORTC = (PORTC & 0xFC) | (LCD_data >> 6);    // Mask current contents of PORTC and merge high bits of LCD_data
where LCD_data is the value to be written to the LCD.
Edit: changed 0x3F to 0xFC...
David (aka frog_jr)
Exactly that...but
PORTC = (PORTC & 0x3F)
would be PORTC = (PORTC & 0xFC ).But I want to replace the total 2 lines by a single word like LCD_PORT that would accept data also.for say LCD_PORT = 0xFF.
I've just knocked this up, but have no idea if it's the best way or not, it's just the first thing that came to mind.
I put everything in a function and passed the byte value that I want to write to the 2 ports, to the function.
// Single byte sent out across 2 ports:
// PB0 - PB5 is upper 6 bits of byte
// PC0 - PC1 is lower 2 bits of byte
// The byte value to be written to the 2 ports:
uint8_t myPortValue = 233;
void LCD_PORT(uint8_t byteValue)
	// Get the upper 6 bits from byteValue
	uint8_t byteValue_UpperSixBits = byteValue & 0b11111100;
	// Get the lower 2 bits from byteValue
	uint8_t byteValue_LowerTwoBits = byteValue & 0b00000011;
	// Get current bit values from PB6 & PB7
	uint8_t PORTB_UpperTwoBits = PORTB & 0b11000000;
	// Get current bit values from PC2 - PC7
	uint8_t PORTC_upperSixBits = PORTC & 0b11111100;
	PORTB = PORTB_UpperTwoBits + (byteValue_UpperSixBits>>2);
	PORTC = PORTC_upperSixBits + byteValue_LowerTwoBits;
    while (1)
		// Give some random values to the ports - test purposes only
                PORTB = 0b10110001;
		PORTC = 0b01011110;
		LCD_PORT(myPortValue);
I tested in the simulator and it seemed to work. Hope I didn't screw up anywhere.
Keith
Why not just write a function? Lcd_port()
Changed the name of the function in my example to LCD_PORT().
Keith.
Folks tend not to like all-caps for function names because that looks like a macro.
As said before, you can do this, but why bother?
Why not use a slightly bigger AVR wit more pins?
How much of your time is the USD2 price difference worth to you?
Below is a copy of the file "pinmagic.h" from the adafruit gfx library.
It's 18kB of text just to get a databyte out to different bits on different microcontrollers.
For each uC basically 2 macro's are defined. A write8inline() and a reas8inline().
#ifndef _pin_magic_
#define _pin_magic_
// This header file serves two purposes:
// 1) Isolate non-portable MCU port- and pin-specific identifiers and
//    operations so the library code itself remains somewhat agnostic
//    (PORTs and pin numbers are always referenced through macros).
// 2) GCC doesn't always respect the "inline" keyword, so this is a
//    ham-fisted manner of forcing the issue to minimize function calls.
//    This sometimes makes the library a bit bigger than before, but fast++.
//    However, because they're macros, we need to be SUPER CAREFUL about
//    parameters -- for example, write8(x) may expand to multiple PORT
//    writes that all refer to x, so it needs to be a constant or fixed
//    variable and not something like *ptr++ (which, after macro
//    expansion, may increment the pointer repeatedly and run off into
//    la-la land).  Macros also give us fine-grained control over which
//    operations are inlined on which boards (balancing speed against
//    available program space).
// When using the TFT shield, control and data pins exist in set physical
// locations, but the ports and bitmasks corresponding to each vary among
// boards.  A separate set of pin definitions is given for each supported
// board type.
// When using the TFT breakout board, control pins are configurable but
// the data pins are still fixed -- making every data pin configurable
// would be much too slow.  The data pin layouts are not the same between
// the shield and breakout configurations -- for the latter, pins were
// chosen to keep the tutorial wiring manageable more than making optimal
// use of ports and bitmasks.  So there's a second set of pin definitions
// given for each supported board.
// Shield pin usage:
// LCD Data Bit :    7    6    5    4    3    2    1    0
// Digital pin #:    7    6   13    4   11   10    9    8
// Uno port/pin :  PD7  PD6  PB5  PD4  PB3  PB2  PB1  PB0
// Mega port/pin:  PH4  PH3  PB7  PG5  PB5  PB4  PH6  PH5
// Leo port/pin :  PE6  PD7  PC7  PD4  PB7  PB6  PB5  PB4
// Due port/pin : PC23 PC24 PB27 PC26  PD7 PC29 PC21 PC22
// Breakout pin usage:
// Uno dig. pin :   7   6   5   4   3   2   9   8
// Uno port/pin : PD7 PD6 PD5 PD4 PD3 PD2 PB1 PB0
// Mega dig. pin:  29  28  27  26  25  24  23  22
// Mega port/pin: PA7 PA6 PA5 PA4 PA3 PA2 PA1 PA0 (one contiguous PORT)
// Leo dig. pin :   7   6   5   4   3   2   9   8
// Leo port/pin : PE6 PD7 PC6 PD4 PD0 PD1 PB5 PB4
// Due dig. pin :  40  39  38  37  36  35  34  33
// Due port/pin : PC8 PC7 PC6 PC5 PC4 PC3 PC2 PC1 (one contiguous PORT. -ish…)
// Pixel read operations require a minimum 400 nS delay from RD_ACTIVE
// to polling the input pins.  At 16 MHz, one machine cycle is 62.5 nS.
// This code burns 7 cycles (437.5 nS) doing nothing; the RJMPs are
// equivalent to two NOPs each, final NOP burns the 7th cycle, and the
// last line is a radioactive mutant emoticon.
#define DELAY7        \
  asm volatile(       \
	"rjmp .+0" "\n\t" \
	"rjmp .+0" "\n\t" \
	"rjmp .+0" "\n\t" \
	"nop"      "\n"   \
#if defined(__AVR_ATmega168__) || defined(__AVR_ATmega328P__) || defined (__AVR_ATmega328__) || defined(__AVR_ATmega8__)
 // Arduino Uno, Duemilanove, etc.
 #ifdef USE_ADAFRUIT_SHIELD_PINOUT
  // LCD control lines:
  // RD (read), WR (write), CD (command/data), CS (chip select)
  #define RD_PORT PORTC				/*pin A0 */
  #define WR_PORT PORTC				/*pin A1 */
  #define CD_PORT PORTC				/*pin A2 */
  #define CS_PORT PORTC				/*pin A3 */
  #define RD_MASK B00000001
  #define WR_MASK B00000010
  #define CD_MASK B00000100
  #define CS_MASK B00001000
  // These are macros for I/O operations...
  // Write 8-bit value to LCD data lines
  #define write8inline(d) {                          \
	PORTD = (PORTD & B00101111) | ((d) & B11010000); \
	PORTB = (PORTB & B11010000) | ((d) & B00101111); \
	WR_STROBE; } // STROBEs are defined later
  // Read 8-bit value from LCD data lines.  The signle argument
  // is a destination variable; this isn't a function and doesn't
  // return a value in the conventional sense.
  #define read8inline(result) {                       \
	RD_ACTIVE;                                        \
	DELAY7;                                           \
	result = (PIND & B11010000) | (PINB & B00101111); \
	RD_IDLE; }
  // These set the PORT directions as required before the write and read
  // operations.  Because write operations are much more common than reads,
  // the data-reading functions in the library code set the PORT(s) to
  // input before a read, and restore them back to the write state before
  // returning.  This avoids having to set it for output inside every
  // drawing method.  The default state has them initialized for writes.
  #define setWriteDirInline() { DDRD |=  B11010000; DDRB |=  B00101111; }
  #define setReadDirInline()  { DDRD &= ~B11010000; DDRB &= ~B00101111; }
 #else // Uno w/Breakout board
#if 1	// 2016-04-13 Performance test. What is the total cost of the bit masking?
	// ILI9341 connected with wires & modified graphics test.
	// It simply adds times of Adafruit TFT Graphics test and prints them on the lcd. (No Serial!).
	// 17318724.0/19753448 = 0.8767443536946056 >>> 1/_ = 1.1405
	// Arduino timing seems off.
	// Note: When connecting RxD & TxD to the ILI programming becomes difficult.
	  PORTD = d; WR_STROBE }
      RD_ACTIVE;					\
	  DELAY7; DELAY7;				\
	  result = PIND;				\
	  RD_IDLE; }
	#define setWriteDirInline() DDRD = 0xff
	#define setReadDirInline()	DDRD = 0
#else
	PORTD = (PORTD & B00000011) | ((d) & B11111100); \
	PORTB = (PORTB & B11111100) | ((d) & B00000011); \
	WR_STROBE; }
	RD_ACTIVE;                                        \
	DELAY7;                                           \
	result = (PIND & B11111100) | (PINB & B00000011); \
	RD_IDLE; }
  #define setWriteDirInline() { DDRD |=  B11111100; DDRB |=  B00000011; }
  #define setReadDirInline()  { DDRD &= ~B11111100; DDRB &= ~B00000011; }
#endif	// Performance test
 #endif
  // As part of the inline control, macros reference other macros...if any
  // of these are left undefined, an equivalent function version (non-inline)
  // is declared later.  The Uno has a moderate amount of program space, so
  // only write8() is inlined -- that one provides the most performance
  // benefit, but unfortunately also generates the most bloat.  This is
  // why only certain cases are inlined for each board.
  #define write8 write8inline
#elif defined(__AVR_ATmega1281__) || defined(__AVR_ATmega2561__) || defined(__AVR_ATmega2560__) || defined(__AVR_ATmega1280__)
 // Arduino Mega, ADK, etc.
  #define RD_PORT PORTF
  #define WR_PORT PORTF
  #define CD_PORT PORTF
  #define CS_PORT PORTF
	PORTH = (PORTH&B10000111)|(((d)&B11000000)>>3)|(((d)&B00000011)<<5); \
	PORTB = (PORTB&B01001111)|(((d)&B00101100)<<2);                      \
	PORTG = (PORTG&B11011111)|(((d)&B00010000)<<1);                      \
	WR_STROBE; }
	RD_ACTIVE;                                                       \
	DELAY7;                                                          \
	result = ((PINH & B00011000) << 3) | ((PINB & B10110000) >> 2) | \
			 ((PING & B00100000) >> 1) | ((PINH & B01100000) >> 5);  \
	RD_IDLE; }
  #define setWriteDirInline() {                                   \
	DDRH |=  B01111000; DDRB |=  B10110000; DDRG |=  B00100000; }
  #define setReadDirInline()  {                                   \
	DDRH &= ~B01111000; DDRB &= ~B10110000; DDRG &= ~B00100000; }
 #else // Mega w/Breakout board
  #define write8inline(d)   { PORTA = (d); WR_STROBE; }
	RD_ACTIVE;                  \
	DELAY7;                     \
	result = PINA;              \
	RD_IDLE; }
  #define setWriteDirInline() DDRA  = 0xff
  #define setReadDirInline()  DDRA  = 0
 #endif
  // All of the functions are inlined on the Arduino Mega.  When using the
  // breakout board, the macro versions aren't appreciably larger than the
  // function equivalents, and they're super simple and fast.  When using
  // the shield, the macros become pretty complicated...but this board has
  // so much code space, the macros are used anyway.  If you need to free
  // up program space, some macros can be removed, at a minor cost in speed.
  #define read8             read8inline
  #define setWriteDir       setWriteDirInline
  #define setReadDir        setReadDirInline
  #define writeRegister8    writeRegister8inline
  #define writeRegister16   writeRegister16inline
  #define writeRegisterPair writeRegisterPairInline
#elif defined(__AVR_ATmega32U4__)
 // Arduino Leonardo
  #define RD_MASK B10000000
  #define WR_MASK B01000000
  #define CD_MASK B00100000
  #define CS_MASK B00010000
	PORTE = (PORTE & B10111111) | (((d) & B10000000)>>1);                     \
	PORTD = (PORTD & B01101111) | (((d) & B01000000)<<1) | ((d) & B00010000); \
	PORTC = (PORTC & B01111111) | (((d) & B00100000)<<2);                     \
	PORTB = (PORTB & B00001111) | (((d) & B00001111)<<4);                     \
	WR_STROBE; }
	RD_ACTIVE;                                                       \
	DELAY7;                                                          \
	result = ((PINE & B01000000) << 1) | ((PIND & B10000000) >> 1) | \
			 ((PINC & B10000000) >> 2) | ((PINB & B11110000) >> 4) | \
			  (PIND & B00010000);                                    \
	RD_IDLE; }
	DDRE |=  B01000000; DDRD |=  B10010000;   \
	DDRC |=  B10000000; DDRB |=  B11110000; }
	DDRE &= ~B01000000; DDRD &= ~B10010000;   \
	DDRC &= ~B10000000; DDRB &= ~B11110000; }
 #else // Leonardo w/Breakout board
	uint8_t dr1 = (d) >> 1, dl1 = (d) << 1;                                   \
	PORTE = (PORTE & B10111111) | (dr1 & B01000000);                          \
	PORTD = (PORTD & B01101100) | (dl1 & B10000000) | (((d) & B00001000)>>3) |\
								  (dr1 & B00000010) |  ((d) & B00010000);     \
	PORTC = (PORTC & B10111111) | (dl1 & B01000000);                          \
	PORTB = (PORTB & B11001111) |(((d) & B00000011)<<4);                      \
	WR_STROBE; }
	RD_ACTIVE;                                                        \
	DELAY7;                                                           \
	result = (((PINE & B01000000) | (PIND & B00000010)) << 1) |       \
			 (((PINC & B01000000) | (PIND & B10000000)) >> 1) |       \
			  ((PIND & B00000001) << 3) | ((PINB & B00110000) >> 4) | \
	RD_IDLE; }
	DDRE |=  B01000000; DDRD |=  B10010011;   \
	DDRC |=  B01000000; DDRB |=  B00110000; }
	DDRE &= ~B01000000; DDRD &= ~B10010011;   \
	DDRC &= ~B01000000; DDRB &= ~B00110000; }
 #endif
  // On the Leonardo, only the write8() macro is used -- though even that
  // might be excessive given the code size and available program space
  // on this board.  You may need to disable this to get any sizable
  // program to compile.
#elif defined(__SAM3X8E__)
// Arduino Due
  #define RD_PORT PIOA				/*pin A0 */
  #define WR_PORT PIOA				/*pin A1 */
  #define CD_PORT PIOA				/*pin A2 */
  #define CS_PORT PIOA				/*pin A3 */
  #define RD_MASK 0x00010000
  #define WR_MASK 0x01000000
  #define CD_MASK 0x00800000
  #define CS_MASK 0x00400000
   PIO_Set(PIOD, (((d) & 0x08)<<(7-3))); \
   PIO_Clear(PIOD, (((~d) & 0x08)<<(7-3))); \
   PIO_Set(PIOC, (((d) & 0x01)<<(22-0)) | (((d) & 0x02)<<(21-1))| (((d) & 0x04)<<(29-2))| (((d) & 0x10)<<(26-4))| (((d) & 0x40)<<(24-6))| (((d) & 0x80)<<(23-7))); \
   PIO_Clear(PIOC, (((~d) & 0x01)<<(22-0)) | (((~d) & 0x02)<<(21-1))| (((~d) & 0x04)<<(29-2))| (((~d) & 0x10)<<(26-4))| (((~d) & 0x40)<<(24-6))| (((~d) & 0x80)<<(23-7))); \
   PIO_Set(PIOB, (((d) & 0x20)<<(27-5))); \
   PIO_Clear(PIOB, (((~d) & 0x20)<<(27-5))); \
   WR_STROBE; }
   RD_ACTIVE;   \
   delayMicroseconds(1);      \
   result = (((PIOC->PIO_PDSR & (1<<23)) >> (23-7)) | ((PIOC->PIO_PDSR & (1<<24)) >> (24-6)) | \
			 ((PIOB->PIO_PDSR & (1<<27)) >> (27-5)) | ((PIOC->PIO_PDSR & (1<<26)) >> (26-4)) | \
			 ((PIOD->PIO_PDSR & (1<< 7)) >> ( 7-3)) | ((PIOC->PIO_PDSR & (1<<29)) >> (29-2)) | \
			 ((PIOC->PIO_PDSR & (1<<21)) >> (21-1)) | ((PIOC->PIO_PDSR & (1<<22)) >> (22-0))); \
   RD_IDLE;}
   PIOD->PIO_MDDR |=  0x00000080; /*PIOD->PIO_SODR =  0x00000080;*/ PIOD->PIO_OER |=  0x00000080; PIOD->PIO_PER |=  0x00000080; \
   PIOC->PIO_MDDR |=  0x25E00000; /*PIOC->PIO_SODR =  0x25E00000;*/ PIOC->PIO_OER |=  0x25E00000; PIOC->PIO_PER |=  0x25E00000; \
   PIOB->PIO_MDDR |=  0x08000000; /*PIOB->PIO_SODR =  0x08000000;*/ PIOB->PIO_OER |=  0x08000000; PIOB->PIO_PER |=  0x08000000; }
	  pmc_enable_periph_clk( ID_PIOD ) ;	  pmc_enable_periph_clk( ID_PIOC ) ;	  pmc_enable_periph_clk( ID_PIOB ) ; \
   PIOD->PIO_PUDR |=  0x00000080; PIOD->PIO_IFDR |=  0x00000080; PIOD->PIO_ODR |=  0x00000080; PIOD->PIO_PER |=  0x00000080; \
   PIOC->PIO_PUDR |=  0x25E00000; PIOC->PIO_IFDR |=  0x25E00000; PIOC->PIO_ODR |=  0x25E00000; PIOC->PIO_PER |=  0x25E00000; \
   PIOB->PIO_PUDR |=  0x08000000; PIOB->PIO_IFDR |=  0x08000000; PIOB->PIO_ODR |=  0x08000000; PIOB->PIO_PER |=  0x08000000; }
   // Control signals are ACTIVE LOW (idle is HIGH)
   // Command/Data: LOW = command, HIGH = data
   // These are single-instruction operations and always inline
   #define RD_ACTIVE  RD_PORT->PIO_CODR |= RD_MASK
   #define RD_IDLE    RD_PORT->PIO_SODR |= RD_MASK
   #define WR_ACTIVE  WR_PORT->PIO_CODR |= WR_MASK
   #define WR_IDLE    WR_PORT->PIO_SODR |= WR_MASK
   #define CD_COMMAND CD_PORT->PIO_CODR |= CD_MASK
   #define CD_DATA    CD_PORT->PIO_SODR |= CD_MASK
   #define CS_ACTIVE  CS_PORT->PIO_CODR |= CS_MASK
   #define CS_IDLE    CS_PORT->PIO_SODR |= CS_MASK
#else // Due w/Breakout board
		PIO_Set(PIOC, (((d) & 0xFF)<<1)); \
		PIO_Clear(PIOC, (((~d) & 0xFF)<<1)); \
		WR_STROBE; }
		RD_ACTIVE;   \
		result = ((PIOC->PIO_PDSR & 0x1FE) >> 1); \
		RD_IDLE;}
		PIOC->PIO_MDDR |=  0x000001FE; /*PIOC->PIO_SODR |=  0x000001FE;*/ PIOC->PIO_OER |=  0x000001FE; PIOC->PIO_PER |=  0x000001FE; }
		pmc_enable_periph_clk( ID_PIOC ) ; \
		PIOC->PIO_PUDR |=  0x000001FE; PIOC->PIO_IFDR |=  0x000001FE; PIOC->PIO_ODR |=  0x000001FE; PIOC->PIO_PER |=  0x000001FE; }
	// When using the TFT breakout board, control pins are configurable.
	#define RD_ACTIVE	rdPort->PIO_CODR |= rdPinSet		//PIO_Clear(rdPort, rdPinSet)
	#define RD_IDLE		rdPort->PIO_SODR |= rdPinSet		//PIO_Set(rdPort, rdPinSet)
	#define WR_ACTIVE	wrPort->PIO_CODR |= wrPinSet		//PIO_Clear(wrPort, wrPinSet)
	#define WR_IDLE		wrPort->PIO_SODR |= wrPinSet		//PIO_Set(wrPort, wrPinSet)
	#define CD_COMMAND	cdPort->PIO_CODR |= cdPinSet		//PIO_Clear(cdPort, cdPinSet)
	#define CD_DATA		cdPort->PIO_SODR |= cdPinSet		//PIO_Set(cdPort, cdPinSet)
	#define CS_ACTIVE	csPort->PIO_CODR |= csPinSet		//PIO_Clear(csPort, csPinSet)
	#define CS_IDLE		csPort->PIO_SODR |= csPinSet		//PIO_Set(csPort, csPinSet)
 #endif
#else
 #error "Board type unsupported / not recognized"
#endif
#if !defined(__SAM3X8E__)
// Stuff common to all Arduino AVR board types:
 #define RD_ACTIVE  RD_PORT &= ~RD_MASK
 #define RD_IDLE    RD_PORT |=  RD_MASK
 #define WR_ACTIVE  WR_PORT &= ~WR_MASK
 #define WR_IDLE    WR_PORT |=  WR_MASK
 #define CD_COMMAND CD_PORT &= ~CD_MASK
 #define CD_DATA    CD_PORT |=  CD_MASK
 #define CS_ACTIVE  CS_PORT &= ~CS_MASK
 #define CS_IDLE    CS_PORT |=  CS_MASK
#else // Breakout board
 #define RD_ACTIVE  *rdPort &=  rdPinUnset
 #define RD_IDLE    *rdPort |=  rdPinSet
#if 1	// 2016-04-13 Performance test. What is the difference?
	// >>> 10173124.0 / 17318724 = 0.5874060929662024 >>> 1/_ 1.7023997741500054
	// >>> 19753448.0 / 10173124 = 1.9417288140791364 >>> 1/_ = 0.5150049753339265
	#define WR_ACTIVE	(PORTC &= ~(1<<1))
	#define WR_IDLE		(PORTC |= (1<<1))
#else
	#define WR_ACTIVE  *wrPort &=  wrPinUnset
	#define WR_IDLE    *wrPort |=  wrPinSet
#endif
 #define CD_COMMAND *cdPort &=  cdPinUnset
 #define CD_DATA    *cdPort |=  cdPinSet
 #define CS_ACTIVE  *csPort &=  csPinUnset
 #define CS_IDLE    *csPort |=  csPinSet
#endif
#endif
// Data write strobe, ~2 instructions and always inline
#define WR_STROBE { WR_ACTIVE; WR_IDLE; }
// These higher-level operations are usually functionalized,
// except on Mega where's there's gobs and gobs of program space.
// Set value of TFT register: 8-bit address, 8-bit value
#define writeRegister8inline(a, d) { \
  CD_COMMAND; write8(a); CD_DATA; write8(d); }
// Set value of TFT register: 16-bit address, 16-bit value
// See notes at top about macro expansion, hence hi & lo temp vars
#define writeRegister16inline(a, d) { \
  uint8_t hi, lo; \
  hi = (a) >> 8; lo = (a); CD_COMMAND; write8(hi); write8(lo); \
  hi = (d) >> 8; lo = (d); CD_DATA   ; write8(hi); write8(lo); }
// Set value of 2 TFT registers: Two 8-bit addresses (hi & lo), 16-bit value
#define writeRegisterPairInline(aH, aL, d) { \
  uint8_t hi = (d) >> 8, lo = (d); \
  CD_COMMAND; write8(aH); CD_DATA; write8(hi); \
  CD_COMMAND; write8(aL); CD_DATA; write8(lo); }
#endif // _pin_magic_
The performance loss is very dependent on the particular macro used.
So trying to use as few ports as possible and not having to shift bits helps a lot.
Note the date: "2016-04-13" in the comment.
That day I did 2 little performance test.
The most important test was to replace the "arduino" way of toggling the WRITE signal to the lcd with a simple macro.
This was twice as fast as the "arduino" way.
The other test was to use the whole port instead of dividing the 8-bit bus over 2 ports. This gave a performance gain of only 14%.
Or in short:
For your particular cpu the adafruit is similar to what you do, but they don't have to shift bits, which wil give a performance boost.
The relevant lines are:
	WR_STROBE; }
Sorry Jim, just did that to match the ops.
Keith.
Got a cycle count of 22 in Atmel Studio and -O1 optimisation. That's from the function call to the final PORTC write in the function.
So at 16Mz it takes about 1.375 microseconds to write the byte value to the 2 ports. Damn I like microcontrollers and these are not even powerful ones.
Keith.
declare the function inline and you might shave off the call overhead. Thus it becomes similar to using macros but with the extra checking of using a function.
First of all,sorry that i am not a macro specialist....but as per my understanding from your post,i write this piece of code as mention below.
    (PORTB & 0b11000000) | ((d) & 0b00111111);        \
    (PORTC & 0b11111100) | (((d)>>6) & 0b00000011);    \
write8inline(0xFF); //random data
while(1);
and try to compile,then it is showing
Warning    1    value computed is not used [-Wunused-value]
Warning    3    value computed is not used [-Wunused-value]
Read the example again! You've not assigned it to anything. Where's the PORTB =
Thanks a lot for pointing me out....now it is working.Next i will write the readback macro and update to you guys shortly!!
Now i wrote the code for reading is as follows
    result = ((PORTC & 0b00000011)<<6)|(PORTB & 0b00111111));    \
the question is,how to read the result??
Sorry....my bad
should be
    result = ((PINC & 0b00000011)<<6)|(PINB & 0b00111111));    \
OK.....I rewrite the whole GLCD program using different port pins acting as a single port successfully.But the problem is GLCD is running insanely slow.May be the proteus is running slow.Also my laptop is blowing it's fan at full speed.
Will connect a real GLCD to atmega328p and check the updating speed if it fullfills my purpose........Thanks a lottttttt guys for your great help.
