graphics/GUI using Xmega?
35 posts / 0 new
Hello:
Are there any ready-to-use Atmel boards with a 5 to 6 inch color LCD for showing "simple" graphics, such as a touch screen menu? Not wanting animation, just simple "control panel" apps.   Need at least 5 inches in size (venerable 4.3" too small).
This may likely be a stretch for the Xmega devices, but thought I'd ask.
Of course, being able to show graphics (lines, text, etc) is not the same as creating a nice full screen layout.  That is usually some sort of wysiwyg editing/creation code app.
Microchip has their pic24 series with integrated graphics controller...would like to use Atmel, maybe even something other than AVR.  Don't need pinch style controls, just "punch the screen button" menus.
How many dots do you want in your 5..6 inch? Sounds like 640x480 or something like that? If it's colour there's a strong chance it'll be 5-6-5 so 2 bytes per pixel and you are therefore talking about 640x480x2 = 616,400 bytes of display memory. The best bet is probably to find one of those panels with an "intelligent" controller that also has a 1MB frame buffer built it. Some of the Seiko-Epson (SED) controllers are like this.
Obviously the display module you are looking for does not need to be Xmega specific but the one thing that might bite you is the fact that's it's almost certainly going to have to be 3.3V only - that may limit your choice.
It's 3.5in max from Precision Design Associates for an XMEGA A1U Xplained Pro board.
EarthLCD did likewise (Atmel to Microchip) for almost all of their products other than a combination of the two in the ArLCD.
From Atmel with a graphiic LCD controller are some of the SAM9 and most of the SAMA5.
PDA has several displays (4.3in, 7in) for the SAMA5 Xplained and Xplained Pro boards.
35xx Series - 3.5in Projected Capacitance Touch
http://www.pdaatl.com/tx35xx.htm
Arduino
Arduino AtHeart
https://www.arduino.cc/en/ArduinoAtHeart/Products
(search for ArLCD)
FTDI do a graphical controller chip called EVE, and you can get display kits that use it. The interface is just a 3.3V UART IIRC, so trivial to hook up to any XMEGA dev board you like.
Thanks for the responses...Gchapman, the PDA looks interesting, but  apparently requires Linux (was really looking for c/c++ in studio 6 environment)...maybe need to open up to consider Linux (bleh), or keep up the search.  The ARLCD is only 3.5", not large enough.
As Clawson suggested, I've looked at some of the integrated displays (4D systems)...that might do the job, though they might break the bank due to high cost.   Hard to beat a $6 pic24 chip & $30 display.
The NuttX RTOS has significant Atmel support; IIRC one of the forthcoming NuttX ports is to XMEGA.
NuttX has a graphics library, widgets, and a window manager; Atmel ASF GFX has some graphics drivers and widgets.
Development for NuttX is not via an IDE whereas ASF is integrated into Atmel Studio.
FreeRTOS  - there is an XMEGA port but I don't know if there's a LCD, and related, library for FreeRTOS.
True though I'll counter with an OSHW attempt (don't fear Linux wink
Could Javascript to/from a web browser on an inexpensive tablet though would need an inexpensive server to transform XMEGA USB CDC to a web interface.
NuttX RTOS
June 9, 2015
http://www.nuttx.org/Documentation/NuttX.html#armcortexm7
Support for the connect maXTouch Xplained Pro LCD as added in NuttX-7.10.
  • Support for the (optional) maXTouch Xplained Pro LCD module (still a work in progress).
 NuttX RTOS
June 9, 2015
http://www.nuttx.org/Documentation/NuttX.html#armcortexa5
Additional board configurations were added to test and demonstrate these new drivers including new graphics and NxWM configurations.
Support for a graphics media player is included (although there were issues with the WM8904 audio CODEC on my board).
Olimex on Wordpress
New Set of LCDs in stock for OLinuXino now directly support LIME and LIME2 connectors
13 Nov 2014
https://olimex.wordpress.com/2014/11/13/new-set-of-lcds-in-stock-for-olinuxino-now-directly-support-lime-and-lime2-connectors/
GitHub
arduino/serial-port-json-server
https://github.com/arduino/serial-port-json-server
A serial port JSON websocket server for Windows, Mac, Linux, Raspberry Pi, or BeagleBone Black that lets you communicate with your serial port from a web application.
This enables web apps to be written that can communicate with your local serial device such as an Arduino, CNC controller, or any device that communicates over the serial port.
http://chilipeppr.com
ChiliPeppr
Downloads v1.82
http://chilipeppr.com/downloads/v1.82/
Edit : added ChiliPeppr URL.
+1
Just received a mailshot from Densitron: they're doing a webinar on their "intelligent" displays - may be worth a watch?
http://www.densitron.com/uploade...
http://www.densitron.com/content...
I bought one of these: https://www.indiegogo.com/projec...
Very low cost. I'm waiting for delivery which should be soon.
Thanks for the info on nextation...interesting & cool, except I  need >5 to 7" size.
I finally found the ASF (gchapman mentioned) graphics  libs...only 2 drivers seemed avail for xmega parts ILI9341 & HX8347A controllers (note:second 8347A on the listing):
http://asf.atmel.com/docs/latest/asf_gfx.html
not sure how "good & fast" this would be on an Xmega with 6 inch display (don't need animation or video, just some  widgets, like sliders, buttons)
I looked around & found xmega usage with a small display (but no menus)...however this is using some Bascom libs, rather than the ASF C libs.
https://www.youtube.com/watch?v=eGcUwT6J5nE
During my  wanderings I came across EVE, from FTDI (a respectable source)...it looks amazing & more than what I need...but need to investigate this..looks like it can tie into an Xmega
http://www.ftdichip.com/EVE.htm
some amazing videos:
https://www.youtube.com/watch?v=3trUUc-tFKY&feature=youtu.be
mojo-chan wrote:
I bought one of these: https://www.indiegogo.com/projects/nextion-a-cost-effective-high-perform...
Would be interested to hear what you think after it arrives. Looks very promising.
Cheers,
Ross
What does "Objective-oriented" mean??
My guess would be that when they state:
Objective-oriented display solution, to reduce the GUI development difficulty and shorten the cycle.
they mean that you take a standard graphical touch display and take away the pain of driving the display yourself using a GUI to customise the display into a number of objects that you can easily interact/control.  So allowing you to think of the touch display as buttons etc. so the solution is 'oriented' towards the final 'objective', i.e. producing a touch user interface in a simple manner using software tools to create the software to drive the display.
Of course I could be completely wrong as I dropped marketing speak before the exam ;o)
David
https://www.avrfreaks.net/comment/1444186#comment-1444186
FT81X datasheet states SVGA; FT800 datasheet states QVGA.
if 4.3" is big enough for you, the STM32F7 Microcontroller Discovery Board - only GBP 35.00 at RS:
This "Gameduino" is using the FTDI graphics chip:
Gameduino 2
https://www.coolcomponents.co.uk...
For AVR Arduino at about HVGA WQVGA (4.3in, FTDI EVE) :
http://www.mouser.com/new/newhavendisplay/newhaven-tft-arduino-shield/
I've done exactly what you're trying to accomplish. I used a 7 inch display with a 640x480 resolution. The display contained the infamous ssd1963. This chip or one if it's family members is what drives most of the cheap Chinese displays in this size category.
You can have my code if you want it. I did not write it to ever be seen by others however, so it's ugly as hell and contains little to no comments.
But be warned: It's possible, but it certainly isn't nice. The 32MHz of the xmega devices is hardly enough, changing a text or clearing the screen to change all of it's content takes long enough to be visible, so I had to overclock it to 64MHz. This is of course unacceptable for a production design. Therefore, I'd never do it again. It was a nice experiment, nothing more.
Thus I recommend going for a linux approach. A "next thing C.H.I.P" costs 9 USD and offers a direct interface to a display and touchscreen. Alternatively, the RPi Zero costs 5 USD and offers HDMI. A touchscreen can be connected with USB.
To design your GUI I can recommend Qt, GTK or wxWidgets. You can go fullscreen with your app directly on startup, so it will feel the same as if you did it bare metal.
-Patrick
Edit: typo
"Some people die at 25 and aren't buried until 75." -Benjamin Franklin
What is life's greatest illusion?"  "Innocence, my brother." -Skyrim
Just to compare
For a customer I have used a 16MHz mega324 to drive a 320x200 display, with a 8 bit SW databus  and 16 bit colour and everything written in GCC, and that is is "just" ok for speed.
Things that would help for speed :
With ASM it could be about 2-3 times faster.
wider bus for SW, or perhaps check if there are any way to get xmega's DMA working with the display.
For speed compare, how long did it take to write text, and how was it connected the display?
It say it't a reply to #18 , but I made it for #17 (something wrong in the forum)
I never measured how long it actually takes, but it is definitely visible without overclocking. I'd say a fifth of a second maybe for a text of 10 characters at a medium font. Now that doesn't sound too bad, but it bothered me a lot.
I used a 16bit data bus, a full port per byte.
One thing that also made it very slow was the fact that the fonts are too large to be stored in RAM so I had to put them in the flash. I guess that's also a very good reason not to use an xmega for such things.
On small screens, you can leave the fonts in RAM of course, so no problem there.
Sorry but why would you put a font in RAM? (It never change)
add
like :
static unsigned char fontchar[] PROGMEM = {
Because the access to it is much faster. As I said, using PROGMEM slows things down.
LPM is 3 clk
LD is 2 clk
So for a 16x16 font that give 1000 letters on a full screen, so that will add 32000 clk for a for a full screen or 1ms on a 32MHz xmega, I think that you have way bigger problems then that!
Another use of SSD1963 is by 4D Systems in Australia; the MCU is a 4D Systems 16-bit.
http://www.4dsystems.com.au/productpages/gen4-uLCD-70D/downloads/gen4-uLCD-70D_datasheet_R_1_3.pdf (page 23, top right)
via
http://www.4dsystems.com.au/product/gen4_uLCD_70D/
A PIC24 may be a better match for function with such size LCD than an XMEGA.
You are right about that, but there must be something else. I honestly don't know enough about how the compiler manages these things, nor can I read assembler too well. So I don't know what's really going on inside the processor.
But my claim that reading from flash is slower is by pure observation.
I had the font in RAM and then put it in the flash. And thus the program became significantly slower. Far from a factor of two, but noticeable none the less.
The font I used there was very large though, 84x132 per letter. I used it to show the time on that 7 inch screen. Maybe I did something wrong, that is really not unlikely.
But it worked, so I don't care that much anymore.
-Patrick
Definitely check out the FTDI FT800 series.  I'm using them, and I'm pleased with the performance.  The FT800 greatly unburdens your MCU.  It takes a little getting used to because the way it gets the stuff on the screen is a bit strange 8)
Tom Pappano
Tulsa, Oklahoma
More SSD1963 :
Newhaven Display International, Inc.
Newhaven Display International, Inc., High Quality Standard and Custom OLEDs, LCDs and VFDs.
NHD-7.0-800480EF-20 Controller Board NHD-7.0-800480EF-20 Controller Board [105.5mm x 40mm] - $25.00
http://www.newhavendisplay.com/nhd70800480ef20-controller-board-p-7307.html
• Digital controller board for 7.0in TFT displays
• 3.3V input
• 8-bit parallel MCU interface
Controller/Driver: SSD1963-8bit
(3.3V, 285mA typ, -20C .. 70C)
https://newhavendisplay.com/appnotes/excode/txt/TFT/TFT_70.txt (WVGA)
via
https://newhavendisplay.com/appnotes/excode/TFTs.php
logo
Riverdi
SSD1963 Catalogue
https://riverdi.com/product-category/displays/ssd1963/
Edit : Riverdi
Newhaven Display's FT80x (WQVGA) source code seems reasonable; in addition to graphics primitives there are widgets.
The Arduino source code has an FTDI copyright; Newhaven Display added examples.
http://www.newhavendisplay.com/appnotes/excode/txt/Arduino/CTP_FT_App_CarbonationMachine_sketch.txt
http://www.newhavendisplay.com/learnmore/Arduino-4_3CTP-N/#sect4 (4.3" Arduino Shield with Capacitive Touch, Example Code)
http://www.newhavendisplay.com/nhd43ctpshieldn-p-9520.html
Indeed!
Seriously?!
Who is actually going to notice the difference?!
There are 2 often used tft libraries for avr's.
One is from adafruit and the other is "utft" from rinkydink.
Adafruit can be made about twice as fast by changing 2 of the horrible macro's in "pinmagic.h".
I found the atmega's to slow to my liking and in fact the small TFT's were the reason to delve into arm (ST32F103C8T6).
I believe the Xmega's are somewhat similar to ARM cortex M3.
For an Idea of performance go see some youtube video's.
As a gadged I bought a jyetech DSO138 clone and it delivers amasing performance for a USD18 scope.
Sorry but in what sense is an Xmega like an M3? The AVR core in an Xmega is not really any different to a mega. The only differentiation of Xmega are slightly higher spec peripherals and a higher top speed.
Cliff,
I wasn't aware that the AVR had the XMega's DMA facilities...
DMA is present in most XMEGA and has 24-bit addressing of data memory; 24b types were added to AVR GCC 4.7
In addition to the AVR RAMPZ register are RAMPX, RAMPY, and RAMPD for XMEGA.
XMEGA have additional memory models for compilers due to the 24b addressing of data memory.
The Newhaven Display WQVGA FTDI source code is using Arduino SPI.
XMEGA has DMA available for master SPI via USART in Master SPI Mode; such could be used for the FT801 frame memory equivalent to a graphics primitive bit blit operation.
https://gcc.gnu.org/wiki/avr-gcc#Types
http://www.atmel.com/Images/Atmel-0856-AVR-Instruction-Set-Manual.pdf
https://github.com/NewhavenDisplay/FTDI_FT801/blob/master/libraries/FT_GC/FT_Transport_SPI/FT_Transport_SPI.h
Designing Feature-Rich User Interfaces for Home and Industrial Controllers
(file size: 933KB, 5 pages, updated: 06/2013)
http://www.atmel.com/Images/Designing_Feature-Rich_UIs_Article.pdf
(page 3)
The Atmel SAMA5D3 MPU is an ideal candidate for your control panel designs.
To assist your development of the UI, Atmel has partnered with TimeSys to port the Qt framework and its comprehensive range of development tools.
eewiki (Digi-Key)
Linux on ARM
ATSAMA5D3 Xplained
by Robert Nelson
https://eewiki.net/display/linuxonarm/ATSAMA5D3+Xplained
last modified on Dec 06, 2016
LCD with early support:
(4.3in and 7in by Precision Design Associates)
http://www.pdaatl.com/ (Precision Design Associates)
