Hi
I'm instal the lastest version of Atmel Studio from the atmel.com
I'm trying to make a very simple program but i can't !!
#include <avr/io.h> int main(void) { /* Replace with your application code */ while (1) { } }
The Problem(Error) is:
recipe for target 'main.o' failed
################################################################################ # Automatically-generated file. Do not edit! ################################################################################ SHELL := cmd.exe RM := rm -rf USER_OBJS := LIBS := PROJ := O_SRCS := C_SRCS := S_SRCS := S_UPPER_SRCS := OBJ_SRCS := ASM_SRCS := PREPROCESSING_SRCS := OBJS := OBJS_AS_ARGS := C_DEPS := C_DEPS_AS_ARGS := EXECUTABLES := OUTPUT_FILE_PATH := OUTPUT_FILE_PATH_AS_ARGS := AVR_APP_PATH :=$$$AVR_APP_PATH$$$ QUOTE := " ADDITIONAL_DEPENDENCIES:= OUTPUT_FILE_DEP:= LIB_DEP:= LINKER_SCRIPT_DEP:= # Every subdirectory with source files must be described here SUBDIRS := # Add inputs and outputs from these tool invocations to the build variables C_SRCS += \ ../main.c PREPROCESSING_SRCS += ASM_SRCS += OBJS += \ main.o OBJS_AS_ARGS += \ main.o C_DEPS += \ main.d C_DEPS_AS_ARGS += \ main.d OUTPUT_FILE_PATH +=GccApplication2.elf OUTPUT_FILE_PATH_AS_ARGS +=GccApplication2.elf ADDITIONAL_DEPENDENCIES:= OUTPUT_FILE_DEP:= ./makedep.mk LIB_DEP+= LINKER_SCRIPT_DEP+= # AVR32/GNU C Compiler ./%.o: .././%.c @echo Building file: $< @echo Invoking: AVR/GNU C Compiler : 4.9.2 $(QUOTE)C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe$(QUOTE) -x c -funsigned-char -funsigned-bitfields -DDEBUG -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.1.130\include" -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega8a -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.1.130\gcc\dev\atmega8a" -c -std=gnu99 -MD -MP -MF "$(@:%.o=%.d)" -MT"$(@:%.o=%.d)" -MT"$(@:%.o=%.o)" -o "$@" "$<" @echo Finished building: $< # AVR32/GNU Preprocessing Assembler
thanks for your help.
