7 digit dicimal number into a 21-bit binary number
6 posts / 0 new
Hello everybody,
I program in c with ATmel studio 7,
work with the protocol POCSAG and would like to do the following:
Conversion of a seven-digit decimal number into a 21-bit binary number.
The code I have is limited.
Can anyone help me with a code that works?
greeting
Etie
Do you understand the basic concept of Place Value - used when writing numbers?
http://www.bbc.co.uk/bitesize/ks...
It's simply a matter of multiplying each digit by its place value, and summing ...
But note that 9999999 won't fit into 21 bits ...
Thank you for responding promptly.
I would like to know this fact:
If I send the following 7 decimals
0000000 must i have as banary 0000000 0000000 0000000
You do understand that leading zeros make no difference whatsoever to the value of the number?
In C normally you would use atoi() for this (ASCII TO Int) but in AVR the int type is just 16 bit and can only hold +32767..-32768 so for AVR you would use the "long" version of the same routine which is atol() (fourth character is L for lima).
char input[] = "1234567";
int32_t num;
num = atol(input); // now num contains 1234567
signed long int or more usefully int32_t on AVR has a numeric range of +2,147,483,647 .. -2,147,483,648 so can accommodate a little over 9 decimal digits.
thank you
For clarification
