Can't figure out how to program ATtiny817
41 posts / 0 new
Hello~
I'm currently working with the ATtiny817-XMini dev board and I'm planning on ordering a PCB soon with the ATtiny817. The plan was to order today, but we realized a key issue- we're not sure how to program the chips.
The more common ATtinys (particularly the 85) have plenty of documentation and resources online, with various programmer boards and even tutorials on how to use an Arduino Uno to program the ATtinys. However, for the 817 (and the corresponding series), there seems to be extremely little, from what pins to connect to AVR programmers that are compatible with it.
I'm sorry if I'm overlooking something important, but after triple checking and discussing the matter with a few different individuals, I'm still at a lost on how to program the ATtiny's that will go onto our PCB. The two dev/eval boards use the Atmel Mini Embedded Debugger (as well as an example application from Atmel), but otherwise, I'm at a complete loss.
Thank you for any and all help.
It's (yet another) new mechanism isn't it? I think they call it UPDI or something. Presumably that's to prevent the whole world using $3 USBAsp's and forcing them to buy $100 Atmel-ICEs ?
EDIT, yup, the whole of chapter 33 in the datasheet is dedicated to "Unified Program and Debug Interface"...
Thank you for the UPDI reference, and we're looking over it again at the moment. However, there are two issues I'm not sure about: first, I can't find much outside of the datasheet that references UPDI. And second, earlier we thought we would need to get a bootloader onto the chip itself first to use UPDI in the first place, which we're also unsure how to do. Sorry if this answer is pretty obvious, but would we be able to use UPDI without even a bootloader (assuming we figure out how to use the proprietary method in the first place, hardware wise)?
On another interesting note, on this datasheet it's chapter 34 (just in case there are key differences between the two).
Once again, thank you!
The idea of a bootloader is to allow you to program (and update) the device without a special tool that uses something like UPDI. So you'd use an ICE to upload your bootloader onto the ATtiny817 then say you had your device connected to a USB port of a PC via a UART to USB converter IC then you could use the PC to program the application image.
Edit: Funnily enough the ATMEL-ICE page on the Atmel website has no mention of being compatible with UPDI?
Those are really good points, thank you.
The two methods I'm looking over right now are...
1) Programming over UPDI myself (say with an Arduino Uno and otherwise quite manually)
As far as I could tell, the UPDI only requires the UART lines and the Reset line. Given the chip itself is already powered appropriately, UPDI could be enabled by a 12V pulse to the Reset line then using UART (of sorts) to communicate the messages. I haven't gotten much farther than this, but it seems technically possible. However, it also seems extremely complicated to do from scratch.
2) Using the mEDBG from the XMINI we already have (ie, hacking together an arbitrary programmer of sorts)
Apparently there's a section on disconnecting the Mini Embedded Debugger (section 4.4). Given that we can remove those resistors safely and replace them with wires of sorts, we may be able to connect the mEDBG to an arbitrary ATtiny817. However, this needs to be looked into far more and, given the lines necessary to use UDPI, I don't believe we can reuse the one on the XMini.
The UPDI is new, and the list of supported interfaces in the Atmel-ICE documentation hasn't been updated yet.
The UPDI is supported by both Atmel-ICE, PowerDebugger and JTAGICE3 if you upgrade them with the latest FW.
UPDI is a single wire interface, so the only wires you need to connect is:
Tool           Target
TDO       -   UPDI
Vtarget  -   VCC
GND      -   GND
The 12V activation is only necessary if you have configured the UPDI pin to be something else (fuse setting), like GPIO. The 12V activation will then configure the pin back to UPDI mode for that programming session.
... the debuggers' user guides are in the pipe smiley
:: Morten
Tool           Target
TDO       -   UPDI
Vtarget  -   VCC
GND      -   GND
Thank you so much! That solves the issues at hand and makes sense. I'll try posting in this thread again down the line just as a confirmation that there's nothing else that may need to be done that's not obvious at the time in order to use those devices to program the ATtiny817, but this should be it. Once again, thank you (and thank you everyone else as well)!
Aww, no dragon support?  q:-(
FF = PI > S.E.T
Once we all get the our ATtiny817-XMini dev boards we will be in a better position to answer things.wink
Should start a poll -- Do y'all see enough info in Chapter 34 for some bright 'Freak to make a programmer?  After all, the chapter starts out with "proprietary"...
That said, the single wire (or two-wire) is a UART interface 8-E-2 so a protocol analyzer should be able to trap sample session(s) and aid the interpretation of Chapter 34.
That's not how I read it.
My reading is the UPDI uses only the reset pin, but that link does use a UART-like half-duplex interface.
Parts that do this, usually have some high frequency pre-amble, to signal the part to flip the pin from simple reset to Serial Link mode.
If you really want to literally 'program this yourself', you need to write code that can talk UPDI
That makes more sense, as the full firmware is already in the XMINI, and you have no code to write.
You just need to replace the on-board 817, with an off-board one, using short wires.
If you are doing volumes of this, I'd check the programming times of the XMINI and XPRO etc, as I've seen some comments on very slow pgm speeds at the bottom end....
(hopefully UPDI is faster...)
Who-me wrote:
That's not how I read it. My reading is the UPDI uses only the reset pin, but that link does use a UART-like half-duplex interface.
There is also the option for a two-wire, which might simplify the interface to a "standard" UART but would then introduce considerations if the second pin needs to be "shared" with the app.
Optionally, a 2-
wire interface using a GPIO as a separate TX-pin can be enabled, with the PDI pin still used for the RXpart of the communication.
theusch wrote:
But I see no mention on how the provided interface can be used to program other '817s.  Some e.g. Cortex dev boards allow snapping off the programmer piece, or a header or similar, to be able to use that part of the dev board for other units.
Perhaps one can use the UPDI "disconnect point"...
Yes, Boards that clearly show how to use on external connections, gain extra points.  The break-off ones are the most obvious.
On the image shown, the CDC points will be for the Com port pathway, which is not needed for the EDEBUG, but is useful for printf style messages from user code.
The UPDI "disconnect point" looks the obvious way to isolate the local Tiny817, but better solder pads for external connect would not have cost anything, surely ?
The UPDI signal to/from the mega32U4 is a 0.25mm via (won't be easy to solder).
http://www.atmel.com/tools/ATTINY817-XMINI.aspx?tab=documents (bottom for "ATtiny817 Xplained Mini User Guide")
http://www.atmel.com/images/Atmel-42726-ATtiny817-Xplained-Mini_User-Guide.zip
  • Files :
Readme.txt
ATtiny817_Xplained_Mini_design_documentation_release_rev4.PDF : Design Documentation with Bom
Test Points\Assembly Testpoint Report for ATtiny817_Xplained_Mini_release_rev4.txt : Assembly Testpoint report, txt
Signal UPDI is in the PDF on page 3 (schematic, programmer, B3)
The 0R R203 to be removed (UPDI disconnect) is on page 2 (schematic, target, A1)
The location of the UPDI via is in the testpoint file.
An Atmel-ICE PCBA would be easier for jigs, burn-ins, etc
http://www.atmel.com/devices/ATtiny817.aspx
http://www.atmel.com/Images/Atmel-42721-ATtiny-417-814-816-817_Complete.pdf (datasheet, 11/2016, 4.9MB)
theusch wrote:
... Do y'all see enough info in Chapter 34 for some bright 'Freak to make a programmer?
Yes; from a quick skim, the information appears similar to other AVR (physical, media, instruction set).
for the OCD which is standard operating procedure for AVR.
Not much in the datasheet on OCD other than high level architecture and the System Information Block (SIB) (datasheet page 516).
The programming spec needs to be open such that the numerous third parties that create AVR programmers can add tiny817.
Distributors will have to make quick work of programming a reel of these for customers.
Dean could add UPDI to his LUFA (half duplex UART for UPDI instead of half duplex USART for PDI).
But see the picture from that guide in #5 above--"UPDI disconnect" jumper...
I just read UDPI as "undefined program and debug interface".
I can understand why op has a problem with that.
Sorry, couldn't resist.
Debugger user guides are now (finally) online both on Atmel.com and in Atmel Studio
:: Morten
If you are interested in making your own programmer for the new Tiny parts with UPDI, you could take a look at the pyupdi repo which I put out on github recently:
https://github.com/mraardvark/py...
UPDI is so simple it can be run from a CDC device with a single resistor between RX and TX.
The code has been tested using an Xplained Nano to program and verify flash.
Mr Aardvark, you have missed a trick, you could have designed a small USBAsp-alike, have them made up in China then sell them for $3 a time on ebay and make a $1 per unit then relax and download: https://www.yachtcharterfleet.co... ! ;-)
Other than the DIY approach, has anyone seen a robust programmer that supports uPDI?
Have they not updated the firmware in the Atmel-ICE to do it then?
clawson wrote:
...Atmel-ICE...
Probably. The trouble is a) the ICE never feels very robust and b) I'd have to install Studio 7 to drive it.
I know I should embrace the dark side but I'm clinging on...
Brian Fairchild wrote:
clawson wrote:
...Atmel-ICE...
Probably.
Or looking at the website, probably not.
The online manual makes no mention of uPDI but is very out of date.
...I'd have to install Studio 7 to drive it.
Actually, not true. I've just spotted that the ICE is supported by CVAVR.
Search the forum for "powerdebugger"
There was an ad from Microchip today with a discount coupon.
Edit: Got it:
https://www.avrfreaks.net/forum/m...
http://www.microchip.com/Developmenttools/ProductDetails.aspx?PartNO=ATPOWERDEBUGGER
Power Debugger
25% Off - Use Coupon Code :ULPSAML2       Expires : 19-Jan-2018
A bit sad that this table has not been kept up to date:
http://www.atmel.com/webdoc/atmelstudio/supported.devices.AVR.Tiny.html
@ Clawson
Why sad? Didn't Atmel just include support for All tiny's?
Maybe this is a bit comforting:
http://www.microchip.com/paramCh...
Maybe a third party?
The list of third party AVR programmers was recently updated :
AT06015: Production Programming of Microcontrollers
AN2468
06/23/2017
http://www.microchip.com//wwwAppNotes/AppNotes.aspx?appnote=en592074
This application note covers both the AVR® and SAM microcontrollers, but not the PIC® microcontrollers.
via http://www.microchip.com/wwwproducts/en/attiny1617
There's a C# wrapper around atprogram.exe :
Microchip
AN2466
Using Atmel-ICE for AVR® Programming In Mass Production
07/28/2017
http://www.microchip.com//wwwAppNotes/AppNotes.aspx?appnote=en599598
The application note introduces Atmel-ICE setup, driver installation, user guide of the Atmel Studio command line utility (atprogram.exe), and provide a PC programming tool project written in C#. The Visual C# example project can be downloaded along with this application note and run with the ATmega328PB Xplained Mini kit.
tiny417 and tiny817 are in CodeVisionAVR (3.30)
Could not locate UPDI in ChipBlasterAVR though it likely supports it :
ChipBlasterAVR
http://hpinfotech.ro/cbavr_features.html
Universal In-System AVR Chip Programming Software
Fully compatible with CodeVisionAVR projects, allows executing the programming tasks specified in CodeVisionAVR’s Project|Configure|After Build menu. Ideal for production environments.
http://hpinfotech.ro/cvavr_revision3.html
An advantage for Atmel Power Debugger over Atmel-ICE is the Power Debugger has pads for a 100mil pitch AVR connector :
The 50mil pitch AVR connector mates with cables included with the Power Debugger (same cables as in Atmel-ICE full kit)
Showing a big hammer at the back of tools may give the users some wrong feedback on what to do when the thing doesn't work! Had that feeling a couple of times in the past.
To use the CodevisionAVR "built-in" programming functions on USB, you need to install Atmel Studio 7.
js wrote:
a big hammer
I have always found it amusing that Atmel choose a Big Hammer as the symbol for their debugging tools!
laugh
Also that they choose a Bug as the emblem for their development tools!
laugh
That's called truth in advertising.
It's not just a big hammer, it's Thor's Hammer.  What else would you expect from a Viking! I must admit I know of no Atmel debugging tool that can be called "one of the most fearsome and powerful weapons in existence, capable of leveling mountains."
Greg Muth
Portland, OR, US
Make Xmega Great Again!
Forget that python thing, big expensive hammers, etc. and just clone Xplained Mini module, as i did: https://www.avrfreaks.net/forum/a...
It works for tiny1616 which has SOIC package available. For minimalist version only 16MHz xtal, some caps and wires are needed... devil
@edit: keep wires short, cause longer may cause errors.
Hello~
There are two questions.
How many adc channels are available at the same time?
So how do you code your program?
jaegon yoo
