Optocoupler speed
14 posts / 0 new
    Hello
    Some transistor output style optocouplers have the base brought out. I wonder what would be the purpose of this ? Is there a way to avoid the output transistor to saturate in order to increase the speed ?
    Another question, from your experience, what would be the maximum baud rate a transistor based optocoupler could achieve, more than 9600 ?
    Thanks.
1Mbps. ACNT-H50L-500.
I like Brian's part!
That said, I used a TIL111 in the past.
It is certainly not a fast part.
I was driving it with a Mega168 USART, 5V system.
I ended up putting a 2N7000 NFet on the output to square up the output signal.
That then drove a Tiny's USART just fine.
Note that is this configuration the opto inverts the signal, and the NFet re-inverts the signal, so the isolated USART is happy.
It worked at 38400 and 57600 baud just fine, although the 38K baud rate signal "looked" better on the O'scope.
The Tiny's USART, however, read both signals just fine.
BTW, I still have one of your XMega PCBs on the bench, it gets powered up every onw and then for a project / test or two.
Pretty ugly PCB, one of my earlier hand soldered SMD boards, but it worked well!
Certainly more than 9600bps is possible, e.g. ICPL2630 / ICPL2631 (Features say 10Mbps, but I do not think that is a realistic spec for commercial product.)
David
frog_jr wrote:
ICPL2630 / ICPL2631
Those are logic gate output parts though.
Indeed: MIDI is opto-coupled and works at 31250 bps.
But if you actually want opto-isolated RS232, there are vendors with specific products for that; eg,
https://www.maximintegrated.com/...
http://www.analog.com/en/product...
And, nowadays, there are plenty of other isolation options;
eg, http://www.analog.com/en/product...
Adding some resistance from the base to ground can significantly shorten the turnoff time
Some capacitance to ground can greatly reduce the effects of high frequency noise capacitance-coupled from the led
Tom Pappano
Tulsa, Oklahoma
Unlike a conventional BJT, an opto-coupler speed is NOT limited by collector saturation. Instead, it is limited by the high inter-electrode capacitance due to the large area needed capture the light (photo-sensitive area). The base region of an opto-coupler can be thousands of times larger in area than a normal transistor. Thus, strategies for speed improvement in opto-couplers are quite different than in a normal BJT circuit. Often, your only viable option is to use a coupler that is optimized for higher speed.
The really early opto couplers gave access to the base, as that gives more choices on how to use.
More recent ones tend to have no base bonded, as that also picks up noise.
The Collector to base junction has a quite high C, in opto Trx, as that is the large-area photo junction.
If you need moderate speed, (~1MBd) the H11L1 is worth a look.
A transistor optocoupler speed will come down to that Cbc mentioned above.
If you use a low load resistor, to reduce the miller effect, and a comparator, you can likely get > 100k in a transistor based optocoupler.
Also, lowering the RL and increasing the drive, will likewise increase the speed, but you will probably decide some more modest drive is more practical.
Most data sheets show tr,tf with load, and you can see the miller effect there.
If you can reach the base you can probably use it to build a schmidt trigger.
I have experimented with general purpose / low speed opto's and could get about 150kHz through them but no practical use ( jitter, aging, temperature effects, etc).
Optocouplers are also cheap & easy, but for higher speeds nowadays specialised ic's with inductive or capacitive barriers are used for 400MHz and faster.
Paul can you mention some part numbers "specialised ic's with inductive or capacitive barriers are used for 400MHz and faster.
This EDN Design Idea significantly speeds up the turn-on time of a standard Opto-Coupler.
Unless this method appeals to the user for some reason, a faster part is probably a better choice.
Optocoupler speed-up also reduces power consumption by Marian Stofka -September 01, 2014
http://www.edn.com/design/analog/4433947/Optocoupler-speed-up-also-reduces-power-consumption
Stan
I am not very good with the electronics side, what about these devices:
http://www.mouser.com/ds/2/678/u...
That is a nice multi-channel fast coupler. There is a really big caveat, however. Both sides need power. If you want to maintain the isolation, you will need isolated power on the input side. And, those input channels are NOT isolated from each other, they must share a common terminal. If you can live with those limitations, then its a great part.
