avr-nm output for EEPROM storage
5 posts / 0 new
Hi all,
As part of the output from my build process I am using avr-nm to generate a memory usage profile:
avr-nm --size-sort -r --demangle application.elf
My application uses 195 bytes of EEPROM, declared as follows:
static uint8_t EEMEM eeprom_device_address = 0;
static uint16_t EEMEM eeprom_max_level = MAX_LEVEL; 'Default MAX_LEVEL #defined in header file
static uint16_t EEMEM eeprom_data_table[192];
these variables appear in the avr-nm output as:
000000c0 d eeprom_data_table
00000002 d eeprom_device_address
000000c1 d eeprom_max_level
Some normal RAM variables in this output also have a 'd' symbol type.
Is there a way of making EEPROM variables appear as a separate symbol type to RAM in the profiler output?
Context: I am using a python tool to parse the profile output to visualise my memory usage. In order to not count EEPROM variables as RAM usage I am filtering for variables starting with the string 'eeprom_', but a more robust, less error-prone method would be an advantage.
Target microcontroller: ATMEGA328PB
avr-nm version: GNU nm (AVR_8_bit_GNU_Toolchain_3.5.4_1709) 2.26.20160125
avr-g++ version: avr-g++ (AVR_8_bit_GNU_Toolchain_3.5.4_1709) 4.9.2
Thanks!
I don't get it, how do those variables have 0 based addresses?
When I build this:
#include <avr/eeprom.h>
uint16_t read_adc;
uint32_t foo EEMEM;
int main(void) {
    while(1) {
    return 0;
I get this:
$ avr-nm avr.elf
00000068 t .do_clear_bss_loop
0000006a t .do_clear_bss_start
00000034 a __CCP__
0000003e a __SP_H__
0000003d a __SP_L__
0000003f a __SREG__
00000078 T __bad_interrupt
00800062 B __bss_end
00800060 B __bss_start
00000054 T __ctors_end
00000054 T __ctors_start
00000082 A __data_load_end
00000082 A __data_load_start
00000060 T __do_clear_bss
00000054 T __dtors_end
00000054 T __dtors_start
00810004 D __eeprom_end
00000000 W __heap_end
00000054 W __init
0000045f W __stack
00000080 t __stop_program
00000000 a __tmp_reg__
00000054 T __trampolines_end
00000054 T __trampolines_start
00000078 W __vector_1
00000078 W __vector_10
00000078 W __vector_11
00000078 W __vector_12
00000078 W __vector_13
00000078 W __vector_14
00000078 W __vector_15
00000078 W __vector_16
00000078 W __vector_17
00000078 W __vector_18
00000078 W __vector_19
00000078 W __vector_2
00000078 W __vector_20
00000078 W __vector_3
00000078 W __vector_4
00000078 W __vector_5
00000078 W __vector_6
00000078 W __vector_7
00000078 W __vector_8
00000078 W __vector_9
00000000 W __vector_default
00000000 T __vectors
00000001 a __zero_reg__
00800060 T _edata
00800062 B _end
00000082 T _etext
0000007e T _exit
0000007e W exit
00810000 D foo
0000007c T main
00800060 B read_adc
As you can see, EEPROM variables are based at 0x0081???? so searching for that should be enough to pick them out.
If the --size-sort option is used then nm displays size rather than address. But if I use the -S flag as well:
avr-nm --size-sort -S -r --demangle application.elf
It looks like I can get both size and address information and then use the address as you've suggested:
00000074 00000010 T __do_clear_bss
00000090 0000000a T main
00810000 00000004 D foo
00800100 00000002 B read_adc
And you have big D and OP has little d.  Because of the "static"?
Yeah, lowercase symbols are local, uppercase are global.
