The AVR194.zip application wont compile in Atmel Studio 7
7 posts / 0 new
I have downloaded the software application folder named "AVR194.zip" from this website http://www.atmel.com/tools/ATAVR...
My goal is to compile the code in Atmel Studio 7 without any errors. The target folder I need to compile is named MC310_BLDC_Sensor which is located in AVR194\avr194_software\Applications\MC310_bldc_sensor.
I have tried to open the folder in Atmel Studio 7, but I cannot open anything because the files are not visible. I have tried to import "File -> Import -> AVR Studio 4 Project", and when I compile the main.c I receive errors, see the picture below.
Compile error BLDC_sensor
I believe there must be another way I can open and compile the code.
The problem is that I cannot compile the code. I hope you can try to download the zip folder, compile it and check if it works.
I would greatly appreciate your help.
That "error List" is almost entirely pointless. Switch to the "Output" tab and show the complete build output (as text, not a picture!).
I am guessing that because it comes from AS4 it may be specifying a C compiler you don't have installed as a "toolchain flavour".
Switched to "Output" tab, here is the picture.
Why not copy-paste the text here instead? smiley
:: Morten
Because my brain thought that was a good idea. But now that you pointed out, it has learned to copy-paste the text next time.
Thanks for informning that :)
Not entirely sure why my post is marked as a solution. Is the file that is missing the \WinAVR-20080610\bin\avr-gcc.exe then?
If it was me I think I'd forget about the import and just create a brand new project using the 4.9.2 that comes with AS7.
Hey Clawson,
You mentioned this "... C compiler you don't have it installed as a "toolchain flavour" ", I searched for toolchain and stumbled on this video "https://www.youtube.com/watch?v=...".
The video shows how to install the WINAVR and then add it to toolchain flavour.
After that, I imported the project as "AVR studio 4 project", it worked.
Thank you a lot!
The result: It says Build Suceeded!
The error is stated because I have no ISP debugger nor AVR PCB.
