Programmers Reference Card
12 posts / 0 new
Years ago, when I started programming, it was customary to have condensed listings of the microprocessor instruction set; usually called Programmers Reference Cards.
While I am not programming Atmel 8-bit micros in Assembly, occasionally I need to look at the Assembly output from the compiler.
Since I could not find an Instruction Set Reference Card on Atmel’s website, I made one.
Simply print the new attached file (see post#10) double sided (flip on short edge) and you have a 8.5 x 5.5 listing of the AVR 8-bit Instruction Set.
Enjoy,
Paul
* original pdf deleted at the author's request. Ross *
You never know where life is going to take you; sit back and enjoy the ride!
Good job
Perhaps just move the LPM instruction's under note 1
Note 3, is not telling the hole story (the new 16 register tiny's don't have LPM either, but have memory mapped flash)
Although I do not program in assembler, you have done something wonderful.
Nice!  I still cherish my M6800/09, and PDP-11 cards, though I seldom use them any more.  Thanks
Keys to wealth:
Isn't the correct term for such a card an "Orphan Annie"?
I still have my 6800 and 68HC11 cards somewhere!
Good point!
As an assembly programmer exclusively, this has become a welcome addition to the electronic documentation I have on one 27" screen and my development platform (33") where there is all kinds of real-estate for reasonably sized frames in Studio 7.
Still on the shelf in front of me...
Hi All,
At the suggestion of sparrow2, I added note 1 to the LPM instructions.
See the attached updated file.
If a moderator couple please remove the previous file, that would be great.
Enjoy,
Paul
And Brian tops us all by producing the actual item!
Those cards are nice.
The one attached is mine, from 1967.
TOU
PS - PaulieT - great work on that card!  Thanks for that!
