Switching from windows to linux | Atmel Studio
7 posts / 0 new
What is the easiest way to develop AVR on Linux (Ubuntu). Is simply compiling and generating a .hex file and burning it on the controller through a terminal the best option?
What is the best way?
Thanks alot!
(FYI I'm wasn't sure where to put this post (forum type))
Code is everything, code is life :D
Eclipse, Code blocks, netbeans or similar. Just pick an IDE you like that can support avr-gcc
That's minimal essential so will likely be multi-platform (multi-OS) and is the method used for continuous integration.
Cliff mentioned some of the IDE that work well with AVR GCC.
AVR debugging (AVR GDB) capability will reduce the set of AVR IDE.
https://www.avrfreaks.net/forum/problem-setting-linux-ubuntu-avr-make-no-rule-make-target-hex-stop
https://www.avrfreaks.net/forum/avr-studio-mac-linux
http://packages.ubuntu.com/search?keywords=AVaRICE&searchon=names&suite=all&section=all (AVR GDB server; svn347 is shy of Atmel EDBG)
Awesome, will check out eclipse, thanks!
I like to go Vim + avr-gcc + avrdude and makefiles. At first I did this because it gives a better understanding of how everything works. Now I continue to do it because of its simplicity.
Yea, I need something simple now, but I used it through the terminal, it was pretty slow. I need to finish and test a project I'm working on and after I will set it up with vim. Thanks!
