Bug in Studio ? Tiny 13 OC0A-Int wents wrong!
5 posts / 0 new
Hi !
I'm using Studio 4.12 SP3 and have problemns to simulate a Tiny13.
The OC0A Interrupt is executed if the counter is 1 higher than the compare value.
(e.g. OCR0A=3, then the OC0A INT will be called if the counter swaps from 3 to 4).
Any idea ?
From the "known issues":
Timer/Counters
16-bit Timer/Counters on all devices have several problems with PWM, prescaler and output compare. Output compare registers are not buffered properly.
The Asynchronous Status Register (ASSR) is not supported in timers with asynchronous mode. This is due to lack of a generic external clock implementation.
OK... forgotten to mention....
The Timer runs with MCLK/256...
far enough time to generate an interrupt...
and its 8 BIT wide..
But did you read the comment above from the AVR Studio help system where the simulator known issues are listed. Specifically the "several problems with .... and output compare". So why are you surprised if you see a problem?
Cliff
OK, I have see the list now....
I've changed my statements in the code for this first, short test time with the simulator...
Thanks anyway
