[SOLVED] SPI C problem
4 posts / 0 new
Hi everybody,
I am not sure if is it right forum for my question.
I am using XMEGA 128A4U MCU. I want use SPI. (with external Flash)
SPI initialize is ok, but when I use command spi_read_packet it is read value (wrong value) to the first cell - to the buffer_tx_servis[0]. Remain cells have value 0.
My original sub is here:
uint8_t readID_SPIFlash(void){
	uint8_t result = 1;
	uint8_t buffer_tx_servis[4];
	ioport_set_pin_low(SS_SPI_EEPROM);								// Select Flash
	asm("NOP");
	spi_write_single(pFlash_SPI, SPI_FLASH_READ_ID);				// Send cmd - ask for ID
	spi_read_packet(pFlash_SPI, buffer_tx_servis, 4);				// Read ID - it is 4 bytes
	ioport_set_pin_high(SS_SPI_EEPROM);								// SS to high
	asm("NOP");
	result = (buffer_tx_servis[0] == 0x1f) ? result * 1 :  0;
	result = (buffer_tx_servis[1] == 0x47) ?  result * 1 : 0;
	result = (buffer_tx_servis[2] == 0x01) ?  result * 1 : 0;
	asm("NOP");	asm("NOP");	asm("NOP");
	return result;
When I try rewrite my sub and replace spi_read_packet by 4 x spi_read_single, SW read all values and ID is OK
(new SUB)
	uint8_t result = 1;
	asm("NOP");
	spi_read_single(pFlash_SPI, &buffer_tx_servis[0]);  				// Read ID - it is 4 bytes
	spi_read_single(pFlash_SPI, &buffer_tx_servis[1]);
	spi_read_single(pFlash_SPI, &buffer_tx_servis[2]);
	spi_read_single(pFlash_SPI, &buffer_tx_servis[3]);
	asm("NOP");
	return result;
I think there is bug in my C code, but I can not find it.
Any advice ?
Solved I think:
When I use spi_master_packet - it use function from ASF file spi_master.c
there is:
status_code_t spi_read_packet(SPI_t *spi, uint8_t *data, size_t len)
    while (len--) {
        spi_write_single(spi,0); //Dummy write
        while (!spi_is_rx_full(spi)){
        spi_read_single(spi, data);
        data++;
    return STATUS_OK;
This function send dummy byte to SPI and read received byte.
But this sub call spi_read_single: it use:
inline static void spi_read_single(SPI_t *spi, uint8_t *data)
    spi_put(spi,0);
    while(!((*spi).STATUS & SPI_IF_bm));
    *data=spi_get(spi);
It is mean this sub send the next value to SPI. And it is my problem.
When I comment the first sending in spi_master.c. My SW working OK
    while (len--) {
        //spi_write_single(spi,0); //Dummy write
        //while (!spi_is_rx_full(spi)){
        data++;
    return STATUS_OK;
I do not know is it ok? Had anybody the same problem ?
That sure looks like a bug in ASF.
Does raise the question: "why bother with ASF for something as simple as SPI?" though.
I'm guessing it may not have been found previously as I doubt many other use SPI in ASF.
(and the very idea of spi_put() and spi_get() shows a possible lack of understanding in the person who wrote this in ASF. The fact is that SPI always is a put and a get at the same time - to try to split it just leads to confusion such as you are seeing here)
Yes
it is true.
I will mark this post like "SOLVED"
