How to add device to Avarice?
3 posts / 0 new
Looking at the .c code for Avarice, I see:
1) that it doesn't support a couple of the parts I bought to experiment with (should have checked earlier...), and:
2) At first glance it looks like adding support is mainly a task of entering a lot of magic numbers into a structure.
So... is there a how-to on filling in the magic numbers? And where do I find the numbers?
-dave
In Atmel's XML files. But it occasionally turns out to be a bit
tricky.
Which devices are you looking for exactly? Did you look into
the CVS sources, or into the latest release only? I've already
added a number of more devices since releasing AVaRICE 2.4,
and fixed some other bugs in there. If you tell me what you're
missing, I could make a quick attempt on adding it.
Jörg Wunsch
Did you look into the CVS sources, or into the latest release only?
I only looked in the 2.4 release sources that I downloaded. I'll go check the CVS.
