Undocumented I/O addresses and internal circuitry
11 posts / 0 new
AtMega328p
The following I/O addresses are reserved:
0x00, 0x01, 0x02, 0x0C through 0x14
Doing some tests, I found out that whenever the AVR does an INPUT instruction, the read value is stored somewhere other than the intended register of the INPUT, and stays there.  Later you can retrieve the read contents at of the above reserved addresses.  Yeah, the INPUT instructions make a copy of the read value in all the above I/O addresses, or, maybe all the above addresses gate the I/O register used to hold the INPUT read.
So, suppose PORTD register contains $F3.   If the AVR does an INPUT R5,PORTD, R5 will contain $F3, but also all the reserved addresses above, and will stay like this until another INPUT is executed.
Note that CBI and SBI is a Read-Modify-Write, operation, so doing  SBI PORTD,2 will first INPUT x,PORTD, lift bit 2 in "x", and Write the new contents $F7 to PORTD, as OUT PORTD,x.
I don't know where the "bit lift" is done and where is "x", but for sure the Reserved Addresses above will hold the result of the INPUT x,PORTD
Also, other instructions involving I/O addresses, such as SBIS and SBIC must read the I/O address, and the same results happens.  Whenever you do SBIC PORTD,7, the contents of PORTD, in this case $F7, will be hold on the Reserved I/O Addresses above.
LDS instructions changes nothing on such Reserved I/O Addresses.
Of course, this found wasn't planned by Atmel, it might be some unused address selection circuitry to be used on larger chips, that end up gating this INPUT temporary undocumented register.  But it is funny to have access to this special register, it may be useful in some circumstances.  One that comes up to mind, is when comparing two sequential INPUTs from PINB  for example, the first reading would be
INPUT R0, PINB   ; it will also store PINB on the reserved I/O addresses
You may lose R0 at this point, later (without any other INPUT done),
INPUT R16,$0    ; retrieve the last and long done INPUT R0, PINB
INPUT R17,PINB ; get a new and actual reading of PINB
CP  R16,R17      ; compare old and new
The gain?  During the time period of the first and second reading of PINB, that may be a long time, you don't need to store the first reading anywhere, saving one register or SRAM position is not always better than how fast is to store the first INPUT somewhere... goes to the ghost register at $0~$3 or $0C~$14.
Suppose you are creating a Logic Analyzer Capture routine and want to know when PINB changes somehow (no interrupts).
AAA:  INPUT R16, $0
      INPUT R17, PINB   ; this INPUT will be also saved on $0
      CP    R16, R17
      BREQ  AAA
Do something else... take some time (no INPUTs)...
      RJMP  AAA
Note that you don't need to save R17 (the last reading of PINB) anywhere, it will stay on $0 until the AAA is called again.   Obviously the first pass should be discarded.
Another use (yeah, I know), suppose you have a  loop of  random CBI / SBI at PORTD, want to halt and check PORTD, the previous value of PORTD, before the last CBI/SBI will be at $0.
Of course, AVRStudio Simulation is a joke in this matter, whenever you make an OUT to any reserved I/O addresses, it keeps the value there, and you can read it back nicely...  it treats all I/O addresses as pure memory for write/read  ;)
Wagner Lipnharski
Orlando Florida USA
That's interesting, undocumented stuff is always good to know, though it can't be used in practice, since Atmel can change it in future silicon revisions. I think I'll check my own ATmegas to see if they also work like that. We can call it LILA (last input latch) register.
These addresses would belong to ports A, E, F and G if the 328P had those ports, right? Maybe it's some side effect of the non-existent inputs. Also, when you toggle pins by writing to PINx, does that count as doing an input?
What I really would like to be mirrored in a low address I/O (<=31) would be a copy of the status register so that we could use sbic/sbis on flags.
Well, we could start a conspiracy theory about this, or just move along as there are probably all sorts of semi-useless things at undocumented addresses.
Conspiracy theories are always fun.
Indeed the chip designers didn't do us Mega88-class users a favor when the omnibus I/O layout was introduced--lots of gaps in the precious low I/O space.
But doesn't the instruction set give a complete set of BR__ op codes on SREG?  "Skip" is the degenerate "branch past one instruction", isn't it?
BRBS/BRBC are the generic, with pseudonyms for e.g. BRCC/BRCS, right?
Yeah, but the more different ways you can do the same thing, the better cheeky
Doesn't the datasheet say
...when there are really about 2/3 unique instructions?  Aren't those extra powerful instructions good enough for you?
The AVR instruction set is excellent, but I would do a couple of tweaks, actually. An instruction to complement flags. The adci instruction, that doesn't exist. Locating sreg in the lower 32 I/O addresses, in range of sbi/cbi sbic/sbis. BST/BLD should operate on the carry flag instead of T flag.
theusch wrote:
But doesn't the instruction set give a complete set of BR__ op codes on SREG? "Skip" is the degenerate "branch past one instruction", isn't it? BRBS/BRBC are the generic, with pseudonyms for e.g. BRCC/BRCS, right?
I'm out.  Next you'll want HCF.  Where in the instruction set map would you add all your magic redundant instructions?  Refer to the several threads that thoroughly explored the "map" and the "holes" that are remaining.
Of what I proposed, only adci would actually require opcode slots. I'm well aware there is limited room.
But c'mon, aren't you taking this too seriously? I was just thinking out loud, it's not like I am demanding those features...
This reminds me when I was at school (long time ago) and was learning something about asm for the 8080 (Even then an old processor)
I used 3 of 4 different simulators and they all had a different implementation of the half carry flag.
In the end I gave up using packed bcd, it was not like this software was critical.
@ school they had also bought a good looking but extremely slow and buggy simulator.
For the homework I used some small, lean & fast assembler & simulator with a debug like interface.
My program (rpn calculator) which took less than an eyeblink to run at home took several minutes to run at school and this was in the days of 486 or pentium.
Oh, yes. The DAA instruction was pretty useless. I made a decimal calculator once using it, could add, subtract, multiply and divide 6 digit numbers, but it was lots easier to do two's complement math and convert to or from decimal for input and output.
Tip: To multiply by 10: Shift left. Save a copy. Shift left twice more and add the saved copy.
