3.3V to 1.8V problems
23 posts / 0 new
I have just switched from powering my micro with 3.3v to 1.8v and now the micro and i think usart does not work.  I cannot test the output of the usart because the ttl level is below 3v.
I am running 4MHz and 9600 baud.  Is this to much for a 1.8v supply.  Should I drop down to 1MHz.
Other than swapping from 3.3v to 1.8v I have changed nothing else.  Do I need to changed anything else when dropping the supply voltage?
thanks.
And your micro is which model? What does its datasheet say about supply voltage options and operating frequency limits?
Tuurbo46 wrote:
 my micro
and you expect us to guess which micro that might be?!
So how can you tell it's not working?
What were you expecting to connect to it?
What does the datasheet say?
Such as BOD level?
Oh sorry, its a ATmega324P
Just trying to find the voltage baud cross over.
Tuurbo46 wrote:
...  I cannot test the output of the usart because the ttl level is below 3v.
That got me curious.
First, why couldn't it be "tested" by looking with a 'scope?
Then for fun I went to DigiKey and found 1.8V or lower RS232 transceivers from several manufacturers.
page 324 displays I am right on the edge of working.  should I therefore drop my clk speed?
thanks
Well I guess you are out of luck.
Hi Valusoft.
Well this could be my problem!!
What page did you find that on?
On page 2 of the datasheet (ATmega164A/164PA/324A/324PA/644A/644PA/1284/1284P ) it quotes the below:
Operating voltage 1.8V - 5.5V.
Page 2 of http://www.atmel.com/Images/Atme... (Atmel-42743B-ATmega324P/V_Datasheet_Summary-08/2016)
Tuurbo46 wrote:
On page 2 of the datasheet (ATmega164A/164PA/324A/324PA/644A/644PA/1284/1284P ) it quotes the below: Operating voltage 1.8V - 5.5V.
And right below:
So you are within spec.  But you still haven't answered why you think it is not working.  Nor about BOD level.
Lee, the datasheet that I have quoted from above is dated August 2016. I guess it and "yours" could be contradictory but as the OP is experiencing problems below 2.7Volts.... well draw your own conclusions.
I am out.
Cheers,
Ross
I'm with Ross.
David
Do you have a '324P-20', a '324PV-10', a '324A' or a '324PA'?
[E2A]
and for completeness there was also a '324-20' and a '324V-10'.
valusoft wrote:
Lee, the datasheet that I have quoted from above is dated August 2016. I guess it and "yours" could be contradictory but as the OP is experiencing problems below 2.7Volts.... well draw your own conclusions. I am out. Cheers, Ross
DAFlippers wrote:
I'm with Ross. David
[edit]  Doh!  I was reading '328 when OP said '324.  Sorry.  BOD level and how testing is done still applies.  ;)  lht
There is no "safe" BOD level for 1.8V...
It's pretty close anyway. ;)  (In bench tests some years back on a model in this family it ran very reliably to a bit below 1V including EEPROM.)
There are '328Ps and '328Ps.  As I recall, '328 (or maybe '328P) was already the A process when it came out.  So without date code and die version and such it is really hard to tell.
The latest I have downloaded is as below, doc 8271 rev. J 11/2015.  The "omnibus" covering the family.
Anyway, OP has to tell us what "doesn't work" means, and BOD level.
OK after double checking the chip, at some point it has moved from an ATmega324P to now using a ATmega324PA AU1522.
Yes I have tried changing the BOD levels but not luck.  But when I switch back to 3.3V the circuit works correctly.  I cannot even flash an led at 1.8V.
Thanks for your help.
Well, a 'PA' should be good for 4MHz.
What oscillator are you using? If it's an external crystal, try setting it to 'full-swing'.
Hi Brain,
I am using the internal oscillator.
So you think 4MHz, 9600 baud, 1.8v should be ok?
thanks.
The internal RC oscillator runs at 8MHz so to run at 4MHz you are setting up a divide by two in CLKPR?
What's not clear from the datasheet is if the RC oscillator will run on 1.8V.
Did you turn it off?  Did you see above that the is no "safe" BOD level for 1.8V?
Re the LED:  What is the forward voltage?
When you ramp up the supply V, at what voltage does it start "working"?
Brian,
Yes I am dividing by two in CLKPR.  This works correctly at 3.3V.
Theusch,
BOD: I did see there is not a safe level for 1.8V, but I tried anyway.
LED: yes you are correct, the led will not work because the voltage drop is 1.8V, well spotted.
Power Supply: I do not have a bench power supply, only a battery.  I can only confirm it works correctly at 3.3V but not 1.8V.
I may just resort back to 3.3V as a few articles on google quote some chips will not run close to there minimum VDD.
Thanks for your help everybody.
Sheesh--did you try >>disabling<< the brownout?!?
And for a sanity check, you have no potentiometer and voltmeter available to manipulate the voltage for a few minutes of experimentation?
Think it through a bit.  Tell more about the purpose of the exercise of 1.8V.  (Are there common batteries with that nominal voltage?  I see none at DigiKey.)  Tell, with proper transceiver, why the UART won't work.  Tell what you connect the UART to, and what you expect.
Hi theusch,
So my project is nearly finished, and I am just trying to put it into low low power mode.
I had a bad power consumption problem, and a design over-site, I have found out I was trying to control a CMOS logic level modem CTS and TX lines with 3.3V.
To resolve this problem I can either power the micro with 1.8V or put a potential divider in the CTS and TX lines.  A level shifter chip would require a new board design which I cannot do at this stage.
So what is the best solution, 1.8V or potential divider.  I can cut the board and put the potential dividers in without a problem.
Tuurbo46
